judam Zgłoś #1 Napisano 9 Kwietnia 2017 (edytowane) Więc zaczynam a raczej chciałbym zacząć od park assist 2. Tutaj skan mojego auta. Najważniejsze czy maglownica da rade ta? Reszta to już chyba drobnostki. Co jeszcze musiałbym wymienić? -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3C0 Scan: 01 02 03 08 09 13 15 16 17 18 19 25 37 42 44 46 47 52 53 55 56 62 69 6D 72 76 77 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 18-Aux. Heat -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 1010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: Malfunction 0010 56-Radio -- Status: Sporadic communication error 1000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-018-BMN.lbl Part No SW: 03G 906 018 EM HW: 03G 906 018 EM Component: R4 2.0l PPD1.2 A 4369 Revision: --H42--- Serial number: VWZCZ000000000 Coding: 0000078 Shop #: WSC 12345 123 232322 VCID: 74E3D8E36C7B No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-300-0xx.lbl Part No SW: 02E 300 044 L HW: 02E 927 770 AE Component: GSG DSG 081 1402 Revision: 04608010 Serial number: 00000709030961 Coding: 0000020 Shop #: WSC 44551 111 44551 VCID: 1E37DA4BB277 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-109-C4.lbl Part No SW: 3C0 614 109 E HW: 3C0 614 109 E Component: J104 C4 440 V3 0003 Revision: --020--- Serial number: 00000775914515 Coding: 0000285 Shop #: WSC 05311 000 00000 VCID: 204BE4B38803 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3C0-907-044.lbl Part No SW: 3C0 907 044 CA HW: 3C0 907 044 CA Component: ClimatronicPQ46 122 0708 Revision: 00122021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 62CFAEBBC68F No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 01000007611290 Coding: E78A8F4701041A00570000000F000000000B5D435C000180000000000000 Shop #: WSC 05124 000 00000 VCID: 71EDD1F71369 Subsystem 1 - Part No: 3C1 955 419 A Component: Wischer 030907 003 0205 Coding: 00046997 Shop #: WSC 05124 Subsystem 2 - Part No: 1K0 955 559 AF Component: RLS 270907 046 0204 Coding: 00208933 Shop #: WSC 05124 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Labels: None Part No SW: 3C0 907 567 H HW: 3C0 907 567 H Component: AC201 RDW 1 031 0119 Revision: 00031000 Serial number: 00000000014560 Coding: 0010000 Shop #: WSC 05311 000 00000 VCID: 306B14F3D8E3 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 3C0-909-605.lbl Part No SW: 3C0 909 605 M HW: 3C0 909 605 M Component: 0D AIRBAG VW8 032 2522 Revision: 12032000 Serial number: 003B1PJJ7JAS Coding: 0012356 Shop #: WSC 05311 000 00000 VCID: 306B14F3D8E3 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl Part No SW: 3C0 953 549 K HW: 3C0 953 549 K Component: J0527 0015 Revision: 00006000 Serial number: 3C9953507BH Coding: 0001222 Shop #: WSC 05311 000 00000 VCID: 346318E32CFB Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3C0-920-xxx-17.lbl Part No SW: 3C0 920 871 E HW: 3C0 920 871 E Component: KOMBIINSTRUMENT VD1 1216 Revision: V0002000 Serial number: 00000000000000 Coding: 0007105 Shop #: WSC 65536 645 577705 VCID: 2647F2ABEA27 No fault code found. ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: 1K0-815-007.lbl Part No: 1K0 815 007 BH Component: Standheizer 042 4404 Revision: 00042000 Serial number: 09011075000000 Coding: 0001012 Shop #: WSC 49841 141 95350 VCID: 6BD1C39F3145 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530.lbl Part No SW: 3C0 907 530 D HW: 3C0 907 951 Component: J533__Gateway H10 0080 Revision: H10 Serial number: 1300Q07802017E Coding: FD857F4E520E022002 Shop #: WSC 49883 141 173349 VCID: 224FEEBB860F No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.lbl Part No SW: 3C0 959 433 R HW: 3C0 959 433 R Component: IMMO 042 0383 Revision: 00042000 Serial number: VWZCZ000000000 Shop #: WSC 131071 1023 2097151 VCID: 397D29D70B99 Part No: 3C0 905 861 G Component: ELV 027 0380 3C0905861G ELV 027 0380 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl Part No: 1K0 919 887 F Component: Navigation 0030 Coding: 0000101 Shop #: WSC 05314 000 00000 VCID: 3C7330C304AB No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1K0 959 701 P HW: 1K0 959 793 L Component: J386 TUER-SG FT 1131 Revision: 32008001 Serial number: 00000530678903 Coding: 0000245 Shop #: WSC 05311 000 00000 VCID: 3B7133DF01A5 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl Part No: 1K1 909 144 M Component: EPS_ZFLS Kl.136 H08 1901 Shop #: WSC 02069 000 90108 VCID: 356525E72781 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 3C0-959-433-46.lbl Part No SW: 3C0 959 433 R HW: 3C0 959 433 R Component: KSG PQ46 ELV 042 0472 Revision: 00042000 Serial number: VWZCZ000000000 Coding: 00900A00D1030E763004941570084F0E707800 Shop #: WSC 49883 141 11342 VCID: 397D29D70B99 Part No: 1K0 951 605 D Component: LIN BACKUP HORN H07 9001 Component: NGS n.mounted Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 3C0-035-456.lbl Part No SW: 3C0 035 456 G HW: 3C0 035 456 G Component: 08K Audioverst. 0006 Revision: 00003000 Serial number: 00000008119348 Shop #: WSC 00000 000 00000 VCID: 2443E8A39C1B 1 Fault Found: 00870 - Bass Speaker Front Left (R21) 007 - Short to Ground ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl Part No SW: 1K0 959 702 P HW: 1K0 959 792 L Component: J387 TUER-SG BT 1131 Revision: 32008001 Serial number: 00000696478923 Coding: 0000244 Shop #: WSC 05311 000 00000 VCID: 3C7330C304AB No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 5N0-907-801.lbl Part No SW: 3C0 907 801 J HW: 3C0 907 801 J Component: J540 EPB3 VW-09393 0009 Revision: 008 Serial number: 00000000182010 Coding: 0000057 Shop #: WSC 05311 000 00000 VCID: 295DF997FB39 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 5M0-907-357-A.lbl Part No SW: 5M0 907 357 A HW: 5M0 907 357 A Component: AFS-Steuergeraet 0001 Revision: H02 Serial number: Coding: 2301953 Shop #: WSC 05311 000 00000 VCID: 326F1EFBD6EF Subsystem 1 - Part No: 7L6 941 329 Component: AFS-Lst.-Modul l X018 Coding: 00000035 Subsystem 2 - Part No: 7L6 941 330 Component: AFS-Lst.-Modul r X018 Coding: 00000035 1 Fault Found: 02628 - Sensor for Swivel Module Position; Right 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 3 Fault Frequency: 4 Reset counter: 138 Mileage: 258636 km Time Indication: 0 Date: 2017.04.07 Time: 10:17:37 Freeze Frame: Voltage: 14.20 V Speed: 130.0 km/h ABS 1 ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-095.lbl Part No: 1K0 035 095 G Component: Radio 0030 Coding: 0012042 Shop #: WSC 05314 000 00000 VCID: 295DF997FB39 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 1K0 959 703 P HW: 1K0 959 795 G Component: J388 TUER-SG HL 1119 Revision: 11006001 Serial number: 00000002377766 Coding: 0000208 Shop #: WSC 05311 000 00000 VCID: 3D753DC71FB1 No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl Part No SW: 1K0 907 383 D HW: 1K0 907 383 B Component: Anhaenger H15 0070 Revision: 3A002001 Serial number: 00000106940677 Coding: 0100000200000000 Shop #: WSC 05314 000 00000 VCID: 2E570A8BC2D7 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. Labels: None Part No SW: 3C9 827 383 B HW: 3C9 827 383 E Component: J605 HECKDECKEL 0600 Revision: 00H21001 Shop #: WSC 23250 384 715754 VCID: 306B14F3D8E3 Part No: 3C9 827 384 B Component: J756 HECKDECKEL 0600 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 1K0 959 704 P HW: 1K0 959 794 G Component: J389 TUER-SG HR 1119 Revision: 11006001 Serial number: 00000002388283 Coding: 0000208 Shop #: WSC 05311 000 00000 VCID: 3E773ACB12B7 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 3C0-919-283.lbl Part No SW: 3C0 919 283 C HW: 3C0 919 283 C Component: Parkhilfe 8-Kan 004 0013 Revision: 00004000 Serial number: 90630726403628 Coding: 0011024 Shop #: WSC 05311 000 00000 VCID: 295DF997FB39 No fault code found. Edytowane 24 Kwietnia 2018 przez judam Przeniesiony do prawidłowego działu. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
szczetke Zgłoś #2 Napisano 9 Kwietnia 2017 pewnie że możesz pla 2.0 jak wymienisz magiel i abs i parę ******* Wysłane z mojego SM-G935F przy użyciu Tapatalka Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
judam Zgłoś #3 Napisano 9 Kwietnia 2017 szczetke napisałeś chyba post nie czytając mojej specyfikacji. Moja maglownica to z literką M i gdzieś czytałem że ponoć właśnie tylko ta z tego typu będzie odpowiednia. Szukam tutaj potwierdzenia czy to prawda. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
judam Zgłoś #4 Napisano 9 Kwietnia 2017 No i chyba jednak się da. Jest możliwość w adaptacji ustawić park assist nawet DSR. Po adaptacji na park assist wywala błąd Błąd komunikacji z sterownikiem automatycznego pilota parkowania J791. Czy dobrze mi sie wydaje że jeśli idzie zrobić adaptacje to będzie ta maglownica działała? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
truna Zgłoś #5 Napisano 9 Kwietnia 2017 Do pla 2.0 musisz połowę elektryki zmienić Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
judam Zgłoś #6 Napisano 9 Kwietnia 2017 proszę o konkrety Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
romeo9999 Zgłoś #7 Napisano 10 Kwietnia 2017 Manglownica Ci podejdzie ale będzie przy parkowaniu szarpała, nie ma w niej płyności obrotu można zastąpić manglownice z golfa lub 5N1. Do wymiany pompa absu, czujniki abs, moduł parkowania, tunel z b7 z panelami i kupe roboty z elektryką Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mgboczna Zgłoś #8 Napisano 10 Kwietnia 2017 A jak to się ma w przypadku B7, bo też mi taki mod chodzi po głowie? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
szczetke Zgłoś #9 Napisano 10 Kwietnia 2017 w b7 dokladka 4 pdc i wymianą sterownika pdc to wszystko Wysłane z mojego SM-G935F przy użyciu Tapatalka Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mgboczna Zgłoś #10 Napisano 10 Kwietnia 2017 Ok. Dzięki za info. A kodowanie ? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
waski1 Zgłoś #11 Napisano 10 Kwietnia 2017 Ok. Dzięki za info. A kodowanie ? Odgapimy z mojego. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mgboczna Zgłoś #12 Napisano 10 Kwietnia 2017 Odgapimy z mojego. Już porównywałem. Kwestia tylko czy kodujemy ABS, wspomaganie,i czy wymagana jest jakaś kalibracja? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
bart.b Zgłoś #13 Napisano 11 Kwietnia 2017 Proponuje zrobić PLA1.5 i będzie git Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
tberent Zgłoś #14 Napisano 11 Kwietnia 2017 Proponuje zrobić PLA1.5 i będzie git Do pla 1.5 także potrzebna pompa od pla 2.0 . Do 1.0 trzeba sprawdzić czy ta obsłuży. Magiel obsłuży. Wysłane z mojego GT-I9506 przy użyciu Tapatalka Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mgboczna Zgłoś #15 Napisano 11 Kwietnia 2017 A jaka jest różnica pomiędzy PLA1.5 a 2.0 ? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
tberent Zgłoś #16 Napisano 11 Kwietnia 2017 Ja pier piernicze Chcesz się zabrać za takiego moda i jesteś zielony ? 1 i 1.5 to równolegle 2.0 to prostopadle i wyjazd Wysłane z mojego GT-I9506 przy użyciu Tapatalka Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mgboczna Zgłoś #17 Napisano 11 Kwietnia 2017 Ja pier piernicze Chcesz się zabrać za takiego moda i jesteś zielony ? Nie stresuj się kolego. Dam radę. Chodziło mi tylko o potwierdzenie Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
artmin Zgłoś #18 Napisano 12 Kwietnia 2017 a cos szerzej na temat opcji 'wyjazd'? jak mam to rozumiec? auto potrafi samo wyjechac z miejsca parkingowego? jesli tak to jak to uruchomic? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
truna Zgłoś #19 Napisano 12 Kwietnia 2017 Jak zaparkowałeś za pomocą pla to żeby Ci wyjechał wciskasz przycisk od pla i wtedy dostaniesz komunikaty na fisie do wyjazdu (takie jak przy pakowaniu) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mgboczna Zgłoś #20 Napisano 12 Kwietnia 2017 ...a czy do tego wystarczy sterownik z końcówką "L" czy może "S"? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
