Sign in to follow this
bsk123
Pomoc w rozkodowaniu błędów Pasat 2.0 TDI 170km DSG
    Samochód: B6 2.0 TDI-CR 170KM (CBBB) DSG
    Rok prod: 2009
    Koledzy proszę pomóżcie rozkodować mi błędy z VCDS. Poniżej załączam logi. Jestem świeżym użytkownikiem Pasata także proszę o wyrozumiałość
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 QG    HW: 03L 907 309
       Component: R4 2,0L EDC G000AG  3736
       Revision: 13H01---    Serial number: VWZCZ000000000
       Coding: 0000078
       Shop #: WSC 84224 536 673448
       VCID: 7AFC29AA35441991A7-802E
    3 Faults Found:
    001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
                   P0544 - 000 - Circuit Malfunction - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 2
                        Fault Frequency: 9
                        Reset counter: 255
                        Mileage: 81177 km
                        Time Indication: 0
                        Date: 2012.02.17
                        Time: 20:05:09
                 Freeze Frame:
                        RPM: 1518 /min
                        Speed: 74.0 km/h
                        Voltage: 13.91 V
                        Temperature: 87.3°C
                        Temperature: 930.0°C
                        Temperature: 264.0°C
                        Temperature: 252.0°C
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 9
                        Reset counter: 255
                        Mileage: 81177 km
                        Time Indication: 0
                        Date: 2012.02.17
                        Time: 20:05:09
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early - Intermittent
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 9
                        Reset counter: 255
                        Mileage: 81177 km
                        Time Indication: 0
                        Date: 2012.02.17
                        Time: 20:05:09
    Readiness: 0 1 0 0 0
    Address 02: Auto Trans        Labels: 02E-927-770.clb
       Part No SW: 02E 300 051 T    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1912
       Revision: 04844002    Serial number: 00000812220899
       Coding: 0000020
       Shop #: WSC 05311 000 00000
       VCID: 244037D2E740BF61AD-8070
    1 Fault Found:
    02084 - Component Protection
                000 -  -  - Intermittent
                 Freeze Frame:
                        Fault Priority: 0
                        Fault Frequency: 255
                        Reset counter: 3
                        Mileage: 81186 km
                        Time Indication: 0
                        Date: 2012.02.18
                        Time: 07:16:07
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 T    HW: 3C0 614 109 T
       Component: J104    C4 440 V2   0013
       Revision: --025---    Serial number: 00000795058234
       Coding: 0000301
       VCID: 2F6AC8FEBE860C3940-807A
    No fault code found.
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 DK    HW: 3C0 907 044 DK
       Component: ClimatronicPQ46 133 0909
       Revision: 00133024    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 6DD612F6740ABE2932-8038
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
       Component: Bordnetz-SG     H54 2602
       Revision: 00H54000    Serial number: 00000009343032
       Coding: EF8A8F0700041A00470A00000F000000000B5D435C000120000000000000
       Shop #: WSC 00510 259 91722
       VCID: 3362C48E52AE28D924-8066
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 221008 004  0206
       Coding: 00046997
       Shop #: WSC 00510
       Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
       Component: RLS     110209 054  0402
       Coding: 00208936
       Shop #: WSC 00510
    2 Faults Found:
    02399 - Control Circuit for Terminal 30 for Interior Illumination
                009 - Open or Short to Ground - Intermittent
                 Freeze Frame:
                        Fault Status: 00111001
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 14
                        Mileage: 82371 km
                        Time Indication: 0
                 Freeze Frame:
                            OFF
                        Voltage: 12.35 V
                            OFF
                            OFF
                            OFF
                            OFF
                            OFF
    00059 - Terminal 30 for Interior Lighting
                012 - Electrical Fault in Circuit - Intermittent
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 1
                        Reset counter: 14
                        Mileage: 82371 km
                        Time Indication: 0
    Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
       Part No SW: 3C8 919 475 A    HW: 3C8 919 475
       Component: PARKHILFE 8K  H07 0009
       Revision: --------    Serial number: 08740903701432
       Coding: 100102
       Shop #: WSC 05314 000 00000
       VCID: 326CC18A6DB421D12F-8066
    2 Faults Found:
    01543 - Parking Aid Warning Chime (H15)
                 Freeze Frame:
                        Fault Status: 00101001
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 245
                        Time Indication: 15
                 Freeze Frame:
                        Temperature: 0.0°C
    01625 - Front Parking Aid Warning Chime (H22)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 245
                        Time Indication: 15
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
       Component: J234__005 VW10 HI   1916
       Revision: 20013000    Serial number: 003E2P323WGE
       Coding: 0012341
       VCID: 4480975207009F618D-8010
       Subsystem 1 - Serial number: 6332MTS601450339
       Subsystem 2 - Serial number: 6342MTS654470139
       Subsystem 3 - Serial number: 6351HTS67R1UV5KJ
       Subsystem 4 - Serial number: 6361HTS68F6UV5KR
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
       Part No SW: 3C0 953 549 AC    HW: 3C0 953 549 AC
       Component: J0527               0020
       Revision: 00026000    Serial number: 3C9953507CN
       Coding: 0001112
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           002 0030
    Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
       Part No SW: 3C0 920 871 T    HW: 3C0 920 871 T
       Component: KOMBI         H04 0107
       Coding: 160F00
       Shop #: WSC 05314 115 00000
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
       VCID: 3566FA9694DA36E90A-8060
    Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
       Part No SW: 3C0 907 530 L    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 3300P092160390
       Coding: FDA17F06000202002002
       VCID: 2A5CD9EA8564691197-807E
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
       Component:    IMMO         043 0383
       Revision: 00043000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       Subsystem 1 - Part No: 3C0 905 861 G
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 4
                        Fault Frequency: 4
                        Reset counter: 250
                        Time Indication: 0
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.clb
       Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
       Component: J386  TUER-SG FT    1517
       Revision: 72009005    Serial number: 00000568498112
       Coding: 0000245
       VCID: 6FEA08FE7E064C3900-803A
    1 Fault Found:
    00096 - Drivers Door Central Locking (Safe) Motor (V161)
                 Freeze Frame:
                        Fault Status: 00101100
                        Fault Priority: 3
                        Fault Frequency: 14
                        Reset counter: 23
                        Mileage: 81361 km
                        Time Indication: 0
                        Date: 2012.03.24
                        Time: 03:14:11
    Address 44: Steering Assist        Labels: 5N1-909-144.clb
       Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
       Component: J500__APA-BS KL.082 0502
       Revision: 1AH02254    Serial number: 00090080068102
       Coding: 0000258
       VCID: 397EF6A670C2D289EE-806C
    1 Fault Found:
    01288 - Terminal 30; Steering Assist
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 9
                        Fault Frequency: 1
                        Reset counter: 250
                        Mileage: 0 km
                        Time Indication: 0
                 Freeze Frame:
                            Term 15 On
                        RPM: 105 /min
                        Speed: 0.0 km/h
                        (no units): 2.0
                        Voltage: 10.70 V
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ46 ELV 043 0612
       Coding: 0191020051030E763004941570084FCE707801
       Subsystem 1 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HORN H08 9001
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    2 Faults Found:
    01135 - Interior Monitoring Sensors
                004 - No Signal/Communication - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 14
                        Mileage: 82371 km
                        Time Indication: 0
                        Date: 2012.04.20
                        Time: 18:52:19
    00323 - Vehicle Inclination Sensor (G384)
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 14
                        Mileage: 82371 km
                        Time Indication: 0
                        Date: 2012.04.20
                        Time: 18:52:19
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
       Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
       Component: J387  TUER-SG BT    1517
       Revision: 72009005    Serial number: 00000627689204
       Coding: 0000244
       VCID: 70E80B82633853C119-8024
    1 Fault Found:
    00110 - Right Mirror Turn Signal Lamp (L132)
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 254
                        Reset counter: 20
                        Mileage: 64364 km
                        Time Indication: 0
                        Date: 2009.08.14
                        Time: 15:58:45
    Address 53: Parking Brake        Labels: 5N0-907-801.clb
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   009       Serial number: 00000000250137
       Coding: 0000057
       VCID: 285823E29B685B0181-807C
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
                002 - Lower Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100010
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 0
                        Mileage: 81447 km
                        Time Indication: 0
                        Date: 2012.03.29
                        Time: 08:04:15
                 Freeze Frame:
                        Voltage: 10.90 V
                        Count: 52
                        Speed: 0.0 km/h
                        Hex Value: 0x12E0
                        Hex Value: 0x0001
                        Hex Value: 0x0101
    Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
       Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
       Component: AFS-Steuergeraet    0136
       Revision: 00H04000    Serial number:
       Coding: 2311169
       VCID: 3460C79257A02FE13D-8060
       Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000035
       Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul r    0004
       Coding: 00000035
    Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: Radio RCD510  036 0130
       Revision: 00000001    Serial number: VWZ1Z3I4214931
       Coding: 0500040004
       VCID: 65C66AD66CFA86697A-8030
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0307
       Revision: 41004101    Serial number: 00000000810329
       Coding: 0000208
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0307
       Revision: 41004101    Serial number: 00000000814521
       Coding: 0000208
       VCID: 71EE0E8668325AC916-8024
    z góry wielkie dzięki za pomoc :)
    Samochód: B7 2.0 TDI 140KM (CFFB) 4x4
    Rok prod: 2012
    Wszystkie błędy są opisane jako "Intermittent" - czyli sporadyczne, które wystąpiły kilka lat temu, jeżeli daty są wiarygodne. Na początek skasuj wszystkie te błędy, zrób jazdę testową (nawet kilka dni) i sprawdź ponownie. Prawdopodobnie żaden z nich nie powróci.
    Create an account
    Register a new account
    Sign in
    Sign In Now
