jacekzw22 Zgłoś #1 Napisano 15 Kwietnia 2010 Witam posiadam passata 2004 rok mam problem otóż po podłączeniu VAG wyskoczyły mi błędy: proszę o pomoc Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58 ------------------------------------------------------------------------------- Address 01: Engine Controller: 038 906 019 EG Component: 1,9l R4 EDC G000SG 1543 Coding: 00005 Shop #: WSC 02802 TMBBU63U539027722 SKZ7Z001008710 No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Controller: 3U0 614 517 B Component: ABS/ESP front 1312 Coding: 04255 Shop #: WSC 00028 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Controller: 3U0 907 044 A Component: CLIMATRONIC S B5 C 2004 Coding: 17000 Shop #: WSC 00028 1 Fault Found: 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation ------------------------------------------------------------------------------- Skipping Address 15-Airbags ------------------------------------------------------------------------------- Address 16: Steering wheel Controller: 1J0 907 487 A Component: Lenkradelektronik 0005 Coding: 00118 Shop #: WSC 00028 1 Fault Found: 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation ------------------------------------------------------------------------------- Address 17: Instruments Controller: 3U0 920 840 A Component: KOMBI+WEGFAHRSP VDO V05 Coding: 31125 Shop #: WSC 00000 TMBBU63U539027722 SKZ7Z001008710 3 Faults Found: 01336 - Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent 00476 - Control Module for Fuel Pump (J538) 49-00 - No Communications 01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- Address 19: CAN Gateway Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 00028 3 Faults Found: 01336 - Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent 00476 - Control Module for Fuel Pump (J538) 49-00 - No Communications 01304 - Radio 49-00 - No Communications ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Controller: 3B1 959 760 E Component: Sitzverstellung 0301 Coding: 0000000 Shop #: WSC 00000 2 Faults Found: 01008 - Note: Emergency OFF Switch is Active! 000 - - - Intermittent 01460 - Driver's Seat-Memory Switch Button 2 (E219) 006 - Short to Plus ------------------------------------------------------------------------------- Address 37: Navigation Controller: 1U0 919 887 A Component: Navigation BNO 0205 Coding: 00002 Shop #: WSC 31480 1 Fault Found: 00481 - Control Module for Traffic Radio (J559) 49-00 - No Communications ------------------------------------------------------------------------------- Address 46: Central Conv. Controller: 1C0 959 799 B Component: 5E Komfortgerát HLO 0003 Coding: 00259 Shop #: WSC 00028 5 Faults Found: 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation 01336 - Data Bus for Comfort System 37-10 - Faulty - Intermittent 01131 - Control Circuit for Turn Signals 25-10 - Unknown Switch Condition - Intermittent 01134 - Alarm Horn (H12) 49-00 - No Communications 01135 - Interior Monitoring Sensors 36-00 - Open Circuit ------------------------------------------------------------------------------- Address 55: Xenon Range Controller: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00005 Shop #: WSC 00028 2 Faults Found: 01539 - Headlights Not Adjusted 35-00 - - 00776 - Level Control System Sensor: Left Front (G78) 31-00 - Open or Short to Ground ------------------------------------------------------------------------------- Address 56: Radio Controller: 3B0 035 186 D Component: Radio BNO 0205 Coding: 00407 Shop #: WSC 02022 1 Fault Found: 00852 - Loudspeaker(s): Front 36-00 - Open Circuit Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
ormowiec Zgłoś #2 Napisano 23 Kwietnia 2010 Spróbuj odłączyć radio i skasować błędy - 01336 - Data Bus for Comfort System 80-00 - Single-Wire Operation nie powinny wrócić. Masz uszkodzony czujnik poziomu przy lewym przednim kole, po wymianie zrobić adaptację reflektorów. ---------- Post added at 12:15 ---------- Previous post was at 12:13 ---------- Masz chyba też zalany moduł komfortu Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
jacekzw22 Zgłoś #3 Napisano 21 Lipca 2010 dziękuje bardzo za odpowiedź pozdrawiam Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
