Sign in to follow this
polan23
Prosze o analize kodow bledow
Passat b6 2006 rok 170km silnik BMR
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Saturday,22,July,2017,11:28:25:62939
Chassis Type: 3C0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 53 55 56 62 72
7D
VIN: WVWZZZ3CZ7P034584 Mileage: 289290km/179756miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 EM HW: 03G 906 018 EM
Component: R4 2.0l PPD1.2 G 1881
Revision: --H22--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 00380 259 88644
VCID: 74E73A5B174EF4B8343
1 Fault Found:
006480 - Radiator Fan (V7)
P1950 - 007 - Movement Restricted / Jammed - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 254
Reset counter: 40
Mileage: 270783 km
Time Indication: 0
Date: 2015.11.13
Time: 16:57:35
Freeze Frame:
RPM: 800 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 13.67 V
37.44 %
Temperature: 77.0°C
Readiness: N/A
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 043 E HW: 02E 927 770 AE
Component: GSG DSG 070 1156
Revision: 04507000 Serial number: 00000606161132
Coding: 0000020
Shop #: WSC 00028 028 00001
VCID: 162320D3217246A8EA7
No fault code found.
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0940018557
Coding: 0013629
VCID: 326BFC43ADDABA88E6F
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 67DD5D1756980F20811
1 Fault Found:
01273 - Fresh Air Blower (V2)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 100
Reset counter: 169
Mileage: 285468 km
Time Indication: 0
Date: 2017.02.22
Time: 09:05:48
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
VCID: 306FF64BA3D6889890B
Subsystem 1 - Part No: 3C1 955 419 Labels: 1KX-955-119.CLB
Component: Wischer VW461 001 0101
Coding: 00063445
Shop #: WSC 00028
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 03 AIRBAG VW8 030 2522
Revision: 10030000 Serial number: 003B1PEK5E07
Coding: 0012339
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00007000 Serial number: 3C5953507P
Coding: 0001211
VCID: 2E53E833B9E29E68827
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 HW: 3C0 920 871
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0005105
Shop #: WSC 80093 222 69422
VCID: E1C9C30F38BCF110CF5
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C066210D15
Coding: 7FFD2C44C21002
VCID: 2149030FF83C31100F5
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 3979CB6F70AC49D0275
Part No: 3C0 905 861 F
Component: ELV 026 0380
3C0905861F ELV 026 0380
Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
Part No: 1K0 919 887 F
Component: Navigation 0030
Coding: 0000101
VCID: 3C77D27B7F9E7CF83C3
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 12006001 Serial number: 00000601368717
Coding: 0000245
VCID: 3B75D1677A907BC0359
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.136 H07 1806
VCID: 3467FA5B57CEB4B8F43
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 01910A0001860E763004941570084FCE707800
Component: Sounder No Answer
Part No: 3C0 951 171 A
Component: Neigungssensor 002 0508
Component: Innenraumueberw.002 0508
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 6
Reset counter: 203
Mileage: 234833 km
Time Indication: 0
Date: 2015.01.08
Time: 08:51:47
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 12006001 Serial number: 00000566068712
Coding: 0000244
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000012
Address 55: Xenon Range Labels: 5M0-907-357-V1.lbl
Part No SW: 5M0 907 357 HW: 5M0 907 357
Component: AFS-Steuergeraet 0003
Revision: H09 Serial number:
Coding: 0000001
VCID: F1E9B34FE85C41905F5
Subsystem 1 - Part No: 7L6 941 329
Component: AFS-Lst.-Modul l X018
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X018
Coding: 00000035
Address 56: Radio Labels: 1K0-035-095.lbl
Part No: 1K0 035 095 G
Component: Radio 0030
Coding: 0040400
VCID: 29591B2F800CF950575
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1113
Revision: 11004001 Serial number: 00000000349124
Coding: 0000208
VCID: 3D71DF7F648475F00BD
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1113
Revision: 11004001 Serial number: 00000000330188
Coding: 0000208
VCID: 3E73D87369826EE8127
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D51EF3FB4E4E570BBD
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End ---------------------------------------------------------------------
Masz dwa błędy
014 - Defective
Jeden intemittent-sporadyczny więc skasuj zobacz czy wróci. a drugie to nie wiem co to ale:
http://wiki.ross-tech.com/wiki/index.php/00361
