albus
Długie kodowanie - brak w ABS : 000000
witam, co prawda sprawa dotyczy Golfa V ale może ktoś coś podpowie , problem jest w golfie V 1.9 TDI 2007r. : Brak kodowania - są same zera. na desce pali sie kontrolka od ręcznego i piszczy brzęczek...
Dodatkowo nie dziala wspomaganie po kalibracji:
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 000000000000000000000000000000000000
Shop #: WSC 01316 785 00200
1 Fault Found
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 201
Mileage: 30446 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 8192
Count: 195
Count: 45568
Count: 0
Count: 0
Count: 0
Ponizej wynik Autoscana :
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: XXXXXXXXXXXXXXXXX Mileage: 30440km/18914miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 SC HW: 03G 906 021 AN
Component: R4 1,9L EDC 001SG 1438
Revision: --H01--- Serial number: XXXXXXXXXXXXXX
Coding: 0050071
Shop #: WSC 06401 785 00200
No fault code found.
Readiness: 0 0 0 0 1
Revision: 00H35001
1 Fault Found
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 201
Mileage: 30446 km
Time Indication: 0
Freeze Frame:
Count: 16391
Count: 0
Count: 8192
Count: 195
Count: 45568
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 DD HW: 1K0 907 044 DD
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008661834
Coding: E5890F2700041000471400001400000000097F075C000100000000000000
Shop #: WSC 00999 444 64523
Part No: 1K1 955 119 E
Component: Wischer 090708 021 0501
Coding: 00038805
Shop #: WSC 00999
Part No: 1K0 955 559 AH
Component: RLS 220708 054 0402
Coding: 00209069
Shop #: WSC 00999
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PC1SHYDC
Coding: 0013111
Shop #: WSC 01357 011 00200
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0101
Coding: 0000042
Shop #: WSC 01279 785 00200
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 864 B HW: 1K0 920 864 B
Component: KOMBIINSTRUMENT VN4 3905
Revision: V0010000 Serial number: VWXBZ0H0790535
Coding: 0000101
Shop #: WSC 00007 007 00666
1 Fault Found
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 189
Time Indication: 0
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 130708F2000258
Coding: E9801F061002020002
Shop #: WSC 00005 005 60301
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VN4 3905
4 Faults Found
005 - No or Incorrect Basic Setting / Adaptation
01176 - Key
004 - No Signal/Communication
01179 - Incorrect Key Programming
000 - -
01176 - Key
008 - Implausible Signal
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1219
Coding: 0000052
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 00000 028 00001
2 Faults Found
02546 - Steering Limit Stop
Freeze Frame:
Mileage: 30430 km
Temperature: 44.0°C
Voltage: 13.70 V
Voltage: 13.50 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: CEC802087F2D8405484B03E010CC
Shop #: WSC 12345 123 12345
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 1K6 035 456 B HW: 1K6 035 456 B
Component: 08K Audioverst. 0006
Revision: 00004000 Serial number: 00000008149998
1 Fault Found
00419 - Left Front DSP Midrange Speaker (R103)
011 - Open Circuit
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000052
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 3C0 035 195 C HW: 3C0 035 195 C
Component: Radio PM6 012 0021
Revision: 00012000 Serial number: VWZ5Z7H1167414
Coding: 0010400
End ---------------------------------------------------------------------
Proszę o jakieś wskazówki
Natknołem się na ten post prez google. Poradził sobie kolega z tym problemem ? Jakies info / update ?
Wymieniłem abs na odpowiedni do tego auta, ten zamontowany był od innego modelu , a w czym masz problem?
Nie chodzi mi o to na jakis wymieniłes, chodzi mi o kodowanie.
