adrusek
Prośba o analize logów 1.9 BXE
Kolega ma problem ze swoją jetta 1.9BXE 2006r. Problem jest taki, że auto nie chce jechać. Na 5 biegu to całkiem przyspieszyć nie chce a przy dodaniu gazu silnik buczy.
Błedy: (po wykasowaniu wrócił tylko błąd czujnika)
Monday,17,August,2015,10:50:58:10074
VCDS Version: Beta 11.6.0
Data version: 20111008
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ7M016573 Mileage: 236360km/146867miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Sporadic communication error 1000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 KH HW: 03G 906 021 KH
Component: R4 1,9L EDC 000SG 8984
Revision: --H02--- Serial number: VWZ7Z0F4257567
Coding: 0000071
Shop #: WSC 00066 000 00000
VCID: 6FE9D78F055D
2 Faults Found:
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83): Signal too High
P2185 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 232494 km
Time Indication: 0
Date: 2000.00.00
Time: 14:44:31
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 11000100
Temperature: 78.3°C
Temperature: 67.5°C
000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Mileage: 232821 km
Time Indication: 0
Date: 2000.00.00
Time: 21:58:30
Freeze Frame:
RPM: 2520 /min
Speed: 117.0 km/h
Load: 76.1 %
Voltage: 14.52 V
Bin. Bits: 11000000
Absolute Pres.: 2019.6 mbar
Absolute Pres.: 2437.8 mbar
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F8947CF15BD
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DP
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 75E5E5E76701
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000410406
Coding: 01010E2700041500470A00000F00000000095D035C0000
VCID: 37792FEF3D8D
Subsystem 1 - Part No: 1K1 955 119 E
Component: Wischer 160102 020 0501
Coding: 00038805
Shop #: WSC 00066
1 Fault Found:
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 110
Mileage: 232631 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 2J AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0HST1
Coding: 0012874
VCID: 3D753DC71FB1
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AN HW: 1K0 953 549 AN
Component: Lenksäulenmodul 636 0070
Coding: 0000001
VCID: 7EF7FACB5237
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 853 H HW: 1K0 920 853 H
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4257567
Coding: 0019103
Shop #: WSC 00420 067 57207
VCID: 2F69178FC5DD
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001065180757
Coding: 3D3F0B4007001002
Shop #: WSC 00110 259 82186
VCID: 2C530083F4CB
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 110
Mileage: 232631 km
Time Indication: 0
Date: 2000.00.00
Time: 08:54:32
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO 3HL 1610
VCID: 2F69178FC5DD
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1125
Revision: 12006001 Serial number: 00000014968703
Coding: 0000180
VCID: 3B7133DF01A5
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 12
Reset counter: 138
Mileage: 0 km
Time Indication: 0
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 346318E32CFB
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 18900A000106087F2D04840570084FC6F0FCA0
Shop #: WSC 00110 259 88037
VCID: 83010B3FB9D5
Part No: 1K0 951 605 B
Component: LIN BACKUP HORN H07 7001
Part No: 1K0 951 178
Component: Neigungssensor 001 0101
Component: Innenraumueberw.001 0101
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1125
Revision: 12006001 Serial number: 00000043868630
Coding: 0000180
VCID: 3C7330C304AB
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 P
Component: Radio BVX 016 0023
Coding: 0020200
VCID: 33611BFF29F5
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1115
Revision: 11004001 Serial number: 00000000162463
Coding: 0000144
VCID: 3D753DC71FB1
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1115
Revision: 11004001 Serial number: 00000000156029
Coding: 0000144
VCID: 3E773ACB12B7
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D550D87CFD1
End ---------------------------------------------------------------------
Logi statyczne mb:
http://vaglog.pl/log_228859.html
http://vaglog.pl/log_228861.html
http://vaglog.pl/log_228862.html
http://vaglog.pl/log_228863.html
logi statyczne
http://vaglog.pl/log_228860.html
logi dynamiczne
http://vaglog.pl/log_228864.html
http://vaglog.pl/log_228866.html
http://vaglog.pl/log_228865.html
Proszę o jakieś rady i dziękuje zainteresowaniem.
Ja tu widzę, że turbo słabo łapie do tych 2000 obr, znowu potem jest solidne przeładowanie o 0,5bar.
Do czyszczenia? A jak przepływka i reszta ?
Zobacz jakie wzorcowe przepływy powietrza powinien mieć ten silnik i potem porównaj ze swoimi. Wiadomo, że jak jest ochyłka +- 5% to wszystko gra, ale przy większych trzeba dalej drążyć temat.
Czyli turbo na stół, a jeszcze coś niepokojącego widać?
