Gość goldpedro Zgłoś #1 Napisano 16 Września 2010 potrzeboje pomocy kumpel ma golfa mk4 1.9 tdi wymienil zegary wymienil immobilajzer ktos mu to wszystko dopasowal i jezdzil dwa tygodnie az nagle sie immobilajzer zablokowal i nie da sie odpalic auta mam vag'a powiedzcie mi co mam zrobic zeby to ruszyc bo juz niewiem jak sie do tego zabrac czego i gdzie szukac Friday,24,September,2010,11:34:16:13314 VCDS Version: Release 908.0 Data version: 20090911 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1J - VW Golf/Bora IV Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75 76 ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-019-AJM.lbl Part No: 038 906 019 CJ Component: 1,9l R4 EDC 0000SG 1045 Coding: 00002 Shop #: WSC 30001 1 Fault Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - - Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl Part No: 1J0 907 379 AF Component: ASR 20 IE CAN 0001 Coding: 13404 Shop #: WSC 01317 1 Fault Found: 00668 - Supply Voltage Terminal 30 16-10 - Signal Outside Specifications - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl Part No: 1C0 909 605 A Component: 2A AIRBAG VW51 01 Coding: 12865 Shop #: WSC 00684 2 Faults Found: 01217 - Side Airbag Igniter; Driver Side (N199) 32-10 - Resistance too High - Intermittent 00589 - Airbag Igniter 1; Passenger Side (N131) 32-00 - Resistance too High ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 01317 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1J0-959-799.lbl Part No: 1J0 959 799 AH Component: 4V Zentral-SG Komf. 0001 Coding: 00256 Shop #: WSC 01317 Part No: 1J2959802C Component: 4V Tőrsteuerger. FS0002r Part No: 1J2959801D Component: 4V Tőrsteuerger. BF0002r 5 Faults Found: 00953 - Interior Light Time limit 25-10 - Unknown Switch Condition - Intermittent 00943 - Heated Exterior Mirror; Driver Side (Z4) 35-00 - - 00912 - Window Regulator Switch; Front Left (E40) 27-10 - Implausible Signal - Intermittent 00933 - Electric Window Motor; Passenger Side (V148) 62-00 - No or Incorrect Adjustment 00944 - Heated Exterior Mirror; Passenger Side (Z5) 35-00 - - ------------------------------------------------------------------------------- Address 56: Radio Labels: 1J0-035-18x-56.lbl Part No: 1J0 035 186 D Component: RADIO SON 0003 Coding: 01403 Shop #: WSC 01317 1 Fault Found: 00855 - Connection to CD changer 49-00 - No Communications End --------------------------------------------------------------------- Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
sipowitz Zgłoś #2 Napisano 16 Września 2010 Proponuję na początek sprawdzić stan naładowania akumulatora, ładowanie alternatora i ewentualne upływy prądu na postoju. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Gość goldpedro Zgłoś #3 Napisano 16 Września 2010 Proponuję na początek sprawdzić stan naładowania akumulatora, ładowanie alternatora i ewentualne upływy prądu na postoju. akumulator i alternator jest ok wszystkodziala jak powinno tylko silnik po 3 sekundach gasnie a na fisie wyskakuje informacja o aktywacji immobilajzera Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
sipowitz Zgłoś #4 Napisano 16 Września 2010 Sprawdzić/zakodować ponownie klucz. Na obu kluczach silnik gaśnie po chwili? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Gość goldpedro Zgłoś #5 Napisano 16 Września 2010 kluczyk jest tylko jeden czy moglbys mi przypomniec jak sie kodowalo kluczyki? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
sipowitz Zgłoś #6 Napisano 16 Września 2010 kluczyk jest tylko jeden czy moglbys mi przypomniec jak sie kodowalo kluczyki? Który rocznik auta? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Gość goldpedro Zgłoś #7 Napisano 16 Września 2010 chyba cos po 2001 jest po can'nie Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Gość goldpedro Zgłoś #8 Napisano 17 Września 2010 sprawdzilem golf jest z konca 2003 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
sipowitz Zgłoś #9 Napisano 17 Września 2010 http://wiki.ross-tech.com/wiki/index.php/Immobilizer_III_Key_Matching_%28Cluster%29 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
