mazaki Zgłoś #1 Napisano 30 Grudnia 2011 ZERKNIE KTOS NA TE BŁEDY?? DOSAM TYLKO ZE MAM WŁASNE ODCIECIE ZASILANIA W PASKU Friday,30,December,2011,17:13:03:36838 VCDS Version: Release 10.6.3 Data version: 20101206 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3B - VW Passat B5 Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77 VIN: WVWZZZ3BZ3P268563 Mileage: 174760km/108590miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-019-AVF.lbl Part No: 038 906 019 GQ Component: 1,9l R4 EDC G000SG 1582 Coding: 00002 Shop #: WSC 01974 VCID: 6CDCD834360D WVWZZZ3BZ3P268563 VWZ7Z0B6225420 No fault code found. Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4B0-614-517.lbl Part No: 4B0 614 517 G Component: ABS/ESP front 1728 Coding: 04255 Shop #: WSC 00028 VCID: 254AED109567 2 Faults Found: 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent 18258 - Powertrain Data Bus: Missing Message from ECU P1850 - 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3Bx-907-044.lbl Part No: 3B1 907 044 H Component: CLIMATRONIC B5GP 0009 Coding: 17000 Shop #: WSC 00028 VCID: 2648EA1CE861 3 Faults Found: 00603 - Footwell/defroster Flap Positioning Motor (V85) 35-10 - - - Intermittent 01274 - Air Flow Flap Positioning Motor (V71) 35-10 - - - Intermittent 01273 - Fresh Air Blower (V2) 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl Part No: 1C0 909 605 B Component: 0A AIRBAG VW51 04 0006 Coding: 12353 Shop #: WSC 00028 VCID: 234EF3089B53 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1J0-907-487-A.lbl Part No: 1J0 907 487 B Component: Lenkradelektronik 0002 Coding: 00008 Shop #: WSC 07777 VCID: 30640C44DAA5 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3B0-920-xx5-17.lbl Part No: 3B0 920 847 E Component: KOMBI+WEGFAHRSP VDO V08 Coding: 21115 Shop #: WSC 00000 VCID: 2854E424E275 WVWZZZ3BZ3P268563 VWZ7Z0B6225420 1 Fault Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 00028 VCID: F0E44C449A25 1 Fault Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 37: Navigation Labels: 3B0-919-887.lbl Part No: 1J0 919 887 B Component: Navigation BNO 0204 Coding: 00000 Shop #: WSC 05311 VCID: 377637583FCB No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1C0-959-799.lbl Part No: 1C0 959 799 B Component: 0Z Komfortgerát HLO 0003 Coding: 00259 Shop #: WSC 00028 VCID: 36683A5C38C1 Part No: 1C1959801 Component: 0Z Tőrsteuer.FS KLO 0004 Part No: 1C1959802 Component: 0Z Tőrsteuer.BF KLO 0009 Part No: 1C0959811 Component: 0Z Tőrsteuer.HL KLO 0009 Part No: 1C0959812 Component: 0Z Tőrsteuer.HR KLO 0009 1 Fault Found: 00928 - Locking Module for Central Locking; Front Driver Side (F220) 27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 3B0-035-186.lbl Part No: 1J0 035 152 G Component: Radio BNO 0204 Coding: 00205 Shop #: WSC 05311 VCID: 2240F60C8449 No fault code found. End --------------------------------------------------------------------- Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mielke Zgłoś #2 Napisano 30 Grudnia 2011 18258 - Powertrain Data Bus: Missing Message from ECU http://wiki.ross-tech.com/wiki/index.php/18258/P1850 00603 - Footwell/defroster Flap Positioning Motor (V85) http://wiki.ross-tech.com/wiki/index.php/00603http://forum.vw-passat.pl/threads/1046-Klimatyzacja-climatronic?highlight=00603 http://forum.vw-passat.pl/threads/74130-Klimatronik-naprawa-silnika-klapy-regulacji-temperatury-blad-4F7-silownik-V68?highlight=naprawa+v68 01274 - Air Flow Flap Positioning Motor (V71) http://wiki.ross-tech.com/wiki/index.php/01274http://forum.vw-passat.pl/threads/16416-klimatyzacja-Climatronick-nie-grzeje?p=246077#post246077 01273 - Fresh Air Blower (V2) http://wiki.ross-tech.com/wiki/index.php/01273http://forum.vw-passat.pl/threads/49307-Co-oznaczaja-te-bledy?highlight=01273 01314 - Engine Control Module http://wiki.ross-tech.com/wiki/index.php/0131400928zamek drzwi kierowcy P.S. To wszystko jest już na forum wystarczy użyć szukaj-ki Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mazaki Zgłoś #3 Napisano 30 Grudnia 2011 dziekuje za pomoc i za poświecony czas , no mój fl juz sie zaczyna sypac Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
