luck
Ocena - 1.8T AEB, brak mocy
to naprawde najlepszy sklep bo ten zawork kosztuje ok 200 pln w ASO . zacznij od zrobienia logów .
Witam!
Właśnie w moje ręce wpadł kabelek VAG KKL!
Na początek rzeprowadziłem Auto-Scan, a oto wynik:
VAG-COM Version: Release  311.2-N
1o9lo0m-n6r12p-o9ko4x-kkjahh-568f
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01     -------------------------------------------------------
  Controller: 8D0 907 557 T
  Component: 1.8L R4/5VT MOTR HS D04
  Coding: 04001
  Shop #: WSC 05314
3 Faults Found:
16487 - Mass Air Flow Sensor (G70): Signal too High
           P0103 - 35-10 - - - Intermittent
01262 - Solenoid Valve for Boost Pressure Control (N75)
           26-10 - Output Open - Intermittent
00544 - Maximum Boost Pressure Exceeded
Readiness: N/A
Address 03     -------------------------------------------------------
  Controller: 8E0 614 111 P
  Component: ABS/EDS 5.3 FRONT   D11
  Coding: 0273004133
  Shop #: BB 24304
No fault code found.
Address 08     -------------------------------------------------------
  Controller: 1J1 907 044
  Component: CLIMATRONIC      S  4.0
  Coding: 02000
  Shop #: WSC 05314
1 Fault Found:
01296 - Sensor for Vent Temperature: Center (G191)
           30-00 - Open or Short to B+
Skipping Address 15-Airbags
Address 17     -------------------------------------------------------
  Controller: 3B0 919 860 A
  Component: B5-KOMBIINSTR. VDO V06
  Coding: 00142
  Shop #: WSC 40193
  IMMO-IDENTNR: VWZ7Z0T0010492
Address 46     -------------------------------------------------------
  Controller: 3B0 959 799  A
  Component: Zentral-SG Komfort  V41
  Coding: 04097
  Shop #: WSC 05311
10 Faults Found:
01332 - Door Control Module: Passenger Side (J387)
           49-10 - No Communications - Intermittent
01331 - Door Control Module: Driver Side (J386)
00932 - Electric Window Motor: Drivers Side (V147)
00928 - Locking Module for Central Locking: Front Driver Side (F220)
           27-10 - Implausible Signal - Intermittent
00933 - Electric Window Motor: Passenger Side (V148)
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
00934 - Electric Window Motor: Rear Left (V26)
00930 - Locking Module for Central Locking: Rear Left (F222)
00935 - Electric Window Motor: Rear Right (V27)
00931 - Locking Module for Central Locking: Rear Right (F223)
End   -------------------------------------------------------
Ewidentnie widać tu problem z przepływomierzem:
problem skasowałem i po dynamicznej pjeździe już się nie pojawił.
To samo dotyczy problemu z zaworem N75:
po skasowaniu i przejażdżce błąd nie występuje.
Błąd przeładowania jest na miejscu, sądzę po tym, że chcąc sprawdzić czy turbo w ogóle coś pompuje zdjąłem jak pisałem kilka dni wcześniej wężyk z WG i przeładowało.
Błąd usunięty i już nie wrócił.
Nie mam w tej chwili możliwości zrobić logów dynamicznych.
Wklejam więc tylko log z postoju na biegu jałowym:
Log (kanały - 021,004)
Niepokoi wartość przepływki... :/ Ale czekam na waszą interpretację.
Za kilka godzin (późniejszym popołudniem) będę miał możliwość zrobienia logów dynamicznych. Porszę was o wskazówki jakie logi zebrać, żebyście mogli mi pomóc...
Z góry DZIĘKUJĘ!
Edytowane przez Krzewka
Wszystkie 3 błędy są błędami sporadycznymi. Zapewne odłączałeś przepływomierz, N75 (o tym wspominałeś), a trzeci
Co tam szukasz na 004 i 021 kanale??
Zaloguj dynamicznie 002, 007, 025.
PS. Widzę trochę niską temperaturę do logów rozgrzej dobrze silnik.
Właśnie sam nie wiem czego szukałem... Sory, nie doczytałem które kanały mam logować.
Oto nowe logi dynamiczne. Zrówno na LPG jak i na PB.
Log startowałem przy 1500 obr./min. na 3-cim biegu potem pedał w podłoge i tak aż do 5000 obr./min.
Tutaj wyniki na grupach 002 oraz 007:
LPG
PB
Pozdr!
Jak logujesz to przeciągaj przynajmniej do 5500 obr./min. a nawet 6000.
Podejrzyj na kanale 003 lub 004 jaką masz temperaturę przy dobrze rozgrzanym silniku.
Przepływomierz za mało mierzy i lambda coś szaleje przy pełnym otwarciu przepustnicy w dolnym zakresie obrotów, być może powoli się kończy.
Dorzucam logi z dołączonym kanałem 025, które zrobiłem kilka chwil temu.
LPG
PB
Za chwilę dorzucę temepratury. :)
Temperatura z kanału 003 chwilkę po wjechaniu do garażu na biegu jałowym:
Temp.
zeby byc na 100% pewnym to przydało by sie sprawdzic manometrem jakie jest cisnienie w układzie turbo w czasie logowania ,bo z logów widac ze wysterowanie n75 jest ok tylko przepływka mierzy jak w silniku wolnossacy czyli zdecydowanie za mało .kolejna rzecza sonda zaczyna powoli odchodzic do krainy wiecznego spokoju i gaz jest tragicznie wyergulowany .
Postaram się w najbliższym czasie zorganizować manometr bądź inny zegar i zmierzyć ciśnienie w układzie turbo podczas logu. O wynikach od razu dam znać, ale 0,6 bar. raczej się nie spodziewam...
Jeżeli chodzi o gaz to faktycznie nadaje się do regulowania. Mam tylko nadzięję że po tym zabiegu spalanie nie wzrośnie jakoś drastycznie...
Do rozpędzenia auta podczas jazdy na LPG do zebrania logów (3-ci bieg i do 5000 obr./min.) potrzebowałem aż 2 km, a na PB 1/4 drogi mniej...
Poza tym wystąpił inny problem...
Podczas pracy na biegu jałowym z katalizatora wydobywa się dźwięk, jakby blacha tłukła o blachę (strasznie uciążliwy). Najprawdopodobniej oberwał się wkład katalizatora i obija się w jego wnętrzu. Po dodaniu gazu do ok. 1300 obr./min. grzechotanie ustaje. Sądzę, że spaliny dopychają wkład do obudowy kata i go unieruchamiają. Jutro biorę się za demontaż.
Przeczytałwm całe mnóstwo tematów na ten temat i chyba najlepszym wyjściem będzie rozcięcie puszki kata, wudłubanie wkładu, wspawanie kwasoodpornej rury 50 mm i zamknięcie szczelnie puszki, a następnie umieszczenie jej na miejscu. AEB ma jedynie 1 sonde lambda, nie powinno być kłopotu...
Wracając do braku mocy, jeżeli nie N75, nie DV (który jest absolutnie szczelny), nie nieszczelność w układnie doładowania, to co może być problemem? Przepływka? Można ją wyczyścić? Wiem, że w TDI warto... A jak to się ma do AEB turbo? "Odchodząca w krainę wiecznego spokoju" sonda lambda? Do wymiany, to pewne.
Czekam na dalsze sugestie!
Poza tematem:
WIELKIE DZIĘKI ZA ZAINTERESOWANIE! Życzę wszystkim ludziom szukającym pomocy dot. swoich aut, aby trafiali na takie fora jak to. :)
Pozdrawiam!
jesli po zmierzeniu cisnienia doładowania okarze sie ze jest ok to wymiana przepływki i sondy załatwi sparwe . co do mycia mozesz spróbowac ale z doswiadczenia wiem ze to nie pomaga .
Ok, więc załatwię manometr i zmierzę co trzeba. Mam nadzieję, że jednak będzie to 0,6 a przynajmniej 0,5 bar.
Dzięki!
Ja obstawiam na luźny zawór westgate który na wolnych obrotach powinien być zamknięty.
Czy taki luźny zawór można naprawić bez oddawania turbo do regeneracji? I czy to on może być powodem hałasu? Jeszcze 2 dni temu tego nie było, a mocy brakuje odkąd kupiłem auto robiąc nim do tej pory ok. 4000 km.
Poza tym, kiedy "bawię się" gazem na postoju i podbijam go do 2200 obr./min. po czym spada do 1500 obr./min. i tak kilka razy to słychać świst turbo, który z resztą jest bardzo przyjemny, a całe auto ugina się prawą stroną do ziemi. :)
Ale właśnie nie wiem, czy teń świst na postoju jest na miejscu...
Wydaje mi się, że turbo powinno raczej zaczynać pracować dopiero pod obciążeniem.
Otwarty, gdyby był zamknięty spaliny trafiały by na łopatki turbiny co powodowało by jej pracę na wolnych obrotach.
Być może klapka WG była luźna na początku jak kupiłeś, a teraz całkiem jest oderwana i dzwoni w kacie. Zdejmij kata z turbiny i wszystko się okaże.
Kolega Alvares kiedyś robił przeszczep poczytaj ;)http://forum.vw-passat.pl/threads/66277-prosze-o-analize-AEB-przeplywka-N75-DV
Edytowane przez Grucha...
Czytałem ten temat i nic więcej nie przychodzi do głowy, tylko pogratulować samozaparcia koledze Alvaresowi. Kawał dobrej roboty. :)
Ok, więc jutro turbo powędruje z auta na stół operacyjny. :)
O wynikach dam znać bliżej wieczora.
Pozdrawiam! :)
Witam ponownie!
Po demontażu turbo w moim Passacie na całe szczęście ujrzałem całą i zdrową klapkę WG. :) Gruchotającym elementem okazał się katalizator, który w całości się oberwał i "latał" po puszce. Wypalony w ponad połowie! Kat wypatroszony a w jego wnętrze wspawana rura 50 mm a w jej wnętrzu na odcinku ok 0,5 cm wspawana węższa 30 mm tulejka celem ograniczenia hałasu.
"Naprawa" pomogła. Auto nie grzechocze, pracuje równo i cicho, a nawet odrobinę ożyło. :)
Przy okazji mając turbo na wierzchu sprawdziłem jak się miewa.
Zawór WG sprawny, klapka również. Nie ma żadnych luzów w odchyleniu, mogłem nią jedynie lekko obracać.
Turbina posiada delikatne luzy promieniowe (ok 0,5 mm) i wzdłuż osi wirnika (również ok 0,5 mm), a ponadto delikatnie zarzuca olejem od strony zimnej. Na przewodzie TIP pojawił się ponownie film olejowy (przewód czyszczony ok 400 km temu) jednak mimo to auto bierze jedynie niewielkie ilości oleju. Po przejechaniu ok 4000 km na nowym mineralnym Castrolu GTX 10W50 (olej poprzedniego właściciela, a sam nie chcę się bawić w kombinacje z olejami i jego zmianę, bo nie zawsze wychodzi to na dobre) dolałem kilka dni temu ok 150 - 200 ml (olej na bagnecie czyściutki, niemalże jak prosto z bańki).
Poza tym wszystko w normie, więc szukam manometru i biorę się do mierzenia ciśnienia w dolocie i dalej pracujemy nad zaginionymi konikami. :)
Nowa przepływka (jeżeli czyszczenie starej nie pomoże) i sonda lambda trafią na miejsce w przyszłym tygodniu. :)
Pozdr!
Gość viktoras
Witam, Krzewka udało się rozwiązać problem?
Edytowane przez viktoras
Gość MaTT_ZST
Kupiłem 1.8T i się rozczarowałem dynamiką. Jeździłem AWT (ja kupiłem AEB) i wbija w siedzenie, a w moim nic się nie dzieje. :P
Wciskam gaz do dechy i się rozpędza jak autko bez turbo, dopiero (np: na 2 biegu) w okolicach 4-4,5 tyś obrotów czuć mocniejsze wbicie.
Do 140km/h nie było problemu z rozpędzeniem ale mam wrażenie że powinno być szybciej.
Od tygodnia raz jeden jedyny wyskoczył mi jakiś błąd 00575, wykasowałem go i już się nie pojawia.
Nie wiem może jestem przyzwyczajony do 2.0TDi, ale prawdę powiedziawszy to zbiera się lepiej niż 1.8T. TDI na 2 biegu potrafi stracić przyczepność na mokrym, a tu but w podłogę i nic.
Wymieniłem filtry i świece.
Czyli co robić logi dynamiczne? Jakie muszą być spełnione warunki do wykonania poprawnych logów?
Dynamiczne na 3 biegu z butem w podłodze dla aeb grupa 002, 020, 025 coś tam bedzie widać.
Ja mam również problem z mocą. Zrobiłem logi: http://vaglog.rtnet.pl/zygnarowski_105845.html
Dwa pierwsze na benzynie, trzeci na LPG.
Zostały skomentowane, że przepływka i sonda ok, ale warto się przyjrzeć N75.
Co wy na to????
Gość MaTT_ZST
002, 020, 025 czy jak kolega wyżej 002, 007, 025? Czy może i te i te :P
