Krynio
prośba o analize kodów błedów
    Samochód: B4 1.9 TDI 90KM (1Z)
    Rok prod: 1996
    Chassis Type: 3B - VW Passat B5
    Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
    Address 01 -------------------------------------------------------
    Controller: 038 906 019 EK
    Component: 1,9l R4 EDC 0000SG 1367
    Coding: 00002
    Shop #: WSC 05314
    WVWZZZ3BZ2E004687 VWZ7Z0A3668260
    No fault code found.
    Address 03 -------------------------------------------------------
    Controller: 4B0 614 517 G
    Component: ABS/ESP front 1328
    Coding: 04255
    Shop #: WSC 05311
    Address 08 -------------------------------------------------------
    Controller: 3B1 907 044 H
    Component: CLIMATRONIC B5GP 0004
    Coding: 17000
    Shop #: WSC 05311
    1 Fault Found:
    01273 - Fresh Air Blower (V2)
    35-00 - -
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 3B0 920 846 A
    Component: KOMBI+WEGFAHRSP VDO V01
    Coding: 21115
    Shop #: WSC 00012
    Address 19 -------------------------------------------------------
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 05314
    Address 37 -------------------------------------------------------
    Controller: 1J0 919 887 A
    Component: Navigation BNO 0102
    Coding: 00000
    Shop #: WSC 05311
    1 Fault Found:
    00862 - Antenna for GPS Navigation (R50/R52)
    36-00 - Open Circuit
    Address 46 -------------------------------------------------------
    Controller: 1C0 959 799 A
    Component: 0Y Komfortgerát HLO 0003
    Coding: 00067
    Shop #: WSC 05311
    3 Faults Found:
    01044 - Control Module Incorrectly Coded
    35-00 - -
    00912 - Window Regulator Switch: Front Left (E40)
    27-10 - Implausible Signal - Intermittent
    00944 - Heated Exterior Mirror: Passenger Side (Z5)
    35-00 - -
    Address 56 -------------------------------------------------------
    Controller: 1J0 035 152 G
    Component: Radio BNO 0102
    Coding: 05405
    Shop #: WSC 05311
    2 Faults Found:
    00856 - Radio Antenna
    00852 - Loudspeaker(s): Front
    End -------------------------------------------------------
    najbardziej zalezy mi na analizie błędu klimatronika ponieważ niedziała wogle nawiew.
    Samochód: B5(3B) 1.9 TDI 110KM (AVG)
    Rok prod: 1999
    01273 Dmuchawa śwież powietrza V2 lub komputer J126 ster dmuchawą śwież powietrza
    00862 Antena R50/R52 nawigacji satelitarnej GPS. (przerwa inst. /zwarcie (+)
    01044 Niewłaściwie zakodowany (uszkodz.) komputer/!!! -diagnozowany moduł sterujący
    00912 Wyłącznik E40 podnośnika szyby przednich lewych drzwi-nieprawidłowy sygnał błąd sporadyczny
    00944 Ogrzewane lusterko zewnętrzna po stronie pasażera – Z5 (mata grzewcza/elektr)
    00856 Antena (radiowa). Zwarcie/przerwa w ciągłości przewodów – uszkodzona antena
    00852 Głośnik przedni - zwarcie przewodów (cewka głośnika) lub instalacji elektrycznej
    Rok prod: 1996
    a jeszcze mam pytanie jak sie zabrać za tą dmuchawe??
    Rok prod: 1996
    witam, mogłby ktoś opisać błedy bo w liscie kodów błędów nie znalazłem do wiekszości opisu.
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8E - Audi A4 B6
    Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
    Controller: 038 906 019 LF
    Component: 1,9l R4 EDC G000SG 4907
    Coding: 00002
    Shop #: WSC 63251
    WAUZZZ8E44A078294 AUZ6Z0C0229851
    1 Fault Found:
    17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
    P1586 - 35-10 - - - Intermittent
    Readiness: N/A
    Controller: 8E0 614 517
    Component: ABS/ESP front 4329
    Coding: 04155
    Shop #: WSC 06435
    1 Fault Found:
    00526 - Brake Light Switch-F
    36-10 - Open Circuit - Intermittent
    Controller: 8E0 820 043 AC
    Component: A4 Klimaautomat 1219
    Coding: 00000
    Shop #: WSC 63251
    Address 09 -------------------------------------------------------
    Controller: 8E0 907 279 F
    Component: int. Lastmodul RDW 0517
    Coding: 00001
    Shop #: WSC 63251
    Address 16 -------------------------------------------------------
    Controller: 8E0 953 549 N
    Component: Lenksáulenmodul 0611
    Coding: 02042
    Shop #: WSC 63251
    Controller: 8E0 920 950 J
    Component: KOMBI+WEGFAHRS. RB4 D37
    Coding: 00400
    Shop #: WSC 00353
    Address 45 -------------------------------------------------------
    Controller: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    Controller: 8E0 959 433 BC
    Component: Komfortgerát T3B 1311
    Coding: 07115
    Shop #: WSC 63251
    9 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    35-00 - -
    01573 - Alarm triggered by Door Contact Switch: Left Rear
    35-00 - -
    00955 - Key 1
    35-00 - -
    00956 - Key 2
    01559 - Drivers Door
    59-10 - Can't Unlock - Intermittent
    01562 - Right Rear Door
    Controller: 8E0 035 195 P
    Component: symphony II NP2 0152
    Coding: 01005
    Shop #: WSC 00352
    Samochód: Nie passat
    Rok prod: 1996
    17994 - elektrozawory (N144/N145): zwarcie do plusa
    00526 - Włącznik świateł hamowania -F
    1370 Załączenie alarmu przez czujnik ruchu wewnątrz pojazdu
    926 - Alarm przez. Czujnik pochylenia
    1369 Załączenie alarmu przez czujnik otwarcia klapy silnika
    1371 Załączenie alarmu przez czujnik otwarcia drzwi kierowcy
    1573 Alarm wywołany przez drzwi Kontakt Switch: lewy tylny
    955 Klucz 1
    956 Klucz 2
    01559 Sterownik drzwi
    01562 prawe tylne drzwi
    masz Ostro namieszane w module komfortu chyba moze byc zalany
    Rok prod: 1996
    wszystkie błędy ładnie sie usuneły i nie powróciły po ponownym sprawdzeniu, podejrzewam ze drzwi przez przymarzniecie nie chciały sie otworzyc i z tad te błedy:) a ten od elektrozaworu za co odpowiedzialny??
    Samochód: B3 1.6 72KM (1F)
    Rok prod: 1990
    Posiadam Paska B3 z 90 roku poj 1,6 benzyna + gaz, ostatnio miałem z nim problem a właściwie mam gdyż nagle podczas jazdy wszedł mi na wysokie obroty i tak trzyma tak na oko około 3 do 4 tysiaków. Silniczek krokowy mam nowy i jest dalej to samo.
    Zaobserwowałem iż trzpień z silniczka krokowego wysuwa się na maksa i już tak zostaje po odkręceniu silniczka jest w "miarę normalnie".
    Dzisiaj sprawdzałem błędy przez kody błyskowe i wyszło mi 2122 czyli brak sygnału obrotów co może za to odpowiadać ???? czy to będzie potencjometr przepustnicy i czy ktoś wie czy da się to naprawić czy w grę wchodzi tylko wymiana.
    Z góry dzięki
    Samochód: B6 1.9 TDI-PD 105KM
    Rok prod: 2006
    Około tygodnia temu zaczęła mi mrugać kontrolka od świec mniej więcej po 5-10 minutach jazdy, jest tak do dziś po odpaleniu i przejechaniu paru kilometrów zapala się ponownie.
    Zaczytałem błędy i pojawiło się coś takiego:
    Address 01: Engine
    Control Module Part Number: 03G 906 021 JQ
    Component and/or Version: R4 1,9L EDC G000SG 9071
    Software Coding: 0000071
    Work Shop Code: WSC 05311
    1 Fault Found
    008213 - Intake Manifold Flap Position Sensor (Bank 1): Implausible Signal
    P2015 - 000 - - - Intermittent
    Freeze Frame
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 10
    Time Indication: 0
    Date: 2010.01.27
    Time: 18:21:01
    Freeze Frame
    RPM: 2100 /min
    Speed: 52.0 km/h
    Load: 0.0 %
    Voltage: 14.29 V
    Duty Cycle: 82.9 %
    Duty Cycle: 0.0 %
    Temperature: 49.5°C
    Przy okazji zaczytywania błędów sprawdziłem filtr DPF i pokazywał około 26% zabrudzenia.
    Wczoraj dodatkowo zapaliła się kontrolka od oczyszczania DPF, tym razem jednak pokazuje około 50% zabrudzenia i mimo odpowiedniej jazdy nie oczyszcza się.
    Czy ma ktoś jakieś pomysły??
    Samochód: B6 2.0 TDI-PD 140KM 4x4
    Rok prod: 2006
    problem jest na kanale 18 z webasto pewnie swieczka ale z reszta mam problem
    prosze o pomoc
    VAG-COM Version: Release 704.1
    Data version: 20071016
    VIN: WVW Mileage: 156140km/97020miles
    Address 18: Aux. Heat Labels: None
    Part No: 1K0 815 007 BC
    Component: Standheizer 041 4303
    Coding: 0001012
    Shop #: WSC 76082
    3 Faults Found:
    01406 - No Flame
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 7
    Reset counter: 233
    Mileage: 155337 km
    Time Indication: 0
    Date: 2009.12.12
    Time: 11:21:54
    Freeze Frame:
    Start
    Temperature: 69.0°C
    Temperature: 69.0°C
    Voltage: 14.31 V
    01407 - Flame Extinguished
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 233
    Mileage: 155366 km
    Time Indication: 0
    Date: 2009.12.13
    Time: 16:39:26
    Freeze Frame:
    Start
    Temperature: 76.0°C
    Temperature: 77.0°C
    Voltage: 14.45 V
    02251 - Heater Unit Locked
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 193
    Mileage: 155750 km
    Time Indication: 0
    Date: 2010.01.26
    Time: 13:17:49
    Address 25: Immobilizer Labels: 3C0-959-433-25.LBL
    Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
    Component: IMMO 042 0383
    Part No: 3C0 905 861 F
    Component: ELV 026 0380
    3C0905861F ELV 026 0380
    2 Faults Found:
    02823 - Requirements for Locking the Steering Column Lock not met
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 246
    Mileage: 156020 km
    Time Indication: 0
    Date: 2010.02.10
    Time: 11:33:06
    02827 - Wake-Up request via ESP
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 246
    Mileage: 156020 km
    Time Indication: 0
    Date: 2010.02.10
    Time: 11:33:07
    Address 62: Door,Rear Left Labels: 1K0-959-703-GEN3.LBL
    Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
    Component: J388 TUER-SG HL 1111
    Coding: 0000144
    Shop #: WSC 05311
    2 Faults Found:
    01036 - Electric Window Thermal Protection Active; Rear Left
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 87
    Reset counter: 233
    Mileage: 155751 km
    Time Indication: 0
    Date: 2010.01.26
    Time: 14:04:21
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 4
    Fault Frequency: 6
    Reset counter: 245
    Mileage: 155720 km
    Time Indication: 0
    Date: 2010.01.14
    Time: 09:39:35
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.LBL
    Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
    Component: J389 TUER-SG HR 1111
    Coding: 0000144
    Shop #: WSC 05311
    2 Faults Found:
    01037 - Electric Window Thermal Protection Active; Rear Right
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 83
    Reset counter: 233
    Mileage: 155751 km
    Time Indication: 0
    Date: 2010.01.26
    Time: 14:03:47
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 109
    Reset counter: 248
    Mileage: 154737 km
    Time Indication: 0
    Date: 2009.12.02
    Time: 10:36:40
    częściowo odpowiem sobie sam
    drzwi to problem z płynnością otwierania szyb i w tym momencie wyskakuje bład
    do webasto pewnie problem z palnikiem
    tylko jeszcze ten Immobilizer co on chce to nie wiem ??
    Edited by kedzior12
    Samochód: B3 2.0 115KM (2E)
    Rok prod: 1992
    Witam, zakupiłem kabelek, podpiełem się i ani silnika ani nic nie mogłem zdiagnozować jedynie na Auto Scan wyszły mi takie błędy:
    VAG-COM Version: Release 409.1-US
    Chassis Type: 31 - VW Passat B3
    Address 02: Auto Trans
    Controller: 095 927 731 AM
    Component: DIGIMAT 0636
    Coding: Diagnose VW
    10 Faults Found:
    00258 - Solenoid Valve 1 (N88)
    00260 - Shareware Version. To Decode all DTCs
    36-10 - Please Register/Activate - Intermittent
    00262 - Shareware Version. To Decode all DTCs
    00264 - Solenoid Valve 4 (N91)
    00266 - Shareware Version. To Decode all DTCs
    00270 - Shareware Version. To Decode all DTCs
    00293 - Multi-function Switch (F125)
    25-10 - Unknown Switch Condition - Intermittent
    00300 - Shareware Version. To Decode all DTCs
    34-10 - Please Register/Activate - Intermittent
    00263 - Shareware Version. To Decode all DTCs
    04-10 - Please Register/Activate - Intermittent
    65535 - Internal Control Module Memory Error
    00-10 - - - Intermittent
    End --------------------------------------------------------------------------------------------------
    Z opisu kodów przetłumaczyłem te błędy:
    00258 P0753 Przełącznik Cewki 1 – otwarty obwód lub skrót do uziemienia lub B+ (N89)
    00260 P0758 Przełącznik cewki 2 – otwarty obwód lub skrót do uziemienia lub B+ (N89)
    00262 P0763 Przełącznik cewki 3 – otwarty obwód lub skrót do uziemienia lub B+ (N90)
    00264 P0748 Przełącznik cewki 4 – otwarty obwód lub skrót do uziemienia lub B+ (N91)
    00266 P0773 Przełącznik cewki 5 – otwarty obwód lub skrót do uziemienia lub B+ (N92)
    00270 P1778 Przełącznik cewki 7 – otwarty obwód lub skrót do uziemienia lub B+ (N94)
    00293 P0705 Wielofunkcyjny przełącznik zakresu transmisji – usterka (wyjście PRNDL) (F125)
    00300 P0712 Czujnik obwodu niskiego poziomu wejścia temperatury transmisji płynów (G93)
    00300 P0713 Czujnik obwodu wysokiego poziomu wejścia temperatury transmisji płynów (G93)
    00263 Transmisja 0107 – usterka mechaniczna / hydrauliczna
    Ale nic z tego nie rozumiem :( dodam że robiłem to na zapalonym aucie, nie wiem czy to nie błąd
    Rok prod: 2004
    Te wszystkie "cewki" to są zawory. Diagnostykę trzeba przeprowadzać z włączonym zapłonem. a nie trzeba odpalać.
    A co do tego, wewnętrzny błąd pamięci sterownika. Może to być uszkodzony bądź zamoczony sterownik, albo uszkodzone przewody do sterownika.
    ---------- Post added at 01:44 ---------- Previous post was at 01:43 ----------
    Wykasuj błędy i sprawdź które powróciły. :)
    Samochód: B5(3BG) 1.9 TDI-PD 131KM (AWX)
    Rok prod: 2004
    Proszę o rozszyfrowanie błędu
    Control Module Part Number: 038 906 019 KE
    Component and/or Version: 1,9l R4 EDC G000SG 4898
    Software Coding: 00005
    Work Shop Code: WSC 05314
    1 Fault Found:
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    Rok prod: 2010
    17964 - Negative Deviation
    Zła orientacja sexualna turbiny :D Moze to jest ten TURBIN :diablica
    A tak na poważnie, to:
    17964 - Przekroczona w dół - granica regulacji układu regulacji ciśnienia doładowania - błąd sporadyczny - czyli występujący NIE W SPOSÓB CIĄGŁY.. Sprawdź zawór elektromagnetyczny ograniczenia ciśnienia dołądowania. Czy jest sprawny i czy nie ma gdzieś przerwy w obwodzie
    Rok prod: 2004
    Ok Tylko w którym miejscu go szukać Czy przyczyna może być że wymieniałem filtr powietrza i gdzieś naderwałem jakieś kabelki
    Rok prod: 2010
    No przede wszystkim sprawdź wszystkie węzyki przy turbince i silniku - moze któryś jest luźny, przetarty, pęknięty i ma dziurę , opaska nie dociska tak, jak powinna....itp.
    Rok prod: 2004
    WIELKIE DZIĘKI ZA POMOC . Usterka zlokalizowana - wypięty wężyk podciśnienia turbiny Usterka usunięta Teraz tylko wykasować błąd
    Edited by tomkitomki
    Rok prod: 2005
    ponieważ nie znalazłem nigdzie opisu moich błędów to pozwoliłem przykleić się tutaj. Po analizie VAGiem pokazały się nast.błedy:
    Adres 77: Telefon Plik etykiet: 3C0-035-729.lbl
    Oznaczenie elementu: 3C0 035 729 E HW: 3C0 035 729 E
    Komponent i/lub wersja: Telefon 5509
    Kodowanie: 0016043
    Kod serwisu: WSC 05311 000 00000
    2 - ilość znalezionych błędów. Oto one:
    01530 - Wyciszanie radia
    009 - Przerwa / zwarcie z masą
    Ramka zamrożona:
    Stan błędu: 01101001
    Priorytet błędu: 3
    Częstość błędu: 1
    Wew.licznik błędów: 92
    Przebieg: 155985 km
    Wskaźnik czasu: 0
    Data: 2010.03.05
    Czas: 10:44:01
    01042 - Sterownik niezakodowany
    000 - -
    Ramka zamrożona:
    Stan błędu: 00000000
    Priorytet błędu: 3
    Częstość błędu: 0
    Wew.licznik błędów: 0
    Wskaźnik czasu: 1
    Może mi ktoś pomóc co z tym zrobić i jak to zakodować?
    Ponadto, ponieważ od niedawna mam dostęp do VAG-a i nie dokońca umiem się nim jeszcze posługiwać to mam następujące pytania:
    1. Co oznacza pozycja kodowanie ..............i tu jakieś nr
    2. Co to jest kod serwisu np o nr WSC 05311
    3. Jak chciałem wejść w opcję 16-dostęp upow. to muszę podać jakiś nr ale nie wiem skąd go wziąć.
    Proszę o pomoc
    Samochód: B5(3B) 1.9 TDI 90KM (AHH)
    Rok prod: 1998
    Witam wymieniłem wtryski na nowe bo po wizycie na vagu odczytano błąd czujnika igły rozpylacza i kazano mi kupić nowe wtryski , bo wtrysk sterujący jest powodem że mruga mi kontrolka świec żarowych. Wtryski wymienione błąd wykasowany,auto pali na dotyk tylko trochę dużo spala . po czasie błąd powraca i tu powstał problem z którym dopiero teraz po wnikliwym rozpatrzeni nawet tych najstarszych postów doczytałem się że czujnik igły rozpylacza jest umieszczony w sterowniku głównym, a na wtrysku jest tylko cewka podająca impuls do sterownika [kasa poszła się ......]. Mam pytanie czy jest jakiś sposób aby to naprawić ,może trzeba by na nowo zaprogramować komputer czy muś być wymieniony na nowy [taki sam numer fabryczny].Proszę o jakieś podpowiedzi ewentualnie rozwiązania tego .Za wszystkie opinie i pomysły dzięki.
    Create an account
    Register a new account
    Sign in
    Sign In Now
