bsk123
Pomoc w rozkodowaniu błędów Pasat 2.0 TDI 170km DSG
Koledzy proszę pomóżcie rozkodować mi błędy z VCDS. Poniżej załączam logi. Jestem świeżym użytkownikiem Pasata także proszę o wyrozumiałość
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QG    HW: 03L 907 309
   Component: R4 2,0L EDC G000AG  3736
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 84224 536 673448
   VCID: 7AFC29AA35441991A7-802E
3 Faults Found:
001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
               P0544 - 000 - Circuit Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 255
                    Mileage: 81177 km
                    Time Indication: 0
                    Date: 2012.02.17
                    Time: 20:05:09
             Freeze Frame:
                    RPM: 1518 /min
                    Speed: 74.0 km/h
                    Voltage: 13.91 V
                    Temperature: 87.3°C
                    Temperature: 930.0°C
                    Temperature: 264.0°C
                    Temperature: 252.0°C
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 255
                    Mileage: 81177 km
                    Time Indication: 0
                    Date: 2012.02.17
                    Time: 20:05:09
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 255
                    Mileage: 81177 km
                    Time Indication: 0
                    Date: 2012.02.17
                    Time: 20:05:09
Readiness: 0 1 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 051 T    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1912
   Revision: 04844002    Serial number: 00000812220899
   Coding: 0000020
   Shop #: WSC 05311 000 00000
   VCID: 244037D2E740BF61AD-8070
1 Fault Found:
02084 - Component Protection
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 3
                    Mileage: 81186 km
                    Time Indication: 0
                    Date: 2012.02.18
                    Time: 07:16:07
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 T    HW: 3C0 614 109 T
   Component: J104    C4 440 V2   0013
   Revision: --025---    Serial number: 00000795058234
   Coding: 0000301
   VCID: 2F6AC8FEBE860C3940-807A
No fault code found.
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 DK    HW: 3C0 907 044 DK
   Component: ClimatronicPQ46 133 0909
   Revision: 00133024    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 6DD612F6740ABE2932-8038
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000009343032
   Coding: EF8A8F0700041A00470A00000F000000000B5D435C000120000000000000
   Shop #: WSC 00510 259 91722
   VCID: 3362C48E52AE28D924-8066
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 221008 004  0206
   Coding: 00046997
   Shop #: WSC 00510
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     110209 054  0402
   Coding: 00208936
   Shop #: WSC 00510
2 Faults Found:
02399 - Control Circuit for Terminal 30 for Interior Illumination
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00111001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 82371 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.35 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
00059 - Terminal 30 for Interior Lighting
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 82371 km
                    Time Indication: 0
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08740903701432
   Coding: 100102
   Shop #: WSC 05314 000 00000
   VCID: 326CC18A6DB421D12F-8066
2 Faults Found:
01543 - Parking Aid Warning Chime (H15)
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 245
                    Time Indication: 15
             Freeze Frame:
                    Temperature: 0.0°C
01625 - Front Parking Aid Warning Chime (H22)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 245
                    Time Indication: 15
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__005 VW10 HI   1916
   Revision: 20013000    Serial number: 003E2P323WGE
   Coding: 0012341
   VCID: 4480975207009F618D-8010
   Subsystem 1 - Serial number: 6332MTS601450339
   Subsystem 2 - Serial number: 6342MTS654470139
   Subsystem 3 - Serial number: 6351HTS67R1UV5KJ
   Subsystem 4 - Serial number: 6361HTS68F6UV5KR
   Subsystem 5 - Serial number: 00000000000000000
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
   Part No SW: 3C0 953 549 AC    HW: 3C0 953 549 AC
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507CN
   Coding: 0001112
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           002 0030
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C0 920 871 T    HW: 3C0 920 871 T
   Component: KOMBI         H04 0107
   Coding: 160F00
   Shop #: WSC 05314 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
   VCID: 3566FA9694DA36E90A-8060
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P092160390
   Coding: FDA17F06000202002002
   VCID: 2A5CD9EA8564691197-807E
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   Subsystem 1 - Part No: 3C0 905 861 G
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 250
                    Time Indication: 0
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1517
   Revision: 72009005    Serial number: 00000568498112
   Coding: 0000245
   VCID: 6FEA08FE7E064C3900-803A
1 Fault Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 3
                    Fault Frequency: 14
                    Reset counter: 23
                    Mileage: 81361 km
                    Time Indication: 0
                    Date: 2012.03.24
                    Time: 03:14:11
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.082 0502
   Revision: 1AH02254    Serial number: 00090080068102
   Coding: 0000258
   VCID: 397EF6A670C2D289EE-806C
1 Fault Found:
01288 - Terminal 30; Steering Assist
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 9
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                        Term 15 On
                    RPM: 105 /min
                    Speed: 0.0 km/h
                    (no units): 2.0
                    Voltage: 10.70 V
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 043 0612
   Coding: 0191020051030E763004941570084FCE707801
   Subsystem 1 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Subsystem 2 - Part No: 3C0 951 171 C
   Component: Neigungssensor  004 0611
   Subsystem 3 - Part No: 3C0 951 171 C
   Component: Innenraumueberw.004 0611
2 Faults Found:
01135 - Interior Monitoring Sensors
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 82371 km
                    Time Indication: 0
                    Date: 2012.04.20
                    Time: 18:52:19
00323 - Vehicle Inclination Sensor (G384)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 82371 km
                    Time Indication: 0
                    Date: 2012.04.20
                    Time: 18:52:19
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1517
   Revision: 72009005    Serial number: 00000627689204
   Coding: 0000244
   VCID: 70E80B82633853C119-8024
1 Fault Found:
00110 - Right Mirror Turn Signal Lamp (L132)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 254
                    Reset counter: 20
                    Mileage: 64364 km
                    Time Indication: 0
                    Date: 2009.08.14
                    Time: 15:58:45
Address 53: Parking Brake        Labels: 5N0-907-801.clb
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000250137
   Coding: 0000057
   VCID: 285823E29B685B0181-807C
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 81447 km
                    Time Indication: 0
                    Date: 2012.03.29
                    Time: 08:04:15
             Freeze Frame:
                    Voltage: 10.90 V
                    Count: 52
                    Speed: 0.0 km/h
                    Hex Value: 0x12E0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0136
   Revision: 00H04000    Serial number:
   Coding: 2311169
   VCID: 3460C79257A02FE13D-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000035
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3I4214931
   Coding: 0500040004
   VCID: 65C66AD66CFA86697A-8030
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000810329
   Coding: 0000208
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000814521
   Coding: 0000208
   VCID: 71EE0E8668325AC916-8024
z góry wielkie dzięki za pomoc :)
Wszystkie błędy są opisane jako "Intermittent" - czyli sporadyczne, które wystąpiły kilka lat temu, jeżeli daty są wiarygodne. Na początek skasuj wszystkie te błędy, zrób jazdę testową (nawet kilka dni) i sprawdź ponownie. Prawdopodobnie żaden z nich nie powróci.
