Redzi Zgłoś #1 Napisano 1 Lutego 2009 Co oznaczaja te bledy?? VAG-COM Version: Release 311.2-N Chassis Type: 3B - VW Passat B5 Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58 Address 01 ------------------------------------------------------- Controller: 038 906 019 GQ Component: 1,9l R4 EDC G200SG 1524 Coding: 00002 Shop #: WSC 26689 WVWZZZ3BZ2E383334 VWZ7Z0A4810763 1 Fault Found: 18057 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 35-00 - - Readiness: N/A Address 03 ------------------------------------------------------- Controller: 4B0 614 517 G Component: ABS/ESP front 1728 Coding: 04255 Shop #: WSC 05311 2 Faults Found: 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent Address 08 ------------------------------------------------------- Controller: 3B1 907 044 H Component: CLIMATRONIC B5GP 0008 Coding: 17000 Shop #: WSC 05311 1 Fault Found: 01274 - Air Flow Flap Positioning Motor (V71) 35-10 - - - Intermittent Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 3B0 920 847 E Component: KOMBI+WEGFAHRSP VDO V07 Coding: 21115 Shop #: WSC 00000 WVWZZZ3BZ2E383334 VWZ7Z0A4810763 2 Faults Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent 01316 - ABS Control Module 49-10 - No Communications - Intermittent Address 19 ------------------------------------------------------- Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 05314 2 Faults Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent 01316 - ABS Control Module 49-10 - No Communications - Intermittent Address 37 ------------------------------------------------------- Controller: 1J0 919 887 A Component: Navigation BNO 0106 Coding: 00000 Shop #: WSC 00000 No fault code found. Address 46 ------------------------------------------------------- Controller: 1C0 959 799 B Component: 0J Komfortgerát HLO 0003 Coding: 00259 Shop #: WSC 05311 1 Fault Found: 01141 - Luggage Compartment Unlocking Switch (E165) 27-00 - Implausible Signal Address 55 ------------------------------------------------------- Controller: 4Z7 907 357 Component: dynamische LWR D07 Coding: 00007 Shop #: WSC 05311 No fault code found. Address 56 ------------------------------------------------------- Controller: 1J0 035 152 G Component: Radio BNO 0106 Coding: 05401 Shop #: WSC 26689 No fault code found. End ------------------------------------------------------- --- scalone --- NIE MOGE ZNALESC CO OZNACZAJA TE BLEDY 18057 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 35-00 - - 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
elmi_k Zgłoś #2 Napisano 1 Lutego 2009 (edytowane) 18057 - P1649 - 4689 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 35-10 - - - Intermittent Brak danych z komputera sterującego systemem ABS. ECU nie widzi sterownika ABS... Posprawdzaj moze jakis czujnik sie poluzowal. a jest ABS?? a cos dzialales z komputerem?? 1. 18258 (ABS ESP EDS ASR/Błędy) Magistrala danych CAN. Brak informacji z komputera sterującego silnikiem. 1. P1649 18057 (Silnik/Kody błędów) Magistrala danych napędu, brakujące dane z komputera sterującego systemem ABS. Edytowane 1 Lutego 2009 przez elmi_k Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
makeć Zgłoś #3 Napisano 1 Lutego 2009 18057 - Magistrala danych napędu, brak danych z komputera sterującego ABS. 18258 - Magistrala danych napędu, brak danych z komputera sterującego silnikiem (ECU) czy coś się z autem dzieje ?? jest dużo alarmów (dokładanych), przez , które właśnie takie błędy się pojawiają - takie zabezpieczenie. skasuj wszystko, sprawdź jeszcze raz. Pozdrawiam Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Redzi Zgłoś #4 Napisano 2 Lutego 2009 W samochodzie jest zamontowanie zabezpieczenie typu odciecie zaplonu multilock czy jalkos tak bylo juz jak kupilem samochod moze to byc to ?? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
grgr Zgłoś #5 Napisano 30 Października 2011 Witam, mam podobny problem i nie jestem pewien działania ABS-u. Jak wcisne hamulec do oporu, to czuć na pedale takie torkotanie jakby, jednak na asfalcie zostają i to wyraźne (tak jakby bez absu) ślady hamowania. Generalnie to wracający błąd (drugie skanowanie, po małej przejażdżce): ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-019-AVF.LBL Controller: 038 906 019 GQ Component: 1,9l R4 EDC G000SG 1524 Coding: 00002 Shop #: WSC 00028 WVW*** VWZ*** 1 Fault Found: 18057 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 35-10 - - - Intermittent Readiness: N/A Natomiast na samym początku były jeszcze błędy: ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4B0-614-517.LBL Controller: 4B0 614 517 G Component: ABS/ESP front 1728 Coding: 04255 Shop #: WSC 00028 1 Fault Found: 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-00 - - ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3B0-920-xx5-17.LBL Controller: 3B0 920 827 A Component: KOMBI+WEGFAHRSP VDO V08 Coding: 05115 Shop #: WSC 00000 WVW*** VWZ*** 2 Faults Found: 01314 - Engine Control Module 49-00 - No Communications 01316 - ABS Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 00028 2 Faults Found: 01314 - Engine Control Module 49-00 - No Communications 01316 - ABS Control Module 49-10 - No Communications - Intermittent I tyle z błędów związanych z ABS. Czy w związku z tym mam wnioskować, że ABS nie chodzi i podjechać gdzieś na oględziny? Spróbowałem przejechać się kawałek, bo znalazłem w tym vcds-lite opcje do odczytu prędkości z czujników i istotnie z 4 odczytuje równe raczej wartości. Ale dalszą jazde sobie odpuściłem, bo migała+wyła kontrolka ręcznego (był zdjęty) i bałem się troche o laptopa przypiętego pasami . Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
