Sign in to follow this
Dymekgd
Błędy Passat B6 - 2.0 FSI
Czy mógłby ktoś rozszyfrować mi kilka błędów:
03200 - Switch for Electric Parking Brake (E538)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 84
                    Mileage: 153833 km
                    Time Indication: 0
                    Date: 2018.04.15
                    Time: 16:14:10
             Freeze Frame:
                    Voltage: 13.40 V
                    Count: 10
                    Speed: 0.0 km/h
                    Hex Value: 0x1261
                    Hex Value: 0x0001
                    Hex Value: 0x1010
00576 - Terminal 15
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 84
                    Mileage: 153833 km
                    Time Indication: 0
                    Date: 2018.04.15
                    Time: 16:13:46
             Freeze Frame:
                    Voltage: 12.00 V
                    Count: 54
                    Speed: 0.0 km/h
                    Hex Value: 0x1271
                    Hex Value: 0x0001
                    Hex Value: 0x1010
1 Fault Found:
01592 - Air Quality Sensor (G238)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 84
                    Mileage: 153830 km
                    Time Indication: 0
                    Date: 2018.04.15
                    Time: 15:56:03
000010 - Camshaft Positioner (Bank 1 Intake)
               P000A - 008 - Slow Response - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 254
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 10200 /min
                    Load: 100.0 %
                    Speed: 255.0 km/h
                    Temperature: 215.0°C
000808 - Knock Sensor 1 (G61)
               P0328 - 001 - Signal too High - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 12
                    Reset counter: 255
                    Mileage: 149954 km
                    Time Indication: 0
                    Date: 2018.03.08
                    Time: 05:24:39
             Freeze Frame:
                    RPM: 2600 /min
                    Load: 45.9 %
                    Speed: 88.0 km/h
                    Temperature: 45.0°C
000819 - Knock Sensor 2 (G66)
               P0333 - 001 - Signal too High - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 153774 km
                    Time Indication: 0
                    Date: 2018.04.15
                    Time: 11:18:07
             Freeze Frame:
                    RPM: 2360 /min
                    Load: 39.2 %
                    Speed: 80.0 km/h
                    Temperature: 53.0°C
Witam mogę poprosić o pomoc, nie łączy mi się z silnikiem.
Wczoraj miałem na wyświetlaczy aby wyłączyć silnik. okazało się że płynu w zbiorniczu wyrównawczym od chłodnicy było o 50gr. ,mniej niż powinno.
Ogólnie na zimnym chodzi coraz dziwniej, tak jakby mu przerywało na ułamki sekund ale nie gaśnie.
Po kilku minutach jest już wszystko ok, wiec postanowiłem podpiąć się i zobaczyć jakie są błędy.
VCDS na autoscan nie wchodzi do silnika.
Sobota,22,Wrzesień,2018,10:04:55:00001
VCDS -- Emulator VAG/VAS pracujący w środowisku Windows, uruchomiony na Windows 10 x64
Wersja VCDS: AKP 17.1.3.0
Wersja danych: 20170621 DS267.7
www.vcds.pl
Przebieg: 208270km   Numer naprawy:
Lista połączeń Gateway:  3C0 907 530 C
00-Czujnik kąta skrętu kierownicy -- Stan: OK 0000
01-Silnik -- Stan: Usterka 0010
02-Skrzynia biegów -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
08-Klimatyzacja -- Stan: OK 0000
09-Centr.zesp.elektr. -- Stan: OK 0000
15-Airbag -- Stan: OK 0000
16-Koło kierownicy -- Stan: OK 0000
17-Zest.wskaźników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
25-Immobiliser -- Stan: OK 0000
42-Elektr.drzwi kier. -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: OK 0000
46-Moduł komfortu -- Stan: OK 0000
52-Elektr.drzwi pas. -- Stan: OK 0000
53-Hamulec postojowy -- Stan: OK 0000
56-Radio -- Stan: OK 0000
62-Drzwi tylne lewe -- Stan: OK 0000
72-Drzwi tylne prawe -- Stan: OK 0000
A ręcznie próbowałeś wejść w 01-Silnik i odczytać błędy? Bo po takim skanie to można uruchomić szklaną kulę niestety.
Ew jeśli ręcznie też nie możesz się połączyć z silnikiem, to poszukaj kogoś, kto również ma VCDS (najlepiej oryginalny), bo może problem leży w klonie.
