ElkAks77 Zgłoś #1 Napisano 11 Grudnia 2016 (edytowane) Witam, Dzisiaj odczytałem loga z komputera i wyskoczył mi temat Address 65: Tire Pressure Cannot be reached. Wszystkie czujniki sprawne, a mimo wszystko nie widzi ich. Nie mam osobnego przycisku SET ustawiania, wszystko przez komputer, system 433MHz wysokopoziomowy oparty o czujniki 3AA907275B. Proszę o pomoc w zdiagnozowaniu problemu. Log poniżej: Saturday,10,December,2016,19:24:39:04550 VCDS Version: 15.7.0.2 Data version: 20150820 Chassis Type: 3C (7N0) VIN: ... Mileage: ... ... ... ... ... ... ... ... ... ... ... 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... 65-Tire Pressure -- Status: Cannot be reached 1100 ... ... ... ------------------------------------------------------------------------------- ... ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb Part No SW: 3AA 920 880 C HW: 3AA 920 880 C Component: KOMBI H03 0408 Serial number: 00000000000000 Coding: 161F00 Shop #: WSC 05314 115 00000 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114 ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod VCID: 337D089FCB35911AD262E11-8066 1 Fault Found: 12658432 - Function Restricted due to Missing Message(s) U1111 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 82 Mileage: 256286 km Date: 2016.12.10 Time: 19:20:49 ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb Part No SW: 7N0 907 530 Q HW: 1K0 907 951 Component: J533 Gateway H41 1623 Revision: H41 Serial number: 060112F2001914 Coding: 462006 Shop #: WSC 26219 123 1048576 VCID: 3E6B29ABF0774CF22D0C78D-806A 2 Faults Found: 01325 - Control Module for Tire Pressure Monitoring (J502) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 82 Mileage: 256286 km Time Indication: 0 Date: 2016.12.10 Time: 19:12:35 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 255 Mileage: 256286 km Time Indication: 0 Date: 2016.12.10 Time: 19:21:32 ------------------------------------------------------------------------------- ... ------------------------------------------------------------------------------- Address 65: Tire Pressure Cannot be reached ------------------------------------------------------------------------------- ... End-------------------------(Elapsed Time: 04:12)-------------------------- Edytowane 11 Grudnia 2016 przez ElkAks77 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
