MaciejK
Błędy - prośba o pomoc w rozwiązaniu
Panowie po przeskanowaniu auta wyszły mi takie błędy:
1 Fault Found:
5523 - Engine Start Blocked by Immobilizer
P1570 00 [096] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
2 Faults Found:
13701440 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 15
Reset counter: 233
Mileage: 129061 km
Date: 2016.06.10
Time: 05:57:04
9478421 - Diagnostic Line for Front Air Blower
B10A1 15 [008] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 233
Mileage: 129108 km
Date: 2016.06.12
Time: 11:32:48
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 63
Reset counter: 234
Mileage: 128142 km
Time Indication: 0
Date: 2016.04.23
Time: 19:45:52
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
OFF
OFF
OFF
1 Fault Found:
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 2
Reset counter: 205
Mileage: 129059 km
Time Indication: 0
Date: 2016.06.09
Time: 21:55:51
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 66
Reset counter: 234
Mileage: 128142 km
Time Indication: 0
Date: 2016.04.23
Time: 19:45:50
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 2
Reset counter: 234
Mileage: 128493 km
Time Indication: 0
Date: 2016.05.28
Time: 09:51:59
4 Faults Found:
02864 - Passenger's Door Handle Touch Sensor Incorrectly Installed
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 219
Mileage: 128142 km
Time Indication: 0
Date: 2016.04.22
Time: 18:32:38
02866 - Rear Right Door Handle Touch Sensor Incorrectly Installed
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 142
Mileage: 128142 km
Time Indication: 0
Date: 2016.04.22
Time: 18:32:38
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 4
Fault Frequency: 254
Reset counter: 147
Mileage: 0 km
Time Indication: 0
00191 - Passenger's Door Handle Touch Sensor (G416)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 179
Mileage: 129280 km
Time Indication: 0
Date: 2016.06.24
Time: 14:21:41
Fault Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 5
Reset counter: 152
Mileage: 128142 km
Time Indication: 0
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
BBardzo proszę o pomoc w rozwiązaniu tych problemów.
Witam wszystkich na forum, Pacjent B6 1.9 BKC 2005r
Czy ktoś z forumowiczów miał taki problem z błędami? to są jedyne błędy, które wracają i prawdopodobnie wyładowują mi akumulator. Dodam że zaobserwowałem, że drzwi pasażera po odblokowaniu ich z pilota się nie otwierają, działa jedynie zamykanie oraz od czasu do czasu występują 3 piknięcia i nie da się zapalić samochodu i świecą kontrolki: czerwona kierownicy, od grzania świec.
Z góry dziękuje za pomoc
