marcin9962 Zgłoś #1 Napisano 15 Listopada 2011 witam, dziś mi przyszedł kabelek i znalazło mi masę błędów, czy można było by je zidentyfikować ? VCDS Version: Beta 11.2.0 Data version: 20110305 Tuesday,15,November,2011,11:11:08:10074 Chassis Type: 3C0 Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 VIN: WVWZZZ3CZ7E156956 Mileage: 116940km/72663miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Cannot be reached 1100 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 03G 906 018 CE HW: 03G 906 018 CE Component: R4 2.0l PPD1.5 G 9707 Revision: --H45--- Serial number: VWZCZ000000000 Coding: 0000072 Shop #: WSC 05314 000 00000 VCID: 6ADFC69B3EBF No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl Part No SW: 3C0 614 109 HW: 3C0 614 109 Component: ESP 440 C4 H018 0001 Revision: H018 Serial number: 0668315914 Coding: 0013602 Shop #: WSC 05311 000 00000 VCID: DBB1135F61E5 1 Fault Found: 00650 - Clutch Pedal Switch (F36) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 202 Mileage: 116579 km Time Indication: 0 Date: 2000.00.00 Time: 10:48:15 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-820-047.lbl Part No: 1K0 820 047 GK Component: Climatic PQ35 120 0606 Shop #: WSC 00000 000 00000 VCID: 73E1DBFF6975 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE Component: Bordnetz-SG H52 2002 Revision: 00H52000 Serial number: 00000006477714 Coding: 01880F0700041A00470A00000F00000000085D435C0001 Shop #: WSC 05311 000 00000 VCID: 6CD3C083344B Subsystem 1 - Part No: 3C2 955 119 B Component: Wischer 121206 022 0601 Coding: 00046997 Shop #: WSC 05311 9 Faults Found: 01064 - Terminal 58d; Interior Dimming 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 4 Fault Frequency: 254 Reset counter: 200 Mileage: 115582 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 12.25 V ON ON OFF OFF OFF 02399 - Control Circuit for Terminal 30 for Interior Illumination 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00111001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 207 Mileage: 116615 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: OFF Voltage: 12.50 V OFF ON OFF OFF OFF 01800 - Light Switch (E1) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 207 Mileage: 116615 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: OFF Voltage: 12.50 V OFF ON OFF OFF OFF 01495 - Bulb for High-Beams; Left (M30) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 223 Mileage: 116814 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 12.10 V ON ON OFF OFF OFF 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 2 Reset counter: 223 Mileage: 116814 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 11.60 V ON ON OFF OFF OFF 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 223 Mileage: 116814 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 11.75 V ON ON OFF OFF OFF 00059 - Terminal 30 for Interior Lighting 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 5 Fault Frequency: 5 Reset counter: 207 Mileage: 116059 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: OFF Voltage: 12.30 V OFF OFF OFF OFF OFF 00978 - Lamp for Low Beam; Left (M29) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00110111 Fault Priority: 1 Fault Frequency: 3 Reset counter: 223 Mileage: 116814 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 11.80 V ON ON OFF OFF OFF 00979 - Lamp for Low Beam; Right (M31) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00110111 Fault Priority: 1 Fault Frequency: 1 Reset counter: 223 Mileage: 116814 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 11.55 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 3C0-909-605.lbl Part No SW: 3C0 909 605 N HW: 3C0 909 605 N Component: 1A AIRBAG VW8R 031 2522 Revision: 12031000 Serial number: 003B2PQ7BMJ/ Coding: 0012609 Shop #: WSC 05311 000 00000 VCID: 316D11F7D3E9 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl Part No SW: 3C0 953 549 L HW: 3C0 953 549 L Component: Lenksäulenmodul 006 0010 Revision: 00006000 Serial number: 3C9953507AH Coding: 0000014 Shop #: WSC 05311 000 00000 VCID: 356525E72781 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3C0-920-xxx-17.lbl Part No SW: 3C0 920 960 K HW: 3C0 920 960 K Component: KOMBIINSTRUMENT VD1 1614 Revision: V0007000 Serial number: 00000000000000 Coding: 0007405 Shop #: WSC 00151 210 56405 VCID: 2B51039FF1C5 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530.lbl Part No SW: 3C0 907 530 C HW: 3C0 907 951 A Component: Gateway 007 0040 Revision: 00007000 Serial number: 0700C06C18008C Coding: 3DFD0C04C22003 Shop #: WSC 05311 000 00000 VCID: 214DE1B78309 2 Faults Found: 01305 - Databus for Infotainment 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 1 Fault Frequency: 1 Reset counter: 76 Mileage: 115939 km Time Indication: 0 Date: 2000.00.00 Time: 18:20:32 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 254 Reset counter: 200 Mileage: 115394 km Time Indication: 0 Date: 2000.00.00 Time: 09:25:21 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 R HW: 3C0 959 433 R Component: IMMO 042 0383 Revision: 00042000 Serial number: VWZCZ000000000 Shop #: WSC 00151 210 91034 VCID: 397D29D70B99 Part No: 3C0 905 861 G Component: ELV 027 0380 3C0905861G ELV 027 0380 1 Fault Found: 01176 - Key 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 187 Mileage: 65581 km Time Indication: 0 Date: 2000.00.00 Time: 10:28:16 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1K0 959 701 P HW: 1K0 959 793 L Component: J386 TUER-SG FT 1132 Revision: 32008001 Serial number: 00000583669210 Coding: 0000693 Shop #: WSC 05311 000 00000 VCID: 3B7133DF01A5 1 Fault Found: 01811 - Supply Voltage for Door Controller; Drivers Side (J386) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 1 Reset counter: 201 Mileage: 116562 km Time Indication: 0 ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K2 909 144 L Component: EPS_ZFLS Kl.135 H07 1806 Shop #: WSC 02069 000 90108 VCID: 356525E72781 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 R HW: 3C0 959 433 R Component: KSG PQ46 ELV 042 0472 Revision: 00042000 Serial number: VWZCZ000000000 Coding: 0191020051030E763004941570085FCE107CA0 Shop #: WSC 00151 210 91034 VCID: 397D29D70B99 Part No: 1K0 951 605 D Component: LIN BACKUP HORN H07 8003 Part No: 3C0 951 171 A Component: Neigungssensor 002 0508 Part No: 3C0 951 171 A Component: Innenraumueberw.002 0508 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl Part No SW: 1K0 959 702 P HW: 1K0 959 792 L Component: J387 TUER-SG BT 1132 Revision: 32008001 Serial number: 00000037569210 Coding: 0000692 Shop #: WSC 05311 000 00000 VCID: 3C7330C304AB No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3C0-907-801-53.lbl Part No SW: 3C0 907 801 E HW: 3C0 907 801 E Component: EPB VC8HC003 013 0003 Revision: 013 Coding: 0000011 Shop #: WSC 05311 000 00000 VCID: 2443E8A39C1B No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 1K0 959 703 P HW: 1K0 959 795 G Component: J388 TUER-SG HL 1119 Revision: 11006001 Serial number: 00000001096512 Coding: 0000144 Shop #: WSC 05311 000 00000 VCID: 3D753DC71FB1 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 1K0 959 704 P HW: 1K0 959 794 G Component: J389 TUER-SG HR 1119 Revision: 11006001 Serial number: 00000001108106 Coding: 0000144 Shop #: WSC 05311 000 00000 VCID: 3E773ACB12B7 No fault code found. End --------------------------------------------------------------------- Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Gość goszki Zgłoś #2 Napisano 15 Listopada 2011 Witam! Czy ktoś mógłby mi powiedzieć co to za błąd 145D . Jest on z modułu silnika. Błąd wywala tylko podczas uruchamiania silnika ( za każdym razem jak odpalam auto ) Po skasowaniu błędu po uruchomieniu auta wywala go od razu. Dodam że jeszcze świeci się kontrolka CHECK ENGINE która po wykasowaniu błędu gaśnie, aż do momentu gdy 2 razy odpalę auto bo łapie 2 błędy i się zapala z powrotem. Dodam że auto jest po malutkiej awarii (padł czujnik temperatury spalin przed turbosprężarką, który został wymieniony na nowy i jest ok) i w tym samym czasie wyskoczył ten błąd. Pozdrawiam i z góry dzięki za pomoc! Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
david1881 Zgłoś #3 Napisano 19 Listopada 2011 (edytowane) witam, dziś mi przyszedł kabelek i znalazło mi masę błędów, czy można było by je zidentyfikować ? Błąd 00650 - TUTAJ Błąd 01064 - TUTAJ Błąd 01800 - sprawdź włącznik światła i jego okablowanie Błąd 01495 - Sprawdź lampę świateł długich lewych, okablowanie do tych świateł i kodowanie modułu sterowania Błąd 00978 - Sprawdź lampę świateł mijania lewych, okablowanie do tych świateł i kodowanie modułu sterowania Błąd 00979 - Sprawdź lampę świateł mijania prawych, okablowanie do tych świateł i kodowanie modułu sterowania Błąd 00059 - błąd obwodu oświetlenia wnętrza, sprawdź bezpiecznik Błąd 01305 i 01304 - TUTAJ Błąd 01176 - TUTAJ Błąd 01811 - Napięcie zasilania dla kontrolera drzwi, po stronie kierowcy (J386) Edytowane 19 Listopada 2011 przez david1881 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
MICHAS Zgłoś #4 Napisano 23 Listopada 2011 Witam serdecznie szukam info na temat nastepujacych bledow (wentylator chlodnicy): 006470 - Control Module 1 for Coolant Fan: Defective 001681 - Fan 1 Control Circuit: Short to GND Dzieki serdeczne Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
verdi70 Zgłoś #5 Napisano 24 Listopada 2011 Witam Zapaliła mi się kontrolka błedu układu odprowadzania spalin, po podpięciu pod komp wyskoczyły błędy: 05213 P145D Exhaust gas temperature sensor Circuit High Sensor3 09259 P242B Exhaust Gas Temperature Sensor 3 Circuit -Blank1: Range Performance Może mi ktoś wytłumaczyć co to za błędy? Z góry dziękuję. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
VWonline.pl Zgłoś #6 Napisano 24 Listopada 2011 05213 P145D 09259 P242B Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
huragan1971 Zgłoś #7 Napisano 24 Listopada 2011 Panowie....dziś zrobiłem test swojego Passata VCDS-em...wyskoczyło mi sporo błędów i powoli je eliminuję jednak mam kilka jeszcze niewyjaśnionych... Chassis Type: 3C0 Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76 7D VIN: XXXXXXXXXXXXXXXXX Mileage: 112330km/69798miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Cannot be reached 1100 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 7D-Aux. Heat -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKC.lbl Part No SW: 03G 906 021 LR HW: 03G 906 021 AN Component: R4 1,9L EDC G000SG 9248 Revision: --H05--- Serial number: XXXXXXXXXXXXXX Coding: 0000071 Shop #: WSC 00191 264 15243 VCID: 7AF0F0B60A854FCC No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl Part No SW: 3C0 614 095 P HW: 3C0 614 095 P Component: ESP 440 C2 H015 0004 Revision: H015 Serial number: 0940046247 Coding: 0013569 Shop #: WSC 05311 000 00000 VCID: 2F6611E281475A64 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3C0-907-044.lbl Part No SW: 3C0 907 044 AJ HW: 3C0 907 044 AJ Component: ClimatronicPQ46 050 0505 Revision: 00050005 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 69D2BFFA7F23F454 4 Faults Found 00229 - Refrigerant Pressure 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01110010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 126 Mileage: 112335 km Time Indication: 0 Date: 2000.00.00 Time: 14:41:39 00756 - Left Vent Temp Sensor (G150) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01111010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 126 Mileage: 112335 km Time Indication: 0 Date: 2000.00.00 Time: 14:41:39 00797 - Sunlight Photo Sensor (G107) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 126 Mileage: 112335 km Time Indication: 0 Date: 2000.00.00 Time: 14:41:39 00709 - Sunlight Photosensor 2 (G134) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01111010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 126 Mileage: 112335 km Time Indication: 0 Date: 2000.00.00 Time: 14:41:39 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl Part No SW: 3C0 937 049 K HW: 3C0 937 049 K Component: Bordnetz-SG H37 1301 Revision: 00H37000 Serial number: 00000002173984 Coding: 00888F0700041A00000A00000F000000000C59435C0000 Shop #: WSC 05311 000 00000 VCID: 3162179A97734C94 Part No: 3C2 955 119 A Component: Wischer VW461 012 0503 Coding: 00063445 Shop #: WSC 05311 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: None VCID: 55AA830AC35B40B4 9 Faults Found 01221 - Crash Sensor Side Airbag; Driver Side (G179) 008 - Implausible Signal - MIL ON 01222 - Crash Sensor Side Airbag; Passenger Side (G180) 008 - Implausible Signal - MIL ON 01638 - Crash-Sensor for Side Airbag; Rear Drivers Side (G256) 008 - Implausible Signal - MIL ON 01639 - Crash-Sensor for Side Airbag; Rear Passenger Side (G257) 008 - Implausible Signal - MIL ON 01738 - Crash Sensor for Front Airbag; Drivers Side (G283) 010 - Open or Short to Plus - MIL ON 01739 - Crash Sensor for Front Airbag; Pass. Side (G284) 010 - Open or Short to Plus - MIL ON 01656 - Crash Signal 009 - Open or Short to Ground - MIL ON 00003 - Control Module 014 - Defective - MIL ON 01042 - Control Module; Not Coded 000 - - ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl Part No SW: 3C0 953 549 A HW: 3C0 953 549 A Component: Lenksäulenmodul 006 0010 Revision: 00006000 Serial number: 3C9953507C Coding: 0000014 Shop #: WSC 05311 000 00000 VCID: 2A5000F6BAA53F4C No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3C0-920-xxx-17.lbl Part No SW: 3C0 920 960 K HW: 3C0 920 960 K Component: KOMBIINSTRUMENT VD1 1614 Revision: X0006000 Serial number: 00000000000000 Coding: 0006105 Shop #: WSC 00036 210 58158 VCID: 2B5E05F2B55F2644 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530.lbl Part No SW: 3C0 907 530 C HW: 3C0 907 951 A Component: Gateway 007 0040 Revision: 00007000 Serial number: 0700C0681704C1 Coding: 3DFD3C04C22003 Shop #: WSC 05311 000 00000 VCID: 2142E7DAC793FC14 2 Faults Found 01305 - Databus for Infotainment 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 1 Fault Frequency: 1 Reset counter: 126 Mileage: 112335 km Time Indication: 0 Date: 2000.00.00 Time: 14:42:00 01304 - Radio 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 126 Mileage: 112335 km Time Indication: 0 Date: 2000.00.00 Time: 14:42:04 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.lbl Part No SW: 3C0 959 433 R HW: 3C0 959 433 R Component: IMMO 042 0383 Revision: 00042000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 39722FBA4F0384D4 Part No: 3C0 905 861 F Component: ELV 026 0380 3C0905861F ELV 026 0380 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1K0 959 701 P HW: 1K0 959 793 L Component: J386 TUER-SG FT 1124 Revision: 12007001 Serial number: 00000570968904 Coding: 0000693 Shop #: WSC 05311 000 00000 VCID: 3B7E35B2453FB6C4 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K2 909 144 L Component: EPS_ZFLS Kl.134 H07 1806 Shop #: WSC 02069 000 90108 VCID: 356A238A631B60B4 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.clb Part No SW: 3C0 959 433 R HW: 3C0 959 433 R Component: KSG PQ46 ELV 042 0472 Revision: 00042000 Serial number: VWZCZ000000000 Coding: 0191020051030E763004941570085FCE107CA0 Shop #: WSC 05311 000 00000 VCID: 39722FBA4F0384D4 Part No: 1K0 951 605 B Component: LIN BACKUP HORN H07 7001 Part No: 3C0 951 171 A Component: Neigungssensor 002 0508 Part No: 3C0 951 171 A Component: Innenraumueberw.002 0508 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl Part No SW: 1K0 959 702 P HW: 1K0 959 792 L Component: J387 TUER-SG BT 1124 Revision: 12007001 Serial number: 00000060068902 Coding: 0000692 Shop #: WSC 05311 000 00000 VCID: 3C7C36AE4031B1FC No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 3C0-907-801-53.lbl Part No SW: 3C0 907 801 B HW: 3C0 907 801 B Component: EPB VC8HC001 013 0001 Revision: 013 Coding: 0000011 Shop #: WSC 05311 000 00000 VCID: 2142E7DAC793FC14 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 1K0 959 703 P HW: 1K0 959 795 G Component: J388 TUER-SG HL 1114 Revision: 11005001 Serial number: 00000000564757 Coding: 0000144 Shop #: WSC 05311 000 00000 VCID: 3D7A3BAA5B2BB8F4 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 1K0 959 704 P HW: 1K0 959 794 G Component: J389 TUER-SG HR 1114 Revision: 11005001 Serial number: 00000000544643 Coding: 0000144 Shop #: WSC 05311 000 00000 VCID: 3E783CA6562DA3EC No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 3C0-919-283.lbl Part No SW: 3C0 919 283 B HW: 3C0 919 283 B Component: Parkhilfe 8-Kan 004 0011 Revision: 00004000 Serial number: 82930623705287 Coding: 0000024 Shop #: WSC 05311 000 00000 VCID: 2854FAFEA4A90D5C No fault code found. ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 E HW: 1K0 963 235 E Component: PTC-Element 0404 Revision: 00800000 Serial number: Shop #: WSC 00000 000 00000 VCID: 2D5A0BEA8B4B2874 No fault code found. End --------------------------------------------------------------------- Czy mogę prosić o pomoc w takiej sprawie... Miałem wcześniej błąd( chodziło o jedną ze świec żarowych)...konkretnie na drugim cylindrze..wymieniłem WSZYSTKIE na takie jak były firmy BOSH...bo miałem drgania silnika...ku mojemu zdziwieniu(na tym teście już tego błędu nie widać) silnik znowu drży...ale błędu VCDS już nie wykrywa a silnik wciąż drży..co jest...głównie na wolnych obrotach i czasami jest coś takiego jakby miał zgasnąć ,spada z obrotów i potem na nie wskakuje. Dziwne to jest samochód ma przejechane nieco ponad 112.000 km... Mieszkam w Anglii a tu raczej liczników się nie kręci,zresztą mam pełną historię obsługi. Jest to silnik 1,9 TDI..myślałem,że to może któryś z wtrysków...niestety nie bardzo wiem jak dokładnie je sprawdzić..może macie jakiś link? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
wojta Zgłoś #8 Napisano 24 Listopada 2011 (edytowane) bledow zadnych nie ma zwiazanych z praca silnika wiec jest ok sprobuj wymienic filtr paliwa i nabij klime Edytowane 24 Listopada 2011 przez wojta Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
huragan1971 Zgłoś #9 Napisano 25 Listopada 2011 Dzięki bardzo za odpowiedź...też miałem podobne spostrzeżenie...na pewno wymienię filtr paliwa,bo może rzeczywiście być tego przyczyna..tak jak pisałem dzieje się to tylko na wolnych obrotach i tak jak pisałem silnik pracuje równo nagle nie wiadomo kiedy jakoś nagle zwalnia a za sekundę przyśpiesza... Przed wymianą świec żarowych zrobiłem test VCDS i wyszło mi to: Address 01: Engine Labels: 03G-906-016-BKC.lbl Control Module Part Number: 03G 906 021 LR HW: 03G 906 021 AN Component and/or Version: R4 1,9L EDC G000SG 9248 Software Coding: 0000071 Work Shop Code: WSC 00191 264 15243 VCID: 7AF0F0B60A854FCC 2 Faults Found 000257 - Mass Air Flow Sensor (G70): Implausible Signal P0101 - 000 - - Freeze Frame Fault Status: 01110000 Fault Priority: 0 Fault Frequency: 1 Mileage: 112253 km Time Indication: 0 Date: 2000.00.00 Time: 18:58:35 Freeze Frame RPM: 1638 /min Speed: 58.0 km/h Temperature: 13.5°C Absolute Pres.: 1132.2 mbar Mass Flow: 31.29 g/s (no units): 0.78 Temperature: 84.6°C 005659 - Glowplug for Cylinder 2 (Q11): Open Circuit P161B - 000 - - Freeze Frame Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Mileage: 112262 km Time Indication: 0 Date: 2000.00.00 Time: 06:53:08 Freeze Frame RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 11.63 V Bin. Bits: 00001101 Temperature: 10.8°C Bin. Bits: 00110000 Readiness: 1 1 0 0 0 ...wymieniłem świece żarowe(tak dla pewności) a dla informacji powiem,że zapłaciłem za nie 39 funtów(200zł) na oryginalne BOSCH zrobiłem test ponownie i błędu tego już nie ma,ale silnik jak drżał tak drży,przyśpiesza i zwalnia... ---------- Post added at 11:18 ---------- Previous post was at 10:54 ---------- Aha jeszcze jedno pytanie w którym miejscu znajduje się filtr paliwa? Czy dam radę sam go wymienić? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
huragan1971 Zgłoś #10 Napisano 26 Listopada 2011 Dzięki bardzo kolego "wojta" właśnie wymieniłem filtr paliwa(ten stary był dosłownie zaszlamiony..)i jest o niebo lepiej! Silnik pracuje równo,no może są lekkie drgania,ale na prawdę bardzo małe w końcu to dizel....nawet nie sądziłem,że wymiana filtra paliwa to takie proste! Jeśli chodzi o klimę to pewnie dopiero nabije jak będę w Polsce ...myślę,że na trzeba sprawdzić szczelność instalacji. Sprawdziłem zaworki i ani śladu "syczenia",więc na pewno brak gazu,który wyciekł...Już kiedyś widziałem jak to się robi w innym aucie,ale mąszą to zrobić fachowcy,bo na pewno układ jest nie szczelny skoro gaz wyciekł.Pozdrawiam Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
VWonline.pl Zgłoś #11 Napisano 26 Listopada 2011 Jazda z pustą klimatyzacją w passacie b6 skutkuje zatarciem kompresora! Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
huragan1971 Zgłoś #12 Napisano 26 Listopada 2011 Z tego co wiem to jeśli klimatyzacja jest nie nabita,albo rozszczelniona to w ogóle się nie załącza sprężarka,więc raczej nie może się uszkodzić tak? Jeśli jestem w błędzie to mnie poprawcie i wyjaśnijcie czy tak jest czy nie. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
wojta Zgłoś #13 Napisano 27 Listopada 2011 Z tego co wiem to jeśli klimatyzacja jest nie nabita,albo rozszczelniona to w ogóle się nie załącza sprężarka,więc raczej nie może się uszkodzić tak? Jeśli jestem w błędzie to mnie poprawcie i wyjaśnijcie czy tak jest czy nie.tez mi sie tak wydaje od tego jest chyba sprzegielko klimy ---------- Post added at 20:20 ---------- Previous post was at 20:18 ---------- huragan1971 dodaj sobie jeszcze do baku srodek do czyszczenia wtryskow firmy STP powinno jeszcze pomoc a napewno nie zaszkodzi skoro filtr wygladal tak jak wygladal skoro mieszkasz w angli to kup w halfords koszt ok 13 do 15 funtow najpierw wlej plyn potem zatankuj Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
huragan1971 Zgłoś #14 Napisano 27 Listopada 2011 Dzięki "wojta"..tak zrobię jak piszesz..Podzielę się jeszcze spostrzeżeniami dotyczącymi sprawdzenie wtrysków VCDS..właśnie to dziś zrobiłem dokładnie według instrukcji..i stwierdziłem,że wszystkie są jak najbardziej ok...a i parametry prawie wszystkie pasują jedynie tylko jest "lekkie" odchylenie od normy jeśli chodzi o kanał 23(chyba..,bo sprawdzałem 13,18 i 23..) jest na cylindrze nr.1 jest -37 a w opisie jest,że powinno być między -30 a +30 i wyczytałem,że te parametry na "minusie" oznaczają,że może być zapchany filtr lub paliwo złej jakości..a filtr wymieniłem na nowy jednak delikatne drgania silnika czuć w środku,ale to minimalnie,więc nie wiem co zrobić...ale chyba tak jak piszesz,żeby dolać płynu STP( a Halfords-a mam pod nosem..) i dopiero zatankuje...Wydaje mi się a nawet jestem tego pewny,że poprzedni właściciel nie był za bardzo "zaznajomiony" użytkowaniem samochodu z silnikiem dizla...i dopóki wtryski są w porządku to warto o to zadbać,żeby tak było dalej. Mam jeszcze problem z zaadoptowaniem drugiego kluczyka...poczytałem na forum o tym dość sporo i nawet założyłem posta,ale chyba wydaje mi się,że ciężko będzie coś z tym zrobić(kupiłem używany kluczyk...),ale najgorsze,że nie mam PIN-u. A na prawdę przydałby mi sie drugi kluczyk.Może ktoś wie jak to dokładnie zrobić,bo jak na razie doszedłem do tego,że sprawdziłem,iż zakodowane są dwa kluczyki.. Proszę o pomoc o Dziękuje za dotychczasową. ---------- Post added at 23:46 ---------- Previous post was at 23:43 ---------- Aha i jeszcze jedno zacznę chyba tankować lepszej jakości ropę to też na pewno będzie miało wpływ na lepszą jakość pracy silnika...na chwilę obecną mam przejechane 69000 mill(112000 km..) a przebieg jest naturalny:) ---------- Post added at 23:55 ---------- Previous post was at 23:46 ---------- Czy to może chodzi o ten środek? http://www.ebay.co.uk/itm/STP-DIESEL-INJECTOR-CLEAN-250ML-/110724220214?pt=LH_DefaultDomain_3&hash=item19c7ad8536#ht_1895wt_1270 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
wojta Zgłoś #15 Napisano 27 Listopada 2011 podjedz do vw i popros o pin napewno dostaniesz jesli nie potrafisz zakodowac kluczyka to 48 funtow w vw bedzie pewnie taka operacja kosztowac bo u mnie w pracy kasuja za to pol godziny roboczej a aso maja podobne ceny godzina kosztuje 80 funta plus vat pozdrawiam ---------- Post added 28-11-2011 at 00:01 ---------- Previous post was 27-11-2011 at 23:57 ---------- tak to ten plyn sa jeszcze do czyszczenia calego ukladu ale przy twoim przebiegu raczej jeszcze nie jest potrzebny jak bedziesz wlewac ten plyn to dodaj go do mniejszej ilosci paliwa (diesla ) tz zrob mocniejsza mieszanke Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
huragan1971 Zgłoś #16 Napisano 28 Listopada 2011 Dzięki bardzo za pomoc jeszcze raz...a tak się składa,że salon i servis VW mam praktycznie pod nosem,więc tam do nich podjadę i poproszę o PIN a jak myślisz skasują mnie coś za niego? I co muszę mieć...znając życie to pewnie V5C i pewnie więcej nic,żeby zidentyfikowali auto...sam pewnie wiesz,że często potrzeba TYLKO numer rejestracyjny i wszystko jasne...tak jest w przypadku kupowania części w sklepach....w Polsce to chyba raczej nie możliwe:) Apropo tego płynu to na raz wlać całą butelkę? A ile wlać "napędu",żeby to wszystko grało,bo będę robił to pierwszy raz a przyda mi się to,bo zapamiętam na przyszłość i jak często to się robi? Czyli ten płyn i ten o którym piszesz czyli do całego układu...Aha po jakim czasie(ile może trwać czyszczenie wtrysków..)mogę podłączyć znowu kabel i VCDS i sprawdzić czy jest poprawa? Jeszcze raz Dzięki. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
wojta Zgłoś #17 Napisano 29 Listopada 2011 Dzięki bardzo za pomoc jeszcze raz...a tak się składa,że salon i servis VW mam praktycznie pod nosem,więc tam do nich podjadę i poproszę o PIN a jak myślisz skasują mnie coś za niego? I co muszę mieć...znając życie to pewnie V5C i pewnie więcej nic,żeby zidentyfikowali auto...sam pewnie wiesz,że często potrzeba TYLKO numer rejestracyjny i wszystko jasne...tak jest w przypadku kupowania części w sklepach....w Polsce to chyba raczej nie możliwe:) Apropo tego płynu to na raz wlać całą butelkę? A ile wlać "napędu",żeby to wszystko grało,bo będę robił to pierwszy raz a przyda mi się to,bo zapamiętam na przyszłość i jak często to się robi? Czyli ten płyn i ten o którym piszesz czyli do całego układu...Aha po jakim czasie(ile może trwać czyszczenie wtrysków..)mogę podłączyć znowu kabel i VCDS i sprawdzić czy jest poprawa?Jeszcze raz Dzięki. na butelce bedziesz mial opisane co i jak co do pinu wejdz zapytaj i tyle u mnie obsluga klienta jest bardzo sympatyczna i nic bys nie zaplacil co do tego servisu nie mam pojecia co cie spotka wez papiery by potwierdzic ze jestes wlascicielem wkoncu to pin Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
huragan1971 Zgłoś #18 Napisano 29 Listopada 2011 Dzięki raz jeszcze...jutro się za to biorę. Właśnie dziś już dostałem ten płyn z ebay.. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
huragan1971 Zgłoś #19 Napisano 30 Listopada 2011 jestem w szoku i dlatego muszę to teraz napisać...byłem dziś rano w serwisie VW w moim mieście i co usłyszałem na temat PIN-u? Chcieli ode mnie ...47 funtów za sam PIN!!! Poszedłem też zapytać ile kosztuje kluczyk z zaprogramowaniem i tu znowu szok..kluczyk kosztuje.. 102 funty a zaprogramowanie kolejne 47 funtów...Kolego czy jesteś pewny,że oni mogą i powinni dać to ren PIN za darmo?Jakbym miał ten PIN to może popróbowałbym zaprogramować ten kluczyk ,który kupiłem na ebay wiem,że trzeba zaprogramować zarówno immobiliser i alarm... Pozdrawiam Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
huragan1971 Zgłoś #20 Napisano 30 Listopada 2011 A może Ty byś mi jakoś pomógł w uzyskaniu tego numeru PIN..oczywiście samochód jest mój i mam na niego V5C...zresztą prawo jazdy też mam na ten sam adres,bo jakiś czas temu wymieniłem na Angielskie...Albo przynajmniej zapytaj czy u Ciebie się coś płaci za uzyskanie numeru PIN...Pozdrawiam Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
