Slimak Zgłoś #1 Napisano 3 Czerwca 2016 Witam, Dziś podłączyłem kabel i programem VLITE przeskanowałem, wyskoczyło coś takiego : VCDS-Lite Version: Release 1.2 Friday, 03 June 2016, 14:36:52:0 Chassis Type: 3B - VW Passat B5 Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,75,76,77 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Controller: 038 906 018 P Component: 1,9l R4 EDC 00SG 1623 Coding: 00002 Shop #: WSC 05314 VCID: 23396C8FA2CD 3 Faults Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - - 00626 - Shareware Version. To Decode all DTCs 31-00 - Please Register/Activate 00741 - Shareware Version. To Decode all DTCs 27-10 - Please Register/Activate - Intermittent Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL Controller: 8E0 614 111 AB Component: ABS 5.3 FRONT D00 Coding: 0273004281 Shop #: BB 24548 VCID: 5ECF1D7BC92F 1 Fault Found: 00285 - ABS Wheel Speed Sensor; Front Right (G45) 30-00 - Open or Short to Plus ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1J0-909-60x-VW3.LBL Controller: 1J0 909 607 A Component: AIRBAG VW3 S V04 Coding: 00065 Shop #: WSC 49743 VCID: 2B2984AFCA1D 1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3B0-919-xxx-17.LBL Controller: 3B0 919 861 J Component: KOMBI+WEGFAHRS. MM4 V12 Coding: 04140 Shop #: WSC 78433 VCID: 311596C7E831 Ident.-Nr. Wegfahrs.:VWZ5Z0W2192233 1 Fault Found: 00667 - Ambient Temperature Signal 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1J0-959-799.LBL Controller: 1J0 959 799 F Component: 0A Zentral-SG Komf.0002 Coding: 00257 Shop #: WSC 05311 VCID: 41F5C6075891 4 Faults Found: 00930 - Locking Module for Central Locking; Rear Left (F222) 27-10 - Implausible Signal - Intermittent 00931 - Locking Module for Central Locking; Rear Right (F223) 27-10 - Implausible Signal - Intermittent 01030 - Central Locking Key Switch; Driver Side; Lock 29-00 - Short to Ground 00928 - Locking Module for Central Locking; Front Driver Side (F220) 27-10 - Implausible Signal - Intermittent End -------------------------------------------------------------------------------------------------- Wiem, że kod 00930 dotyczny problemu z zamkami, innym nie mogę zlokalizować na forum. Dodam, że mam problem z drzwiami - metoda na zamknięcie auta : Wciśnięcie przycisku na panelu u kierowcy od zamykania drzwi, wciśnięcie rygla od pasażera (za kierowcą) zamknięcie drzwi i przekręcenie kluczyka. Pilot w ogóle nie działa od nowości, czasami dioda się zapali na pilocie gdy wcisne ale żadnej reakcji w samochodzie. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
yksi Zgłoś #2 Napisano 3 Czerwca 2016 Wiem, że kod 00930 dotyczny problemu z zamkami, innym nie mogę zlokalizować na forum. http://wiki.ross-tech.com/wiki/index.php/Special:Search?search=00285&fulltext=Uda%C4%87+si%C4%99 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Slimak Zgłoś #3 Napisano 3 Czerwca 2016 http://wiki.ross-tech.com/wiki/index.php/Special:Search?search=00285&fulltext=Uda%C4%87+si%C4%99 Niestety wszystkich błędów tam nie byłem w stanie zweryfikować. Czy ktoś może ma tak duża wiedzę i wie w jaki sposób mogę pozbyć się tych usterek? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
yksi Zgłoś #4 Napisano 3 Czerwca 2016 Niestety wszystkich błędów tam nie byłem w stanie zweryfikować. Kody błędów VAG.pdf Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Slimak Zgłoś #5 Napisano 3 Czerwca 2016 [ATTACH]145504[/ATTACH] Dziękuje Ci bardzo mi pomogłeś trzy błędy zweryfikowane : 928 Mechanizm zamka centralnego, drzwi kierowcy - F220 930 Mechanizm zamka centralnego, drzwi tylne lewe - F222 931 Mechanizm zamka centralnego, drzwi tylne prawe -F223 Jescze został 01030 - ma ktoś może informacje o tym ? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
yksi Zgłoś #6 Napisano 3 Czerwca 2016 Jescze został 01030 - ma ktoś może informacje o tym ? 1030 Przycisk klucza - strona kierowcy - zamknięty Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Slimak Zgłoś #7 Napisano 3 Czerwca 2016 1030 Przycisk klucza - strona kierowcy - zamknięty To by się teraz wszystko zgadzało - dzięki wielkie. Korzystam z VCDS - Lite - to odpowiedni program czy za czymś innym się rozejrzeć ? Co do problemów w moim Passacie, szukać pomocy tu czy do innego działu ? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
yksi Zgłoś #8 Napisano 3 Czerwca 2016 Program jak najbardziej odpowiedni,każdy inny będzie pokazywał to samo.Każdy z Twoich błędów jest inny i szukaj rozwiązań na forum w odpowiednich działach ,używaj szukarki.I jeszcze jedno-vag podpowiada niekoniecznie idealnie,czasami przyczyna jest tylko powiązana. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
