Witam, kolega kupuje B5 wiec dzis zeskanowalem mu go i wyszly nastepujace rzeczy. Martwia mnie 2 bledy 01314 i 01330 czy moze sie cos powaznego za tym kryc?
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 038 906 018 GA
Component: 1,9l R4 EDC G000SG 2605
Coding: 00002
Shop #: WSC 00028
2 Faults Found:
18050 - Please check DTC Memory of Airbag Controller
P1642 - 35-00 - -
P1642 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
1 Fault Found:
00283 - Front Left ABS Wheel Speed Sensor (G47)
35-00 - -
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 D
Component: CLIMATRONIC D2.2
Coding: 05000
Shop #: WSC 00028
1 Fault Found:
00792 - A/C Pressure Switch (F129)
35-10 - - - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 3B0 920 822 A
Component: B5-KOMBIINSTR. VDO V25
Coding: 05145
Shop #: WSC 00878
IMMO-IDENTNR: VWZ7Z0Y2314761
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to B+ - Intermittent
29-10 - Short to Ground - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00004
Shop #: WSC 00028
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AH
Component: 3C Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00028
9 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01333 - Door Control Module: Rear Left (J388)
01331 - Door Control Module: Driver Side (J386)
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
01332 - Door Control Module: Passenger Side (J387)
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
01334 - Door Control Module: Rear Right (J398)
End -------------------------------------------------------
:przestraszony: trochę tego jest, jeszcze nie skanowałem passata z taką ilością błędów.
Po mojemu auto po dzwonie lub przerabiany anglik i nie wszystko poskładane jak należy.
Może wtyczki i kable należałoby posprawdzać.
Oczywiście odradzałbym kupno tego auta, chyba że ktoś jest dłubakiem hobbystą i lubi takie wyzwania.
auto nie mialo przekladki, przyprowadzone z holandii ale mialo dzwon, lewy przod.
Awariall, odpuść sobie to auto!
Na poczatek skasuj bledy i zobacz ile pozostanie, bo kilka z nich to sporadyczne.
Gość biedrona
Vax, jest ich więcej niż myślisz.
Naprawdę daj sobie spokój z tym autem.
Też tak pomyślałem.
Większość błędów to objaw wyładowanego akumulatora i zalanego modułu komfortu. Wykasuj błędy ( wczesniej je zapisz ) i jak możesz to pojeździj chwilę, włącz wszystkie użądzenia itd i następnie zrób mu jeszcze raz test
Podepnę się pod temat.
Czy warto/można kupić passata B5 3B z takimi błędami jak poniżej.
Czy to standard w passacie?
Czy to od zalania modułu?
VAG-COM Version: Release 311.2-N
Controller: 028 906 021 DT
Component: 1.9l R4 EDC 00SG 0816
Coding: 00002
Shop #: WSC 05314
No fault code found.
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
Controller: 1J1 907 044
Component: CLIMATRONIC S 4.0
Coding: 02000
Shop #: WSC 05314
1 Fault Found:
00792 - A/C Pressure Switch (F129) - podobno klima nie napełniona
35-00 - -
Controller: 3B0 919 880 D
Component: B5-KOMBIINSTR. VDO V08
Coding: 00140
Shop #: WSC 08800
IMMO-IDENTNR: VWZ7Z0T0012376
1 Fault Found:
01176 - Key
07-00 - Signal to Low
Controller: 3B0 959 796 K
Component: Zentral-SG Komfort V41
Coding: 04097
Shop #: WSC 04938
8 Faults Found:
01134 - Alarm Horn (H12)
25-00 - Unknown Switch Condition
01131 - Control Circuit for Turn Signals
37-00 - Faulty
35-00 - -
37-00 - Faulty
35-00 - -
00930 - Locking Module for Central Locking: Rear Left (F222)
27-00 - Implausible Signal
00931 - Locking Module for Central Locking: Rear Right (F223)
pozdr
Edytowane przez jasiujasiu1
Pytanie ile z tych błędów dało się usunąć. Coś było grzebane w autko lub zaczyna się psuć. Począwszy od tylnych zamków (prawy i lewy), podgrzewane lusterka działały? bo raczej się już im skończyło.
A tak przy okazji to nie przekładka czasami?(anglik) Za dużo błędów od grzebania.
Aha z błędem od klimy walczy kumpel. Podmienił panel i nic. Prawdopodobnie presostat odcina ale lepiej niech to fachowcy od klimy sprawdzą aby sprężarka nie była padnięta w najgorszej opcji. Z jakiejś przyczyny czynnik chłodzący zwiał prawda?
to jest drugie skanowanie po usunięciu błędów :(
centraly zamek żyje własnym życiem - ze środka nie blokuje tylnych drzwi, a od zewnątrz - kluczem czasem nie blokuje tylnych lewych. Raz przy zamykaniu kluczem otworzyły się lewe szyby. Po przytrzymaniu dłużej klucza domknęły się. central w pilocie-kluczu nie działa.
kody wyposażenia zaczynają się od X3A co podobno oznacza - national sales program France.
auto mialo baranka z przodu - niby nie dużego - myśle, że chlodnica klimy padła
Powiem tak. Jeżeli te auto jest w dobrej cenie i sądzisz, że się zmieścisz w średniej cenie takich pasków to można brać. Ja osobiście bym sobie odpuścił.
No zobacz gdzie jest rozlany czynnik ma on specyficzny barwnik ułatwiający ustalenie wycieków. Co do działa centralne to ciekawe czy pod dywanikiem kierowcy nie ma wody. Jak moduł pływa to pytanie czy dostała się do elektroniki woda bo może na przewodach tylko zwierać.
Taaaaaa...... Najprościej jest tak powiedzieć. To czemu sprzedający jej nie nabił? Przeciez to niewielki koszt. Czujnik moze byc uszkodzony, sprężarka zatarta, węże i instalacja - nieszczelne. Ja na swoją klimę wywaliłem 3000, ale teraz wiem że działa i nie ma prawa się nic stać :D
To mi wygląda na zalany moduł komfortu. U mnie H12 też nie działa, bo woda przeżarła styk w kostce i nie ma zasilania. Pozostałe - podobna kwestia i również dochodzi po prostu uszkodzenie mikrostyków w zamkach bądź siłowników zamków.
Trochę grzebania jest. Drzwi to problem niewielki, ale klima, to już inna bajka. Poźniej może jeszcze wyjśc, ze silniczki klapek nie reagują. Jest jedna zasada - jeśli klima jest a nie działa i gośc mówi, ze jest TYLKO pusta, to omija się szerokim łukiem takie auto. Bo jeśli ktoś sprzedaje samochód to stara sie tanim kosztem ukryć mankamenty, a skoro taka rzecz, jak klima - nie działa, tzn ze koszt naprawy się sprzedającemu nie kalkulował - proste. Przecież nikt sobie nie pozowli by kupujący zapunktował sprzedawcę na czymś - co może prowadzic do obnizenia ceny - czyż nie? Ja bym też sobie odpuscił to auto.
Edytowane przez Danek75
