romeo9999
[Instrukcja] Montaż sterownika Climatronic z MY'08 i nowszych
Gość sebp75
no ja to wszystko rozumiem, ale co on robi, zamyka obieg czy jak ??
W rzeczy samej...
Ja dziś dalej kombinuje z panelami od B7
mam 2
1 3AA907044AN brak wyświetlania na OPS
błędy na nim
Cytuj
Monday,23,January,2012,09:18:36:37412
VCDS Version: Release 11.11.0
Data version: 20111111
Address 08: Auto HVAC Labels: None
Control Module Part Number: 3AA 907 044 AN HW: 3AA 907 044 AN
Component and/or Version: Climatronic 043 0202
Software Coding: 0010004002
Work Shop Code: WSC 00015 115 08193
ASAM Dataset: EV_Climatronic A01010 (VW46)
VCID: 7CFD8554EFF078E
6 Faults Found:
13701392 - Function Restricted due to Missing Message(s)
U1111 10 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 16
Reset counter: 35
Mileage: 319 km
Date: 2012.14.12
Time: 01:09:19
13701424 - Function Restricted due to Missing Message(s)
U1111 30 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 250
Mileage: 110623 km
Date: 2009.14.00
Time: 09:21:58
13701488 - Function Restricted due to Missing Message(s)
U1111 70 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 319 km
Date: 2016.14.20
Time: 02:49:38
13701504 - Function Restricted due to Missing Message(s)
U1111 80 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 319 km
Date: 2016.14.20
Time: 02:49:38
13701520 - Function Restricted due to Missing Message(s)
U1111 90 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 319 km
Date: 2016.14.20
Time: 02:49:38
13701536 - Function Restricted due to Missing Message(s)
U1111 A0 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 35
Mileage: 319 km
Date: 2016.14.20
Time: 02:49:38
2 3AA907044AG
ten działa dobrze ale generuje 1 błąd
Monday,23,January,2012,09:23:33:37412
Control Module Part Number: 3AA 907 044 AG HW: 3AA 907 044 AG
Component and/or Version: Climatronic H03 0303
Work Shop Code: WSC 00020 999 00000
VCID: 75EB9070D4DA296
Fault Codes have been Erased
1 Fault Found:
U1111 30 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 250
Mileage: 110623 km
Date: 2009.14.00
Time: 09:31:22
Potrzebuje pomocy co to może oznaczać
Dodatkowo Prosiłbym o zrzuty długiego kodowania panela bo jak ja wchodzę to wyrzuca error i po wejściu nie widać opisów który bit od czego jest???
... brak momunikacji z BCM-em
A co to oznacza?
Proszę zrzuty z kodowania panelu klimatyzacji 3AA907044F
uszkodzony panel?? czy źle podpięte przewody(nie przerabiałem instalacji)
a masz BCM-a ? Bo to od 2009/10 dopiero.
To samo było z panelami modelowymi 2011. Panele z softem do 0606 nie zgłaszały błedu, potem nowsze juz miały te
n bład. BCM - to Centralny elektryki, po prostu ten panel go szuka po CAN , bo BCM inaczej steruje juz poswietlaniem i to jest własnie ten błąd.
mam 3AA .. z Webasto i tez mam ten bład. Poprzednie panele z 2011 przerabiałem i miałem ponad rok panel z softem 0606 i było ok, ale nowszy juz zgłaszał bład, dlatego ludzie szukają starszych
Major ale ten panel Angelus528-a ma SW:0202
SW:0202
AN ma SW:202 a AG SW:303 a ten ostatni napewno jest z końca 12 roku
Marcin w swoim ma SW:101
Gościu od którego kupiłem ma jeszcze taki sam AG tylko starszy i z softem SW202
Edytowane przez Angelus
Przeciez to 2 rózne panele.
Soft 0606 do paneli z 2011 i cała reszta paneli z nr-em 3AA po 2012r
Sorki ale nie kumam, mam taki w domu 3AA907044AG (2011r.) z softem 0202, auto MJ2006, będzie chodził czy będzie sypał błędami jak dziki :).
To co szukać panela z 2011 roku????
Czy mając gateway z końcówką C :rozpacz i jak zmienię klimatronik na nowy, to czy wszystko będzie działać jak trzeba. Nie mam jeszcze RNS 510 :( chodzi o sam klimatronik ??
Tak
panel 3AA ...AJ miał błąd gdy na pokładzie był Bordnetz, a teraz gdy na pokładzie BCM wszystko śmiga bez najmniejszego błędu ;)
Panowie co to ten "humidity sensor" w kodowaniu?
Witam. Mam problem w swoim Tiguanie z climatronem. Otóż, w aucie fabrycznie był climatic, (auto z 2011r z USA) musialem tak czy inaczej wymienić całą nagrzewnicę więc stwierdziłem że jak już to na climatronik. Zakupiłem całą nagrzewnicę kompletną z wiązką (z dwiema kostkami do panelu sterowania) i silniczkami krokowymi,czujniki temperatury nawiewu w kratki i czujnik nasłonecznienia. Problem polega na tym,że wogóle sie nie uruchamia sterownik po włączeniu zapłonu. Auto stoi teraz u szpeca od elektroniki i mówi że go zakodował a i tak VCDS pokazuje brak komunikacji ze sterownikiem klimy. I teraz pytanie do Was, czy trzeba robić jakąś modyfikacje w dużej czarnej kostce z zasilaniem sterownika?
Nawet nie wiadomo który rok auta miałes i z jakiego roku kupiłes nagrzewnice z panelem i okablowaniem
W najgorszym wypadku .......ubili juz panel
Auto jest z 2011r, panel klimatrona jak i nagrzewnica z 2008r
Mam pytanie już mam panel klimi ten nowy 2 pokrętła mam to podłączone tak jak pisał bimbasz na pierwszej stronę ale chcę podłączyć nowy panel z b7 3 pokrętła jak to jest z kablami? Trzeba coś prerabiat?
Ten nowy panel z b7 działa już bez przerabiania kabli jest p&p.
