Kuczi Zgłoś #141 Napisano 25 Listopada 2008 (edytowane) Mam wszystkie kody VAG i tam nie ma tego co szuka, ponad 100 stron w wordzie... M3L 4-cyl. turbo diesel engine 1.9 L/85 kW TDI with pump-jet injection system base engine is T4N/TD0 M00 6-cyl. gasoline engine 2.8 L/137 kW 5V ECE base engine is T7F M01 industr. carburetor eng. 1.8 L/max. 49kWat 4000rpm (unit 026.L) M02 industr. diesel engine 1.9 L/max. 50 kW at 4400rpm (unit 028.L) M03 indust. turbo diesel eng. 1.6 L / max. 53kW at 4500rpm (unit 068.H) M04 industr. diesel engine 1.6 L/max. 40 kW at 4800rpm (unit 068.K) M05 industr. diesel engine 2.4 L/max. 55 kW at 4300rpm (unit 075.Y) M06 indust. turbo diesel eng. 2.4 L/ max. 75 kW at 4300rpm (unit 075.Z) M07 4-cylinder diesel engine 1.9 L/55 kW turbocharger acc. to Canadian reg., cat base engine is T2N M08 4-cylinder diesel engine 1.9 L/55 kW w/ turbocharger and EGR for Canada, cat base engine is T2N M09 4-cylinder gasoline engine 2.0 L/79 kW DIGIFANT base engine is T3S M0A 4-cylinder gasoline engine 1.4 L/44 kW Monomotronic, closed-loop cat. converterbase engine is T3P M0B 6-cylinder gasoline engine 2.8 L/120 kW base engine is T6N M0C 5-cyl. diesel engine 2.5 L/55 kW SDI base engine is T8P M0D 4-cyl. gasoline engine 1.6 L/74 kW 20V with catalytic converter base engine is T5D M0E 4-cyl. gas. eng. 1.8 L/118 kW DIGIFANT G60 w/ closed-loop cat, small intercooler, base engine is T3R M0F 5-cyl. turbo diesel eng. 2.5 L/75 kW TDIEU 2, light commercial vehicle 2 base engine is T8Q M0G 4-cyl. turbo diesel eng. 1.9 L/66 kW TDIwith MVEG 2 base engine is T0W M0H 5-cylinder gasoline engine 2.2 L/232 kW turbo injection base engine is T1M M0J 4-cylinder gasoline engine 1.6 L/74 kW multi-point injection, US 83 base engine is T6H M0K 4-cylinder gasoline engine 1.6 L/53 kW open-loop catalytic converter base engine is T2L M0L 5-cyl. turbo diesel eng. 2.5 L/75 kW TDIMVEG 2 base engine is T8Q M0M 4-cyl. gasoline eng. 1.8 L/77 kW DIGIFANT, EGR, closed-loop catalytic converter, base engine is T3E M0N 4-cylinder gasoline engine 1.3 L/37 kW according to Austrian regulations base engine is T3H M0P 6-cyl. gasoline engine 2.9 L/135 kW VR6 Motronic, MVEG 1, catalytic converter base engine is T6Q M0Q 5-cyl. diesel engine 2.5 L/75 kW TDI turbocharger, MVEG1, catalytic converterbase engine is T7K M0R 4-cylinder gasoline engine 2.0 L/85 kW intake manifold injection base engine is T6Y/T18/T55/TE2/TB2 M0S 4-cylinder diesel engine 1.4 L/35 kW with idle speed control base engine is T3Q M0T 4-cyl. turbo diesel engine 1.9 L/66 kW direct injection base engine is T0T M0U 4-cylinder gasoline engine 1.6 L/55 kW w/ MPI, MVEG 2 a. closed-loop cat. conv.base engine is T3N M0V 4-cylinder gasoline engine 1.4 L/44 kW w/ MPI, MVEG 2 a. closed-loop cat. conv.base engine is T3L/T4M M0W 4-cylinder gasoline engine 1.4 L/44 kW Monomotronic, closed-loop cat., MVEG 2 base engine is T3P M0X 4-cylinder gasoline engine 1.4 L/44 kW Monomotronic, appendix 15/04 base engine is T3P M0Y 4-cylinder gasoline engine 1.8 L/77 kW DIGIFANT, closed-loop cat. converter base engine is T3E M0Z 4-cylinder gasoline engine 1.8 L/79 kW DIGIFANT, closed-loop US cat. converter base engine is T3E M10 6-cylinder gasoline engine 2.8 L/142 kW TLEV base engine is T7F M11 4-cylinder gasoline engine 2.0 L/85 kW Simos, catalytic converter and MVEG 2 base engine is T8A M12 4-cylinder gasoline engine 1.3 L/40 kW Monomotronic, MVEG 2 base engine is T4Z M13 4-cylinder gasoline engine 0.9 L/32 kW with MVEG 2 base engine is M14 6-cylinder gasoline engine 2.8 L/128 kW multi-point injection, appendix 15.04 base engine is T6N M15 4-cylinder gasoline engine 1.3 L/40 kW Monomotronic as of P.7585H MVEG 2 base engine is T4Z M16 4-cylinder diesel engine 1.9 L/47 kW SDIwith MVEG 2 base engine is T2Q M17 4-cylinder gasoline engine 1.8 L/77 kW with multi-point injection, MVEG 2 base engine is T6E M18 4-cylinder gasoline engine 2.0 L/85 kW with EGR, MVEG 2/EU 3D M19 4-cylinder gasoline engine 1.6 L/74 kW base engine is T6S M1A 4-cylinder gasoline engine 2.0 L/85 kW DIGIFANT, catalytic converter M1B 4-cylinder gasoline engine 2.0 L/85 kW Motronic, closed-loop cat. (cross-flow) base engine is T3U M1C 4-cylinder gasoline engine 2.0 L/85 kW DIGIFANT base engine is T3S M1D 4-cylinder gasoline engine 1.8 L/55 kW Monomotronic, catalytic converter base engine is T5U M1E 4-cylinder gasoline engine 1.8 L/55 kW Monomotronic with single point injectionbase engine is T5U M1F 5-cylinder gasoline engine 2.3 L/110 kW with MVEG 2 base engine is T8R M1G 5-cyl. gasoline engine 2.0 L/118 kW 20V base engine is T3B M1H 5-cylinder gasoline engine 2.2 L/100 kW continuous injection system base engine is T3A M1J 5-cylinder gasoline engine 2.3 L/98 kW electronic fuel injection with cat base engine is T3C M1K 5-cylinder gasoline engine 2.3 L/98 kW electr. fuel injection system, activatedcharcoal canister base engine is T3C M1L 4-cylinder gasoline engine 1.6 L/55 kW Monomotronic, closed-loop cat. converterbase engine is T4L M1M 6-cyl. gasoline engine 2.9 L/140 kW VR6 Motronic, closed-loop catalyt. converterbase engine is T6Q M1N 4-cyl. gasoline eng. 1.8 L/118 kW DIGIFANT G60, sm. intercooler, nominal rpm output, base engine is T3R M1P 5-cylinder gasoline engine 2.0 L/85 kW continuous injection system base engine is T3T M1Q 4-cylinder gasoline engine 1.6 L/55 kW Monomotronic, MVEG 2 base engine is T4L M1R 5-cylinder gasoline engine 2.0 L/85 kW electronic fuel injection and cat base engine is T3T M1S 5-cyl. gasoline engine 2.2 L/169 kW 20V closed-loop catalytic converter base engine is T3V M1T 4-cylinder gasoline engine 1.8 L/118 kW DIGIFANT G60 closed-loop cat. converter base engine is T3R M1U 4-cylinder diesel engine 1.9 L/50 kW SDIEU 3 base engine is T0X/T76 M1V 4-cylinder gasoline engine 1.8 L/72 kW DIGIFANT, closed-loop cat. converter base engine is T3E M1W 4-cylinder gasoline engine 1.4 L/44 kW with multi-point injection base engine is T3L M1X 4-cylinder gasoline engine 1.8 L/118 kW DIGIFANT G60 (80.6 bore) base engine is T3R M1Y 4-cylinder gasoline engine 2.0 L/85 kW Simos base engine is T8A M1Z 4-cylinder gasoline engine 1.8 L/77 kW DIGIFANT base engine is T3E M20 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, US 83 base engine is T8C M21 6-cyl. gasoline engine 2.8 L/103 kW VR6 Motronic, closed-loop cat w/ EGR and SAPbase engine is T2X M22 4-cyl. diesel engine 1.9 L/63 kW with cat, ESC, turbo, intercooler w/ lower supercharger, base engine is T0N M23 6-cyl. gasoline engine 2.8 L/132 kW V6 contr. cat w/ changed NOx values, Calif.base engine is T6N M24 4-cylinder gasoline engine 1.6 L/75 kW KA jetronic, appendix 15/04 base engine is T2T M25 5-cyl. gasoline eng. 2.5 L/81 kW DIGIFANT, closed-loop cat. converter w/ EGR a. SAP base engine is T2Y M26 6-cylinder gasoline engine 2.4 L/110 kW base engine is T8N M27 4-cylinder gasoline engine 1.8 L/66 kW keihin carburetor, appendix 15/04 base engine is T38 M28 4-cylinder gasoline engine 1.8 L/73 kW BOSCH Motronic base engine is T39 M29 4-cyl. gasoline engine 1.8 L/92 kW 20V M2A 4-cylinder gasoline engine 1.6 L/75 kW base engine is T0H M2B 4-cyl. gasoline engine 1.8 L/92 kW 20V US 83 base engine is T0V M2C 5-cylinder gasoline engine 2.5 L/81 kW DIGIFANT, closed-loop catalyt. converterbase engine is T2Y M2D 4-cyl. gasoline engine 1.8 L/95 kW 16V closed-loop catalytic converter base engine is T2D M2E 4-cyl. gasoline engine 1.8 L/102 kW 16V base engine is T2D M2F 6-cyl. gasoline engine 2.8 L/128 kW VR6 Motronic, MVEG 2, EGR a. closed-loop catbase engine is T6N M2G 4-cylinder diesel engine 1.9 L/50 kW with load-controlled start of delivery base engine is T2E M2H 5-cylinder gasoline engine 2.5 L/81 kW DIGIFANT, appendix 15/04 base engine is T2Y M2J 4-cylinder diesel engine 1.9 L/45 kW base engine is T2G M2K 4-cyl. turbo diesel eng. 1.9 L/66 kW TDIand MVEG 2 base engine is T2F M2L 4-cylinder gasoline engine 1.8 L/82 kW with continuous injection system base engine is T2A M2M 10-cyl. diesel engine 5.0 L/230 kW TDI pump-jet injection system base engine is T2M/T80/TE7/TF7 M2N 4-cylinder gasoline engine 1.8 L/66 kW base engine is T2C M2P 5-cylinder diesel engine 2.5 L/75 kW TDIturbocharger and intercooler base engine is T7K M2Q diesel engine 1.9 L/40 kW for Multicar M2R 4-cylinder gasoline engine 1.8 L/66 kW electr. fuel injection a. controlled catbase engine is T2B M2S 4-cylinder gasoline engine 1.8 L/66 kW base engine is T2H M2T 4-cylinder diesel engine 1.9 L/47 kW MVEG 2, catal. converter, swirl chamber base engine is T2V M2U 4-cylinder diesel engine 1.9 L/47 kW with load-controlled start of delivery base engine is T2E M2V 4-cylinder gasoline engine 1.8 L/62 kW catalytic converter (open-loop) base engine is T2H M2W 4-cylinder gasoline engine 1.6 L/60 kW keihin base engine is T2P M2X 4-cylinder gasoline engine 1.8 L/66 kW keihin carb., cat. conv. (open-loop) base engine is T0A M2Y 4-cylinder gasoline engine 1.8 L/70 kW keihin base engine is T2S M2Z 4-cylinder gasoline engine 1.6 L/55 kW base engine is T2W M30 4-cylinder gasoline engine 2.0 L/85 kW DIGIFANT, closed-loop catalyt. converterbase engine is T3Z M31 4-cylinder gasoline engine 1.8 L/66 kW DIGIFANT, closed-loop catalyt. converterbase engine is T4J M32 4-cyl. gasoline engine 1.8 L/95 kW 16V DIGIFANT, closed-loop catalyt. converterbase engine is T1D M33 4-cylinder diesel engine 1.9 L/50 kW SDIEU 3 and pump-jet injection system base engine is T4P M34 5-cyl. gasoline engine 2.2 L/169 kW 20V closed-loop catalytic converter base engine is T1G M35 6-cyl. gasoline eng. 3.2 L/162 kW 24V VR6 base engine is T31, T36 M36 4-cylinder gasoline engine 2.0 L/85 kW DIGIFANT, lead resistant lambda probe base engine is T3Z M37 4-cyl. gasoline eng. 1.8 L/66kW DIGIFANTwith lead resistant lambda probe base engine is T4J M38 4-cyl. gasoline engine 2.0 L/110 kW 16V DIGIFANT, catalytic converter, MVEG 2 base engine is T3X M39 6-cyl. gasoline engine 2.8 L/128 kW VR6 w/ MPI, MVEG 2, controlled cat, w/o EGR base engine is T6N M3A 4-cylinder gasoline engine 1.3 L/57 kW DIGIFANT base engine is T3W M3B 4-cylinder gasoline engine 1.3 L/55 kW DIGIFANT, closed-loop catalyt. converterbase engine is T3W M3C 4-cyl. gasoline engine 1.0 L/51 kW 16V MVEG 2 base engine is T3Y M3D 4-cyl. gasoline engine 2.0 L/110 kW 16V DIGIFANT, catalytic converter base engine is T3X M3E 8-cyl. gasoline engine 4.0 L/202 kW 32V WR8 base engine is T9H M3F 5-cyl. gasoline engine 2.2 L/162 kW 20V closed-loop catalytic converter base engine is T4W M3G 12-cyl. gas. eng. 6.0 L/309 kW WR12 48V Motronic base engine is T01 M3H 4-cyl. gasoline eng. 1.3 L/83kW DIGIFANTG-supercharger, cat, MVEG 1 without EGR base engine is T3J M3J 4-cyl. gas. eng. 1.8 L/118 kW DIGIFANT G60, contr. cat, EGR, small intercooler nom. rpm outp. 5800rpm, base eng. is T3R M3K 4-cyl. gasoline engine 1.3 L/40 kW DIGIJET, closed-loop catalytic converterbase engine is T3G M3L 4-cyl. turbo diesel engine 1.9 L/85 kW TDI with pump-jet injection system base engine is T4N/TD0 M3N 4-cylinder gasoline engine 1.05 L/33 kW (carburetor 1B) M3P 4-cylinder gasoline engine 1.3 L/40 kW (carburetor 2E3) base engine is T3H M3Q 4-cylinder diesel engine 1.3 L/33 kW M3R 4-cylinder gasoline engine 1.05 L/33 kW micro catalytic converter (open-loop) base engine is T3F M3S 4-cylinder gasoline engine 1.3 L/40 kW carburetor 2E3, open-loop catalyt. conv.base engine is T3H M3T 4-cylinder gasoline engine 1.05 L/37 kW (carburetor TL-1B) base engine is T3F M3U 4-cylinder gasoline engine 1.3 L/85 kW DIGIFANT, G-supercharger base engine is T3J M3V 4-cylinder gasoline engine 1.6 L/55 kW base engine is T2L M3W 4-cylinder gasoline engine 2.0 L/85 kW Motronic, contr. cat a. EGR (cross-flow)base engine is T3U M3X 4-cylinder gasoline engine 1.8 L/82 kW DIGIFANT base engine is T3E M3Y 4-cylinder gasoline engine 1.8 L/79 kW DIGIFANT, closed-loop cat. converter base engine is T3E M40 5-cylinder gasoline engine 2.5 L/81 kW Simos, appendix 15/04 base engine is T6Z M41 4-cylinder gasoline engine 2.0 L/85 kW DIGIFANT w/ lead resistant lambda probe base engine is T0P M42 4-cylinder gasoline engine 2.0 L/85 kW DIGIFANT, closed-loop catalytic convert.base engine is T0P M43 4-cylinder gasoline engine 1.0 L/33 kW Monomotronic, MVEG 2 base engine is T4R M44 6-cyl. gasoline engine 2.8 L/142 kW 30V ECE base engine is T7F M45 4-cylinder gasoline engine 2.0 L/79 kW appendix 15/04 M46 8-cyl. gasoline eng. V8 4.2 L/228 kW 40Vcamshaft adjustment w/o cylinder cutout base engine is T7S M47 5-cylinder gasoline engine 2.5 L/81 kW Simos, closed-loop catalytic converter base engine is T6Z M48 5-cyl. diesel engine 2.5 L/75 kW TDI, cat, turbocharger, intercooler and EGR, OBD D base engine is T7K M49 5-cyl. turbo diesel engine 2.5 L/103 kW with MVEG 2 base engine is T4E M4A 5-cyl. turbo diesel engine 2.5 L/84 kW open-loop catalytic converter base engine is T4E M4B 4-cylinder gasoline engine 1.8 L/66 kW Monomotr., single-point inj., contr. catbase engine is T5W M4C 4-cylinder gasoline engine 1.8 L/66 kW Monomot., contr. cat, mod. lambda probe base engine is T5W M4D 4-cylinder gasoline engine 1.8 L/66 kW Monomotronic base engine is T5W M4E 4-cyl. gasoline eng. 2.0 L/85 kW Motronic, cross-flow w/ lead-resis. lambda probe, base engine is T3U M4F 4-cylinder gasoline engine 1.8 L/49 kW carburetor 2E3 base engine is T4C M4G 4-cylinder gasoline engine 2.0 L/85 kW closed-loop catalytic converter base engine is T4G M4H 4-cylinder gasoline engine 2.0 L/85 kW closed-loop catalytic converter and EGR base engine is T4G M4J 5-cylinder gasoline engine 2.3 L/100 kW with electronic fuel injection base engine is T3C M4K 4-cylinder gasoline engine 2.0 L/62 kW DIGIFANT, closed-loop catalyt. converterbase engine is T4B M4L 4-cylinder gasoline engine 2.0 L/62 kW DIGIFANT base engine is T4B M4M 5-cylinder gasoline engine 2.3 L/100 kW w/ electr. fuel inject., EGR, contr. catbase engine is T3C M4N 4-cylinder gasoline engine 2.0 L/74 kW closed-loop catalytic converter base engine is T4H M4P 4-cylinder gasoline engine 1.05 L/33 kW Monojetronic, closed-loop catalyt. conv.base engine is T4Q M4Q 4-cylinder gasoline engine 1.05 L/33 kW Monomotronic, MVEG 1 base engine is T4R M4R 4-cylinder boxer engine 1.6 L/34 kW fuel injected engine base engine is T0S M4S 4-cyl. turbo gasol. eng. 1.8 L/165kW 20VEU 3D base engine is T6B M4T 4-cylinder gasoline engine 1.6 L/74 kW w/ multi-point injection a. MVEG 2/EU 3Dbase engine is T6U M4U 4-cylinder gasoline engine 2.0 L/66 kW single-point injection, closed-loop cat base engine is T4D M4V 4-cylinder gasoline engine 2.0 L/66 kW single-point injection base engine is T4D M4W 4-cylinder gasoline engine 2.0 L/85 kW Motronic with EGR, SAP and TLEV base engine is T3U M4X 4-cylinder gasoline engine 2.0 L/85 kW Monomotronic with EGR and SAP base engine is T3U M4Y 4-cylinder gasoline engine 1.8 L/118 kW G60, big intercooler, closed-loop cat base engine is T3R M4Z 4-cylinder gasoline engine 1.6 L/55 kW with MPI, MVEG 2 and catalytic converterbase engine is T0B M50 4-cyl. gasoline engine 1.6 L/103 kW 20V MVEG 2 a. closed-loop catalyt. converterbase engine is T5Y M51 4-cyl. gasoline engine 1.8 L/92 kW 20V with MVEG 2 base engine is T0V/T5Z M52 4-cyl. gasoline engine 1.8 L/92 kW 20V with EU 4 base engine is T5Z M53 4-cylinder gasoline engine 1.6 L/74 kW HITACHI, closed-loop catalytic converterbase engine is T0Q M54 4-cyl. gasoline engine 1.6 L/53 kW Monomotronic, base engine is T5P base engine is T5P M55 4-cyl. turbo gas. eng. 1.8 L/154 kW 20V EU 3D base engine is T6B M56 4-cyl. turbo diesel engine 1.9 L/66 kW direct injection, with Tier1-US base engine is T0E M57 4-cylinder gasoline engine 1.6 L/74 kW MPI HITACHI with MVEG 2/EU 3D base engine is T6S M58 4-cylinder gasoline engine 1.6 L/74 kW MPI HITACHI w. closed-loop catal. conv. M59 4-cylinder gasoline engine 1.8 L/66 kW Monomotronic, cat. conv. a. MVEG 2/EU 3Dbase engine is T5C M5A 4-cylinder gasoline engine 1.05 L/29 kW M5B 4-cylinder gasoline engine 1.6 L/74 kW HITACHI base engine is T0Q M5C 4-cylinder gasoline engine 1.3 L/55 kW M5D 4-cylinder gasoline engine 2.0 L/85 kW w/ electr. fuel inj., EGR, contr. cat base engine is T5E M5E 4-cylinder gasoline engine 1.3 L/43 kW M5F 4-cylinder gasoline eng. 2.0 L/83 kW w/ activ. charcoal canister, electr. fuel inj., base engine is T5E M5G 4-cylinder gasoline engine 1.8 L/66 kW Monomotronic, catalytic converter base engine is T5C M5H 4-cylinder gasoline engine 1.8 L/66 kW Monomotronic base engine is T5C M5J 4-cylinder diesel engine 1.9 L/47 kW with MVEG 1 base engine is T2E M5K 4-cyl. gasoline engine 2.0 L/100 kW 16V closed-loop catalytic converter base engine is T5J M5L 5-cylinder gasoline engine 2.3 L/125 kW w/ activated charcoal canister (tourist solution) base engine is T5F M5M 4-cylinder gasoline engine 1.8 L/66 kW Monojet, single-point inj., contr. cat base engine is T5A M5N 5-cyl. gasoline engine 2.3 L/125 kW 20V w/ EGR, closed-loop catalytic converter base engine is T5F M5P 5-cyl. gasoline engine 2.3 L/125 kW 20V closed-loop catalytic converter base engine is T5F M5Q 4-cylinder gasoline engine 2.0 L/85 kW w/ electronic fuel injection, cat. conv.base engine is T5E M5R 4-cylinder gasoline engine 1.6 L/51 kW carburetor 2EE, closed-loop cat. conv. base engine is T5R M5S 4-cyl. gasoline engine 2.0 L/101 kW 16V closed-loop cat. converter f. Californiabase engine is T5M M5T 4-cylinder gasoline engine 1.6 L/51 kW 2EE, closed-loop catalytic converter base engine is T5L M5U 4-cylinder gasoline engine 1.6 L/53 kW Monomotronic, closed-loop cat. converterbase engine is T5P M5V 6-cyl. turbo diesel engine 2.5 L/110 kW catalytic converter and EGR, MVEG 2 base engine is T6T M5W 4-cylinder gasoline engine 1.8 L/66 kW with activated charcoal canister base engine is T5A M5X 4-cylinder gasoline engine 2.0 L/100 kW w/ red. emission spec. acc. to Calif. regulations contr. cat, base engine T5J M5Y 4-cyl. gasoline engine 2.0 L/103 kW 16V Motronic, closed-loop catalyt. converterbase engine is T5M M5Z 6-cyl. gasoline engine 2.8 L/130 kW VR6 with multi-point injection, MVEG 2 base engine is T2R M60 4-cylinder gasoline engine 2.0 L/85 kW Motronic base engine is T3U M61 4-cylinder gasoline engine 1.8 L/92 kW MVEG 1 base engine is T5Z M62 4-cyl. turbo diesel engine 1.9 L/85 kW MVEG 2, TDI with pump-jet injection system, base engine is T4N M63 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection and MVEG 2 base engine is T6H M64 4-cyl. gasoline engine 1.4 L/74 kW 16V with multi-point injection and MVEG 2 base engine is T1N/T5G M65 4-cylinder gasoline engine 1.8 L/70 kW with MPI (low octane fuel) base engine is T6E M66 4-cylinder gasoline engine 1.8 L/55 kW Monomotronic, EU 3D base engine is T5U M67 4-cylinder gasoline engine 1.8 L/66 kW Monomotronic, EU 3D base engine is T5C M68 4-cylinder gasoline engine 1.8 L/92 kW multi-point injection, ECE base engine is T9K M69 4-cylinder gasoline engine 1.8 L/92 kW multi-point injection, MVEG 2 base engine is T9K M6A 6-cyl. gasoline engine 2.8 L/130 kW VR6 with multi-point injection base engine is T2R M6B 4-cylinder diesel engine 1.6 L/40 kW with reduced emission specificat. acc. to Swiss/US regulations, base engine T6F M6C 4-cylinder diesel engine 1.6 L/40 kW base engine is T6F M6D 4-cyl. turbo diesel engine 1.6 L/51 kW swirl chamber 24.5 base engine is T6A M6E 4-cyl. turbo diesel engine 1.6 L/51 kW swirl chamber 24.5, appendix 23 base engine is T6A M6F 3-cyl. turbo diesel eng. 1.4 L/55 kW TDIpump-jet injection system base engine is T0U M6G 4-cylinder diesel engine 2.0 L/66 kW EU 3, for FORD M6H 5-cylinder diesel engine 2.4 L/55 kW catalytic converter, MVEG 1 base engine is T7D M6J 4-cylinder diesel engine 1.6 L/40 kW according to Canadian regulations base engine is T6F M6K 5-cylinder gasoline engine 2.5 L/85 kW Simos, cat. conv. with EGR, MVEG2/EU3-D base engine is T6Z M6L 4-cylinder diesel engine 2.0 L/85 kW EU 3, for FORD M6M 6-cyl. gasoline engine 2.8 L/140 kW VR6 Motronic, closed-loop cat acc. to Calif.regulations, base engine is T6Q M6N 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIwith MVEG 2 base engine is T1R M6P 4-cylinder diesel engine 1.6 L/40 kW with load-controlled start of charging base engine is T6F M6Q 4-cyl. turbo diesel engine 1.6 L/59 kW swirl chamber 23.5 w. intercooler, load-contr. start of charg., base eng. is T6G M6R 4-cyl. turbo diesel engine 1.6 L/59 kW swirl chamber 24.5, appendix 25 base engine is T6G M6S 4-cyl. turbo diesel engine 1.6 L/59 kW w/ load-contr. start of charging a. intercooler, base engine is T6C M6T 6-cylinder gasoline engine 2.9 L/140 kW Motronic, catalytic converter and MVEG 2base engine is T6Q M6U 4-cylinder gasoline engine 1.6 L/52 kW Monomotronic base engine is T5K M6V 4-cyl. turbo diesel engine 1.6 L/59 kW without idle speed control base engine is T6C M6W 8-cyl. gasoline engine 3.7 L/191 kW V8 camshaft adjust. w/o cyl. cutout, EU 3-Dbase engine is T8X M6X 4-cylinder diesel engine 1.9 L/50 kW with catalytic converter, EGR control base engine is T0G M6Y 6-cyl. gasoline engine 2.6 L/110 kW V6 base engine is T7G M6Z 4-cylinder diesel engine 1.9 L/50 kW ecodiesel f. com. veh., turboch. a. EGR base engine is T0G M70 6-cyl. gasoline eng. 2.8 L/142 kW V6 5V LEV base engine is T7F M72 8-cyl. gasoline engine 4.2 L/220 kW V8 Motronic, closed-loop catalyt. converterbase engine is T7W M73 8-cyl. gasoline engine 4.2 L/213 kW with MVEG 2, closed-loop catalytic conv.base engine is T7J M74 8-cyl. gasoline engine 4.2 L/220 kW V8 Motronic, OBD 2 (California) base engine is T7W M75 6-cylinder gasoline engine 2.8 L/128 kW MH-motronic with catalytic converter, TLEV M76 6-cylinder gasoline engine 2.6 L/110 kW MVEG 2 base engine is T7Y M77 6-cylinder gasoline engine 2.6 L/110 kW LH-motronic with closed-loop cat. conv. base engine is T7Y M78 6-cylinder gasoline engine 2.8 L/128 kW MH-motronic with catalytic conv., MVEG 2base engine is T7X M79 6-cylinder gasoline engine 2.8 L/128 kW MH-motronic with closed-loop cat. conv. base engine is T7X M7A 4-cylinder gasoline engine 1.8 L/61 kW M7B 4-cylinder diesel engine 2.4 L/58 kW M7C 5-cylinder diesel engine 2.4 L/55 kW M7D carburetor engine 2.2 L/69 kW M7E fuel injection engine 2.4 L/84 kW with closed-loop catalytic converter M7F 6-cyl. gasoline eng. 2.8 L/142kW V6 5V catalytic converter, MVEG 2 base engine is T7F M7G 6-cyl. gasoline eng. 2.6 L/110 kW V6 2V closed-loop catalytic converter base engine is T7G M7H 6-cyl. gasoline eng. 2.8 L/128 kW V6 2V closed-loop catalytic converter base engine is T7E M7J 5-cylinder diesel engine 2.4 L/57 kW base engine is T7A M7K 6-cyl. gasoline eng. 2.6 L/106 kW V6 2V base engine is T7G M7L 5-cylinder injection engine 2.3 L/85 kW 15.04 M7M 5-cylinder diesel engine 2.4 L/60 kW with load-controlled start of charging base engine is T7B M7N 8-cylinder gasoline engine 4.2 L/220 kW EGR, contr. cat, red. emission spec. accto Californian regu., base engine is T7J M7P 6-cylinder gasoline engine 2.4 L/66 kW carburetor 2E3 base engine is T7P M7Q 6-cylinder gasoline engine 2.4 L/69 kW closed-loop catalytic convert., DIGIFANTbase engine is T7Q M7R 8-cyl. gasoline engine 3.7 L/169 kW V8 Motronic, MVEG 2 base engine is T7L M7S 6-cyl. gasoline engine 2.8 L/128 kW VR6 Motronic, catalytic converter base engine is T6N M7T 6-cyl. gasoline eng. 2.8 L/128 kW V6 2V closed-loop cat w/ modified NOx values base engine is T7E M7U 6-cyl. gasoline engine 2.8 L/128 kW VR6 base engine is T6N M7V 8-cylinder gasoline engine 3.6 L/184 kW base engine is T7H M7W 8-cyl. gasoline engine 3.6 L/184 kW closed-loop catalytic converter base engine is T7H M7X 8-cylinder gasoline engine 4.2 L/206 kW base engine is T7J M7Y 8-cyl. gasoline engine 4.2 L/206 kW closed-loop catalytic converter base engine is T7J M7Z 8-cyl. gasoline engine 3.7 L/169 kW V8 Motronic, OBD 2 base engine is T7L M80 6-cylinder gasoline engine 2.8 L/128 kW MH-Motronic base engine is T7X M81 6-cylinder gasoline engine 2.6 L/110 kW LH-Motronic base engine is T7Y M82 6-cylinder gasoline engine 2.8 L/128 kW MH-motronic, closed-loop catalytic conv.base engine is T7X M83 6-cylinder gasoline engine 2.6 L/102 kW M84 5-cylinder diesel engine 2.4 L/55 kW cat, EGR, MVEG 2 (light comm. vehicle) base engine is T7A M85 4-cylinder gasoline engine 1.0 L/37 kW MVEG 2 base engine is T3M M86 8-cyl. gasoline engine 4.2 L/180 kW V8 appendix 23, Motronic, closed-loop cat base engine is T7W M87 4-cyl. diesel engine 1.9 L/47 kW SDI and MVEG 2 base engine is T8D M88 6-cyl. gasoline eng. 2.4 L/121 kW 30V V6with MVEG 2 base engine is T7T/T6R M89 6-cyl. turbo gasoline eng. 2.7 L/195 kW V6 30V base engine is T7Z M8A 5-cyl. turbo diesel engine 2.5 L/88 kW base engine is T4E M8B 8-cyl. gasoline eng. 4.2 L/228 kW V8 40Vcamshaft adjustm. w/o cyl. cutout, EU 3Dbase engine is T7S M8C 5-cylinder gasoline engine 2.3 L/98 kW electronic fuel injection, contr. cat base engine is T5V M8D 4-cylinder gasoline engine 2.0 L/85 kW EGR, MVEG 2 (mod. NOx values) contr. catbase engine is T4Y M8E 4-cylinder gasoline engine 2.0 L/85 kW DIGIFANT, w/ lead resistant lambda probebase engine is T4Y M8F 4-cylinder gasoline engine 1.6 L/55 kW keihin carburetor base engine is T2J M8G 8-cyl. gasoline eng. 4.2 L/265 kW V8 40Vcamshaft adjust. w/o cyl. cutout M8H 4-cylinder gasoline engine 1.8 L/55 kW base engine is T2K M8J 4-cylinder gasoline engine 1.8 L/55 kW open-loop catalytic converter base engine is T2K M8K 4-cylinder diesel engine 1.9 L/50 kW SDIwith MVEG 2 base engine is T0X M8L 4-cylinder gasoline engine 1.6 L/53 kW carburetor with modified distributor base engine is T2L M8M 4-cylinder gasoline engine 1.8 L/55 kW Monomotronic, cataly. conv. MVEG 2/EU 3Dbase engine is T5U M8N 4-cylinder diesel engine 1.9 L/55 kW w/ catalytic conv., turbocharger a. EGR base engine is T2N M8P 4-cylinder gasoline engine 1.6 L/74 kW BOSCH Motronic, appendix 15.04 M8Q 4-cylinder injection engine 2.0 L/88 kW BOSCH Motronic, appendix 15.04 M8R 4-cylinder gasoline engine 1.6 L/52 kW Monomotronic, closed-loop catalyt. conv.base engine is T5K M8S 4-cylinder gasoline engine 1.8 L/82 kW BOSCH Motronic, appendix 15.04 M8T 6-cylinder gasoline engine 2.9 L/135 kW with MVEG 2, catalytic converter base engine is T6Q M8U 4-cylinder gasoline engine 1.8 L/66 kW with activated charcoal canister base engine is T2B M8V 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T6V M8W 4-cylinder diesel engine 1.9 L/47 kW w/ cat, load-controlled start of charg. base engine is T2E M8X 4-cylinder gasoline engine 1.8 L/92 kW 15.04 with multi-point injection base engine is T6W M8Y 4-cylinder gasoline engine 1.8 L/92 kW with multi-point injection, MVEG 2 base engine is T6W M8Z 4-cylinder injection engine 1.8 L/88 kW ECE base engine is T5Z M90 4-cylinder diesel engine 1.9 L/55 kW with cat, turbocharger, EGR and MVEG 2 base engine is T2N M91 4-cylinder gasoline engine 1.6 L/74 kW with MVEG 2 base engine is T0C M92 4-cyl. gasoline engine 2.3 L/106 kW 16V MVEG 2, for FORD M93 4-cylinder gasoline engine 1.6 L/55 kW Monomotronic and MVEG 2 base engine is T5P M94 4-cyl. turbo diesel engine 4.3 L/103 kW M95 5-cylinder gasoline engine 2.5 L/81 kW appendix 15/04 base engine is T2Y M96 4-cylinder gasoline engine 2.0 L/79 kW Simos base engine is T8A M97 6-cyl. gasoline engine 2.8 L/120 kW V6 with multi-point injection base engine is T7X M98 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo base engine is T8B/T8C M99 in-line 4-cyl. gasoline eng. 2.0 L/85 kWdouble overhead camshaft, for FORD M9A 4-cyl. turbo diesel engine 1.6 L/51 kW according to Canadian regulations base engine is T6A M9B 4-cyl. turbo diesel engine 1.6 L/59 kW w/ intercooler acc. to Canadian regulat.base engine is T6G M9C 4-cylinder diesel engine 1.6 L/44 kW cat, turbocharger base engine is T6M M9D 4-cyl. gasoline engine 1.6 L/74 kW 20V appendix 15/04 base engine is T5D M9E 4-cyl. gasoline engine 2.0 L/85 kW 2V base engine is T4G M9F 5-cylinder gasoline engine 2.3 L/98 kW with electronic fuel injection base engine is T5V M9G 5-cyl. gasoline engine 2.2 L/169 kW 20V base engine is T3V M9H 6-cyl. gasoline eng. 2.8 L/128 kW V6 2V base engine is T7E M9J 4-cyl. gasoline engine 1.6 L/74 kW 20V appendix 15/04 base engine is T6X M9K 8-cyl. gasoline eng. 4.2 L/250 kW V8 40VEU 3D base engine is T7S M9L 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, MVEG 2 base engine is T8B/T8C M9M 5-cyl. diesel engine 2.5 L/75 kW TDI distr. inj. pump, turboch., interc., EGRbase engine is T7K/T8S M9N 4-cyl. diesel engine 1.9 L/47 kW w/ cat w/ MVEG 2 base engine is T2E M9P 6-cyl. turbo diesel engine 2.4 L/70 kW charge air cooler base engine is T7U M9Q 4-cylinder injection engine 1.0 L/51 kW M9R 6-cyl. gasoline eng. 2.8 L/128 kW V6 2V with catalytic converter and EGR base engine is T7E M9S 6-cylinder diesel engine 2.4 L/57 kW base engine is T7N M9T 6-cyl. turbo diesel engine 2.4 L/80 kW base engine is T7R M9U 6-cylinder diesel engine 2.4 L/51 kW base engine is T7N M9V 6-cyl. turbo diesel engine 2.4 L/68 kW base engine is T7R M9W 4-cyl. diesel engine 1.9 L/55 kW, cat turboch., EGR, load-contr. st. of charg.base engine is T2N M9X 4-cylinder gasoline engine 1.8 L/65 kW with closed-loop catalytic converter base engine is T1U M9Y 4-cyl. gasoline engine 1.8 L/92 kW 20V appendix 15/04 base engine is T0V M9Z 4-cyl. turbo diesel engine 1.9 L/66 kW TDI with central EGR extraction base engine is T2F MA1 5-cyl. turbo diesel engine 2.5 L/111 kW base engine is T8S MA2 5-cyl. turbo diesel engine 2.5 L/110 kW EU 3, pump-jet injection system base engine is T8T MA3 4-cyl. gasoline engine 1.8 L/92 kW 20V with multi-point injection and OBD 2 for base engine see supplement MA4 8-cyl. gasoline engine 4.2 L/213 kW V8 Motronic base engine is T7W MA5 3-cyl. gasoline engine 1.2 L/47 kW 12V base engine is T70 MA6 4-cyl. turbo diesel engine 1.7 L/66 kW TDI EU 3 base engine is T4X MA7 3-cyl. turbo diesel engine 1.2 L/45 kW TDI pump-jet injection system base engine is T4A MA8 4-cylinder gasoline engine 2.0 L/85 kW FORD, EU 3 MA9 4-cylinder gasoline engine 2.0 L/85 kW OBD 1 base engine is T3U MB0 6-cyl. gasoline eng. 2.8 L/150 kW 24V VR6, EU 3/4 base engine is T9S MB1 4-cylinder gasoline engine 1.3 L/43 kW carburetor base engine is T4S MB2 4-cyl. gasoline engine 2.3 L/103 kW 16V EU 4, for FORD MB3 4-cylinder gasoline engine 1.3 L/42 kW carburetor, with open-loop cat. conv. base engine is T4S MB4 4-cylinder gasoline engine 1.4 L/50 kW MVEG 2 base engine is T1X MB5 4-cyl. gasoline engine 1.4 L/55 kW 16V MVEG 2 base engine is T1Q MB6 4-cyl. gasoline engine 1.4 L/55 kW 16V with multi-point injection, EU 3D base engine is T1Q MB7 4-cyl. gasoline engine 1.4 L/51 kW 16V with multi-point injection, MVEG 2 base engine is T1Q MB8 4-cyl. gasoline engine 1.4 L/74 kW 16V EU 3D base engine is T1N MB9 4-cyl. diesel engine 1.7 L/42 kW SDI with MVEG 2 base engine is T1W MC0 6-cyl. gasoline eng. 2.8 L/150 kW 24V VR6 base engine is T9T MC1 4-cylinder gasoline engine 1.3 L/40 kW Monomotronic, closed-loop cat. converterbase engine is T4T MC2 4-cylinder gasoline engine 1.3 L/50 kW Monomotronic, cat. converter (open-loop)base engine is T4T MC3 4-cylinder gasoline engine 1.4 L/50 kW ECE base engine is T1X MC4 4-cyl. gasoline engine 1.8 L/92 kW 20V with TLEV base engine is T5Z MC5 4-cylinder gasoline engine 1.0 L/37 kW base engine is T4F MC6 4-cylinder gasoline engine 1.0 L/37 kW base engine is T4F MC7 4-cyl. gasoline engine 2.0 L/132 kW 20V turbo base engine is T66 MC8 8-cylinder TDI engine 3.3 L/165 kW 32V common rail base engine is T6L MC9 6-cyl. gasoline engine 2.8 L/140 kW 5V base engine is T7F MD0 4-cylinder diesel engine 1.9 L/47 kW fuel distributor injection pump, MVEG 2 base engine is T1A MD1 4-cyl. turbo diesel eng. 1.9 L/66 kW TDIbase engine is T0W/T0E MD2 4-cylinder gasoline engine 1.3 L/50 kW with multi-point injection, MVEG 2 base engine is T8G MD3 4-cylinder gasoline engine 1.3 L/40 kW with multi-point injection, MVEG 2 base engine is T8G MD4 4-cylinder gasoline engine 1.0 L/37 kW ECE base engine is T4F MD5 8-cyl. gasoline eng. V8 3.7 L/191 kW 40Vcamshaft adjustment w/o cylinder cutout base engine is T8X MD6 8-cyl. diesel engine 3.9 L/200 kW TDI pump-jet injection system base engine is T84 MD7 5-cyl. gasoline engine 2.3 L/110 kW VR5 appendix EU 3D base engine is T8R MD8 5-cyl. gasoline eng. 2.3 L/125 kW 20V VR5 base engine is T13/T8Y MD9 6-cyl. gasoline engine 2.4 L/115 kW 30V ECE base engine is T7T ME0 4-cyl. diesel engine 1.9 L/47 kW SDI fuel distributor injection pump base engine is T9V/T2Q/T0X/T96 ME1 6-cyl. gasoline engine 2.8 L/122 kW VR6 Motronic with EGR and SAP, MVEG 2 base engine is T2X ME2 4-cylinder gasoline engine 1.8 L/77 kW with multi-point injection and OBD 2 base engine is T6E ME3 4-cyl. gasoline engine 1.4 L/77 kW 16V fuel stratified injection base engine is T02 ME4 4-cyl. turbo diesel eng. 1.9 L/60 kW TDIwith MVEG 2 base engine is T0D ME5 4-cylinder gasoline engine 1.8 L/77 kW with multi-point injection and TLEV base engine is T6E ME6 4-cyl. gasoline engine 1.8 L/92 kW 16V with multi-point injection and LEV for base engine see supplement ME7 4-cyl. turbo diesel eng. 1.9 L/85 kW TDITLEV 1 with pump-jet injection system base engine is T4N ME8 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection, EU 3D base engine is T6H ME9 4-cyl. gasoline engine 1.8 L/92 kW 20V with multi-point injection base engine is T0V/T5Z/T64/T6W MF0 5-cylinder diesel engine 2.5 L/66 kW TDIwith fuel distributor injection pump base engine is T8Q MF1 4-cylinder gasoline engine 1.4 L/55 kW Motronic base engine is T0Y MF2 4-cyl. diesel engine 1.7 L/42 kW SDI MVEG 2 base engine is T2Z MF3 4-cylinder diesel engine 1.9 L/50 kW with MVEG 2 base engine is T8D MF4 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIMVEG 2 base engine is T8U MF5 4-cyl. turbo diesel eng. 1.9 L/55 kW TDIMVEG 2 base engine is T0T MF6 8-cyl. gasoline engine 4.0 L/220 kW 32V fuel-stratified injection, WR8 base engine is T89 MF7 4-cyl. turbo diesel eng. 1.9 L/66 kW TDIpump-jet injection system and EU 3 base engine is T1T MF8 6-cyl. turbo gas. eng. 2.7 L/169 kW 30V V6 turbo base engine is T7Z MF9 4-cylinder diesel engine 2.0 L/55 kW SDIpump-jet injection system base engine is T9M MG1 8-cyl. gasoline engine 4.2 L/250 kW V8 Motronic, MVEG 2 base engine is T8V MG2 6-cylinder gasoline engine 2.8 L/103 kW OBD 2 with BOSCH Motronic, EGR and SAP base engine is T2X MG3 8-cyl. gasoline engine 4.2 L/240 kW 32V with MVEG 2, catalytic converter base engine is T8W MG4 5-cylinder gasoline engine 2.3 L/110 kW appendix LEV base engine is T8R MG5 6-cyl. gasoline eng. 2.8 L/150kW VR6 24VBOSCH Motr., var. ind. pipe, EU 3/TLEV base engine is T0M MG6 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection, ECE base engine is T6U MG7 4-cylinder diesel engine 1.7 L/55 kW EU 3 base engine is T9J MG8 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, EU 4/D4/LEV base engine is T8C/T63 MG9 4-cylinder gasoline engine 1.3 L/50 kW keihin carburetor MH0 6-cyl. gasoline engine 2.7 L/187 kW 30V base engine is T7Z MH1 4-cylinder gasoline engine 1.4 L/44 kW multi-point injection, MVEG 1 base engine is T3L MH2 4-cyl. gasoline engine 1.8 L/115 kW 20V base engine is T0Y MH3 4-cyl. gasoline engine 1.8 L/154 kW 20V US 83 base engine is T6B MH4 4-cylinder gasoline engine 1.0 L/37 kW with multi-point injection base engine is T8F MH5 4-cyl. gasoline engine 1.4 L/44 kW multi-point injection base engine is T8H/T1X MH7 4-cylinder gasoline engine 1.6 L/55 kW appendix 15/04 base engine is T3N MH8 4-cylinder gasoline engine 1.0 L/40 kW base engine is T8F MH9 4-cyl. turbo diesel eng. 1.9 L/55 kW TDIEU 3 (pump-jet injection system) base engine is T1T MJ0 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIEU 3D base engine is T8U MJ1 4-cylinder gasoline engine 1.6 L/74 kW base engine is T6H MJ2 4-cylinder gasoline engine 1.8 L/71 kW with closed-loop catalytic converter base engine is T1U MJ3 4-cylinder gasoline engine 1.6 L/57 kW with closed-loop catalytic converter base engine is T1V MJ4 4-cylinder gasoline engine 2.0 L/88 kW base engine is T10/T11/T12/T51 MJ5 6-cyl. gasoline engine 2.8 L/130 kW VR6 w/ MPI induction pipe, app. 15/04 base engine is T2R MJ6 5-cyl. turbo diesel eng. 2.5 L/75 kW TDIEU 2 base engine is T8Q MJ7 4-cylinder gasoline engine 1.8 L/74 kW BOSCH Motronic base engine is T6K/TG2 MJ8 4-cyl. gasoline engine 1.8 L/132 kW 20V turbo, MVEG 2 base engine is T8B/T8C MJ9 6-cyl. gasoline engine 2.8 L/142 kW V6 with LEV base engine is T6J MK0 4-cylinder gasoline engine 2.0 L/88 kW EU 4 base engine is T10 MK1 4-cyl. turbo gas. eng. 1.8 L/154 kW 20V appendix EU 3 base engine is T6B MK2 6-cylinder gasoline engine 2.8 L/130 kW with MPI, variable induction pipe, EU 3 base engine is T2R MK3 3-cylinder gasoline engine 1.2 L/37 kW base engine is T73 MK4 5-cylinder gasoline engine 2.5 L/85 kW EU 3 base engine is T6Z MK5 6-cyl. gasoline engine 2.7 L/184 kW 30V base engine is T7Z MK6 4-cylinder gasoline engine 2.0 L/85 kW base engine is T04/T10/T11/T51 MK7 4-cyl. gasoline engine 1.0 L/48 kW E 22, with multi-point injection base engine is T92/T97 MK8 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, ULEV for base engine see supplement MK9 4-cylinder gasoline engine 1.8 L/66 kW appendix 23 base engine is T1F ML0 4-cyl. gasoline engine 1.6 L/81 kW 16V fuel-stratified injection base engine is T94 ML1 4-cylinder gasoline engine 2.0 L/85 kW multi-point injection, EU 4/D4 base engine is T6Y ML2 4-cylinder gasoline engine 2.0 L/85 kW BOSCH Motronic a. emissi. concept TIER 1base engine is T6Y ML3 4-cylinder gasoline engine 2.0 L/85 kW BOSCH Motronic a. emissions concept TLEVbase engine is T6Y ML4 4-cylinder gasoline engine 2.0 L/85 kW BOSCH Motronic a. emissions concept LEV base engine is T3U/T6Y ML5 4-cylinder gasoline engine 2.0 L/85 kW multi-point injection, LEV/ULEV base engine is T52 ML6 4-cyl. gasoline engine 1.0 L/56 kW 16V E 22, with multi-point injection base engine is T93 ML7 6-cyl. gasoline engine 2.4 L/121 kW V6 EU 4 base engine is T1Z ML8 4-cylinder gasoline engine 2.0 L/85 kW multi-point injection, TIER 1 (Latino) base engine is:T6Y ML9 4-cylinder gasoline engine 1.8 L/92 kW multi-point injection, EU 4 base engine is T6W MM0 name hitherto unknown MM1 5-cyl. turbo diesel eng. 2.5 L/136 kW 20V TDI, pump-jet injection system base engine is T62 MM2 3-cylinder gasoline engine 1.2 L/40 kW base engine is T73 MM3 5-cyl. turbo diesel engine 2.5 L/96 kW pump-jet injection system base engine is T85 MM4 3-cylinder gasoline engine 1.2 L/44 kW base engine is T73 MM5 4-cyl. gasoline engine 1.6 L/78 kW 20V base engine is T54 MM6 4-cyl. gasoline engine 1.6 L/88 kW 16V with multi-point injection, EU 3D base engine is T1Y MM7 4-cylinder gasoline engine 1.4 L/40 kW multi-point injection, MVEG 2 base engine is T4M MM8 4-cyl. gasoline engine 1.6 L/85 kW 16V fuel-stratified injection base engine is T72 MM9 3-cyl. turbo diesel eng. 1.5 L/74 kW 12Vpump-jet injection system base engine is T98 MN0 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIEU 3 base engine is T8U MN1 6-cyl. gasoline engine 2.8 L/128 kW VR6 EU 3 base engine is T1C MN2 6-cyl. diesel eng. 3.0 L/165 kW TDI 24V pump-jet inj. system, biturbo, base engine is T65/T78 MN3 6-cyl. gasoline engine 2.4 L/120 kW V6 with MVEG 2 base engine is T7T MN5 8-cyl. gasoline engine 4.2 L/255 kW 32V fuel-stratified injection base engine is T8T MN7 4-cyl. gasoline engine 1.4 L/55 kW 16V multi-point injection base engine is T1Q/T99/TK0 MN8 8-cyl. gasoline eng. 4.2 L/250 kW V8 40VMotronic, EU 3/TLEV base engine is T7S MN9 4-cyl. diesel engine 1.7 L/44 kW SDI fuel distributor injection pump, EU 3D base engine is T2Z MP0 4-cyl. gasoline engine 1.4 L/74 kW 16V base engine is T1N MP2 5-cylinder diesel engine 2.5 L/65 kW TDIbase engine is T7K MP3 8-cyl. gasoline engine 4.2 L/250 kW V8 Motronic, EU 3 (provisional solution) base engine is T8V MP4 8-cyl. gasoline engine 4.2 L/220 kW V8 Motronic, EU 3 (provisional solution) base engine is T7W MP5 8-cyl. gasoline engine 3.7 L/169 kW V8 Motronic, EU 3 (provisional solution) base engine is T7L MP6 4-cylinder gasoline engine 1.4 L/54 kW carburetor MP7 6-cyl. gasoline engine 2.4 L/100 kW 30V appendix EU 3, provisional solution base engine is T7T MP8 5-cyl. diesel engine 2.5 L/80 kW TDI with fuel distributor injection pump base engine is T8Q MP9 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection base engine is T6H/T69 MQ0 8-cyl. gasoline engine 4.2 L/220 kW 40V multi-point injection base engine is T79 MQ2 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, EU 4 base engine is T8M MQ4 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, EU 3D base engine is T8C MQ5 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection and D4 base engine is T6U MQ6 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, D4 base engine is T8B MQ7 4-cyl. gasoline engine 1.8 L/132 kW 20V turbo base engine is T8C/T16 MQ8 4-cyl. gasoline engine 1.8 L/92 kW 20V EU 3D base engine is T0V MQ9 4-cyl. turbo diesel engine 1.9 L/66 kW direct injection, EU 3D base engine is T0E MR0 6-cyl. gasoline eng. 2.8 L/147 kW 24V VR6 LEV base engine is T9T MR1 6-cyl. diesel engine 2.5 L/132 kW 24V TDI with fuel distributor injection pumpbase engine is T1K/T5T MR2 6-cyl. diesel engine 2.5 L/110 kW TDI EU 3 base engine is T6T MR3 4-cyl. gasoline engine 2.0 L/85 kW EU 3D base engine is T8A MR4 4-cyl. gasoline engine 2.0 L/85 kW with AGW base engine is T1Y MR5 4-cyl. diesel engine 1.7 L/44 kW SDI fuel distributor injection pump base engine is T1W MR6 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, ECE base engine is T8B MR7 6-cyl. diesel engine 2.5 L/110 kW 24V TDI common rail base engine is T40 MR9 6-cyl. diesel engine 2.5 L/132 kW 24V TDI common rail, EU 3 base engine is T40 MS0 5-cyl. diesel engine 2.5 L/128 kW pump-jet injection system base engine is T9L/T03/T86/TB7/TG7 MS2 4-cylinder gasoline engine 1.4 L/50 kW multi-point injection base engine is T1X MS3 4-cyl. gasoline engine 1.8 L/132 kW 20V turbo base engine is T8C MS4 4-cyl. turbo gasoline eng. 1.8 L/165 kW base engine is T6B MS5 8-cyl. gasoline eng. V8 4.2 L/228 kW 40Vcamshaft adjustment w/o cylinder cutout base engine is T7S/T81/T88 MS6 4-cyl. turbo gasoline eng. 1.8 L/165 kW multi-point injection, EU 3 base engine is T6B MS7 4-cyl. turbo diesel eng. 1.9 L/74 kW TDIpump-jet injection system base engine is T5X/T21/T71 MS8 4-cyl. turbo diesel eng. 1.9 L/92 kW TDIwith pump-jet injection system base engine is T9G MS9 4-cyl. turbo diesel 2.0 L/100 kW 16V TDIwith pump-jet injection system base engine is T9G/TB3 MT0 5-cyl. gasoline eng. 2.3 L/125 kW 20V VR5 base engine is T0D MT1 6-cyl. gasoline engine 2.8 L/142 kW 30V base engine is T7F MT2 6-cyl. gasoline engine 2.4 L/121 kW 30V base engine is T7T MT3 6-cyl. gasoline engine 2.4 L/120 kW 30V base engine is T7T MT4 6-cyl. gasoline engine 2.8 L/142 kW V6 5-valve with EU 3 (provisional solution)base engine is T7F MT5 6-cyl. gasoline engine 2.4 L/121 kW V6 EU 3 (provisional solution) base engine is T7T MT7 6-cyl. gasoline engine 2.4 L/121 kW 30V ECE base engine is T7T MT8 8-cyl. gasoline eng. 3.7 L/206kW WR8 32Vmulti-point injection, EU 3 base engine is T9H MT9 8-cyl. gasoline engine 3.7 L/220 kW 32V multi-point injection, WR8, LEV base engine is T9H MU0 4-cylinder gasoline engine 2.0 L/85 kW multi-point injection, MVEG 2 base engine is T6Y MU1 4-cylinder gasoline engine 1.4 L/44 kW multi-point injection, MVEG 2 base engine is T1X MU2 4-cylinder gasoline engine 1.0 L/37 kW with multi-point injection, EU 3D base engine is T3M MU3 4-cylinder gasoline engine 1.6 L/55 kW with multi-point injection, EU 3D base engine is T3N MU4 4-cylinder gasoline engine 1.4 L/44 kW with multi-point injection and MVEG 2 base engine is T8H MU5 4-cylinder gasoline engine 1.0 L/37 kW with multi-point injection and MVEG 2 base engine is T8F MU6 5-cylinder diesel engine 2.5 L/61 kW TDIwith fuel distributor injection pump base engine is T8Q MU7 4-cyl. gasoline engine 1.6 L/92 kW 16V with multi-point injection base engine is T1Y MU8 4-cylinder gasoline engine 1.0 L/37 kW with multi-point injection, EU 4 base engine is T9R MU9 5-cylinder diesel engine 2.5 L/70 kW TDIwith fuel distributor injection pump base engine is T8Q MV0 4-cyl. gasoline engine 1.8 L/132 kW 20V turbo, EU 3D base engine is T8C MV2 4-cylinder gasoline engine 1.0 L/42 kW with multi-point injection base engine is T9P MV4 4-cyl. gasoline engine 1.0 L/51 kW 16V multi-point injection, EU 2 base engine is T9Q MV6 4-cylinder gasoline engine 1.4 L/40 kW multi-point injection, EU 4 base engine is T8H MV7 4-cylinder gasoline engine 1.4 L/44 kW multi-point injection, ECE base engine is T8H MV8 4-cylinder gasoline engine 1.4 L/44 kW with multi-point injection, EU 3D base engine is T3L MV9 4-cylinder gasoline engine 1.6 L/74 kW EU 3D base engine is T0C MW0 4-cylinder gasoline engine 1.0 L/40 kW multi-point injection and EU 4 base engine is T8F MW1 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection, EU 4 base engine is T0B MW2 4-cyl. gasoline engine 2.0 L/96 kW 20V with multi-point injection, EU 4 base engine is T0F MW3 4-cylinder gasoline engine 1.0 L/45 kW US 83 base engine is T9P MW4 12-cyl. gasoline engine 6.0 L/309 kW 48VWR 12, Motronic base engine is T08/T1H MW5 8-cyl. gasoline engine 4.3 L/228 kW 32V WR8 base engine is T83 MW6 4-cylinder gasoline engine 1.6 L/75 kW with multi-point injection base engine is T0B/T53/TC3 MW7 4-cyl. gasoline engine 2.0 L/100 kW 16V fuel-stratified injection, EU 4 base engine is T17 MW8 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo base engine is T0L/T16/T6V/T63 MW9 4-cyl. gasoline engine 1.8 L/125 kW 20V turbo base engine is T6V/T0L MX0 electric motor 22kW base engine is T9Z MX1 4-cyl. gasoline engine 1.8 L/158 kW 20V with multi-point injection, EU 4 base engine is T0K MX2 6-cyl. gasoline engine 2.7 L/257 kW V6 base engine is T0R MX4 6-cyl. gasoline engine 2.8 L/147 kW V6 EU 4 base engine is T6J MX5 6-cyl. gasoline engine 2.4 L/125 kW V6 EU 4 base engine is T1Z MX6 6-cyl. gasoline engine 2.7 L/184 kW V6 EU 4 base engine is T0R MX7 6-cyl. gasoline engine 2.8 L/147 kW V6 emissions concept LEV base engine is T6J MX8 8-cyl. gasoline engine 4.0 L/215 kW 32V WR8 base engine is T9H MX9 6-cyl. gasoline engine 2.8 L/128 kW VR6 with multi-point injection, EU 3D base engine is T6N MY0 4-cylinder gasoline engine 1.6 L/74 kW multi-point injection base engine is T1J/T23/TC0 MY1 4-cylinder gasoline engine 1.6 L/57 kW MPI with closed-loop catalytic converterbase engine is T1V MY2 3-cyl. gasoline engine 1.2 L/40 kW 12V base engine is T70 MY3 4-cyl. diesel engine 1.9 L/47 kW 16V SDIfuel distributor injection pump base engine is T96 MY4 4-cylinder gasoline engine 1.6 L/69 kW MPI with closed-loop catalytic converterbase engine is T1V MY5 4-cylinder gasoline engine 1.8 L/83 kW MPI with closed-loop catalytic converterbase engine is T1U MY6 4-cylinder gasoline engine 1.8 L/71 kW MPI with closed-loop catalytic converterbase engine is T1U MY7 6-cyl. gasoline eng. 3.2 L/173 kW 24V VR6 base engine is T9N MY8 10-cyl. gasoline eng. 5.0 L/368 kW 40V V10 base engine is T77 MY9 4-cyl. gasoline engine 1.0 L/58 kW 16V E 22, with multi-point injection base engine is T9A MZ0 in-line 4-cyl. gas. eng. 2.3 L/105 kW MVEG 2, (bought from MERCEDES BENZ, M111E23 type), base engine is T9X MZ1 in-line 4-cyl. diesel eng. 2.8 L/96 kW 12V TDI, EURO 2 (bought from MWM, TCA 4.07 type), base engine is T9Y MZ2 in-line 4-cyl. dies. eng. 2.8 L/116 kW TDI 12V (bought from MWM, TCA 4.07 type)base engine is T9Y MZ3 5-cylinder gasoline engine 2.6 L/100 kW appendix 15/04 MZ4 4-cylinder gasoline engine 1.8 L/82 kW MZ5 4-cylinder gasoline engine 1.6 L/55 kW keihin carburetor MZ6 4-cylinder gasoline engine 1.3 L/44 kW MZ7 4-cylinder gasoline engine 1.8 L/70 kW MZ8 12-cyl. gasoline engine 6.0 L/412 kW 48VWR 12, biturbo base engine is T46 Edytowane 25 Listopada 2008 przez Kuczi Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
GURAL Zgłoś #142 Napisano 25 Listopada 2008 MS7 4-cyl. turbo diesel eng Próbowałem wszystkie podobne znaki do L, ale za każdym razem wychodziło mi całkiem co innego niż w podpisie sebasaw1. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Gość Krawcol Zgłoś #143 Napisano 25 Listopada 2008 M3L 4-cyl. turbo diesel engine 1.9 L/85 kW TDI with pump-jet injection system base engine is T4N/TD0 I to wlasnie chyba bedzie to "msl" Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
GURAL Zgłoś #144 Napisano 25 Listopada 2008 M3L 4-cyl. turbo diesel engine 1.9 L/85 kW TDI with pump-jet injection system base engine is T4N/TD0 A może to, najbardziej pasuje do kodu, i opisu z profilu EDIT // Krawcol mnie wyprzedził Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Kuczi Zgłoś #145 Napisano 25 Listopada 2008 A może to, najbardziej pasuje do kodu, i opisu z profilu sam swojej wlepce się przyglądałem przez kilka minut i co się okazało ?? Jeden kod był z błędem Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Server Zgłoś #146 Napisano 28 Listopada 2008 witam, Właśnie zakupiłam Passata, czy może mi ktoś pomóc go rozkodować bo mam problem z niektórymi skrótami, np : MW8, H6S, GA. Mam jeszcze pytanie: czy możliwe jest aby pask rozrządu był wymieniany dopiero po 180.000 km? pozdrawiam Server Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
GURAL Zgłoś #147 Napisano 28 Listopada 2008 Proszę. MW8 4-CYLINDROWY SILNIK Z WTRYSKIEM PALIWA 1,8 L H6S OPONY 195/65 R 15 V GA tapicerka w kolorze czarnym (tkanina) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
VWLupus Zgłoś #148 Napisano 2 Grudnia 2008 a wie moze ktos,co oznacza takie cos "interior lc7u"??bo nigdzie nie moge wyszukac jest to kod lakieru według org. kat. VW Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
GURAL Zgłoś #149 Napisano 3 Grudnia 2008 (edytowane) lc7u A to nie jest przypadkiem LC7V bo innego kodu nie ma. VOLKSWAGEN-AUDI BLUE ANTHRAZIT PEARL LC7V 1997 METALLIC Edytowane 3 Grudnia 2008 przez GURAL Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Gość pioteer Zgłoś #150 Napisano 5 Grudnia 2008 Witam.Muszę wymienić skrzynię biegów,jest to automat 4-ro biegowy(1,8 92kw 20v).Na wlepce jest oznaczenie DMU LB6G.Co oznacza skrót LB6G.Czy skrzynia z oznaczeniem DMU 04098 FM0714L będzie pasować? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Kuczi Zgłoś #151 Napisano 5 Grudnia 2008 Co oznacza skrót LB6G Jest to kolor lakieru Na wlepce jest oznaczenie DMU Czy skrzynia z oznaczeniem DMU 04098 FM0714L będzie pasować? Sam sobie odpowiedziałes. DMU to kod skrzyni a 04098 to numer Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
doktor80 Zgłoś #152 Napisano 29 Grudnia 2008 (edytowane) Dobra panowie. Napiszę tu aby mieć pewność. Nie mogę znaleźć oznaczeń ile mam poduszek powietrznych i czy wogóle je mam. Pisałem na B6 forum bo tam był wątek ale zapytam się jeszcze tu. Ni cholery na wlepie nie widzę żadnego kodu związanego z airbegami. Przy czytaniu opisu kodów na forum znalazłem coś o poduszkach bocznych w siedzeniach i mają kod, który zaczyna się chyba 4X cos tam. Ja w swojej lepie nie mam takiego czegoś. W aucie mam napis na kierownicy, obok na desce(pasażer) i boczki w fotelach. Nie wiem na ile te wszystkie oznaczenia odpowiadają rzeczywistości ale znalazłem kod na tempomat, ja mam u siebie tempomat ale takiego kodu na niego nie mam na wlepie. Edytowane 29 Grudnia 2008 przez doktor80 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
GURAL Zgłoś #153 Napisano 29 Grudnia 2008 Nie mogę znaleźć oznaczeń ile mam poduszek powietrznych i czy wogóle je mam. Jak masz paska B5 tak jak w opisie to pewnie masz 4-ry poduszki, a oznaczenia na wlepie wcale nie musisz mieć. Ja mam tak jak u Ciebie 4-ry poduchy, a żadnego oznaczenia na wlepie. Nie przejmuj się tym zbytnio, że nie masz oznaczenia, czasem potrafią też błędnie wybić kod którego nie ma . Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Gość andrzej71 Zgłoś #154 Napisano 5 Stycznia 2009 Potrzebuję pomocy w oznaczeniach wlepki: EYZ LC9Z JJ EU3 5G ATJ, T4N i QG2. Resztę kodów znalazłem na pierwszej stronie, a tych nie mogę znaleźć. Myślę, że dobrze odczytałem te kody z naklejki. Z góry dzięki Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
gryson Zgłoś #155 Napisano 5 Stycznia 2009 Poszukaj tutaj, ale coś mi się wydaje, że nie dokładnie spisałeś podane tutaj kody, spisz je jeszcze raz. http://forum.vw-passat.pl/showthread.php?p=415733#post415733 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
GURAL Zgłoś #156 Napisano 5 Stycznia 2009 (edytowane) Proszę. T4N - SILNIK 4-CYLINDROWY WYSOKOPRĘŻNY TURBO 1,9 L QG2 - PRZEDŁUŻENIE OKRESU PRZEGLĄDU NIE DAJE SIĘ UAKTYWN. LC9Z - BLACKMAGIC-PEARL EFFECT JJ - CZARNA SKÓRA WERSJA SPORT EYZ - KOD LITEROWY SKRZYNI BIEGÓW ATJ - KOD LITEROWY SILNIKA 5G - SKRZYNIA 5 BIEGÓW MANUALNA EU3- oznacza normę zużycia paliwa, ale nie pamiętam o co tam chodzi tak do końca. Edytowane 5 Stycznia 2009 przez GURAL Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
killerek Zgłoś #157 Napisano 29 Stycznia 2009 Witam prosiłbym o rozszyfrowanie jednego kodu jest to OAO lub 0A0.Bardzo bym prosił szukałem ale nie znalazłem,resztę znalazłem .Z góry za pomoc dziękuje Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
baxior Zgłoś #158 Napisano 22 Lutego 2009 (edytowane) Witam, mam pytanie jaki to kolor? LD5Q, no i jeszcze kody, bo nie mogę znależć, albo źle spisałem: FRK, YS-może tapiserka? z góry dzieki PZDR ---------- Post added at 17:44 ---------- Previous post was at 17:37 --------- Edytowane 22 Lutego 2009 przez baxior Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
JurekW Zgłoś #159 Napisano 22 Lutego 2009 Witam, mam pytanie jaki to kolor? LD5Q, no i jeszcze kody, bo nie mogę znależć, albo źle spisałem: FRK, YS-może tapiserka? z góry dzieki PZDR ---------- Post added at 17:44 ---------- Previous post was at 17:37 --------- Shadow Blue Clearcoat LD5Q/P6 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
GURAL Zgłoś #160 Napisano 22 Lutego 2009 FRK Skrzynia biegów manualna 6-cio biegowa YS A może XS Beż słoneczny ? YS nie znalazłem. Oczywiście jest to kolor tapicerki- siedzenia sportowe Recaro. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
