sebiastan Zgłoś #1 Napisano 15 Lutego 2011 Gdyby komuś chciało się odnieść co do znajomych błędów to będę wdzięczny.Sebastian Chassis Type: 3B - VW Passat B5 Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58 Address 01 ------------------------------------------------------- Controller: 038 906 019 GL Component: 1,9l R4 EDC G000AG 1495 Coding: 00001 Shop #: WSC 00237 WVWZZZ3BZ3E313409 VWZ7Z0B6616471 No fault code found. Address 02 ------------------------------------------------------- Controller: 01N 927 733 FC Component: AG4 Getriebe 01N 4945 Coding: 00000 Shop #: WSC 00000 No fault code found. Address 03 ------------------------------------------------------- Controller: 4B0 614 517 G Component: ABS/ESP front 1728 Coding: 04257 Shop #: WSC 05311 No fault code found. Address 08 ------------------------------------------------------- Controller: 3B1 907 044 H Component: CLIMATRONIC B5GP 0009 Coding: 17000 Shop #: WSC 05311 4 Faults Found: 00603 - Footwell/defroster Flap Positioning Motor (V85) 35-10 - - - Intermittent 01271 - Positioning Motor for Temperature Flap (V68) 35-10 - - - Intermittent 01274 - Air Flow Flap Positioning Motor (V71) 35-10 - - - Intermittent 01299 - Diagnostic Interface for Data Bus (J533) 79-00 - Please Check Fault Codes Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 3B0 920 827 A Component: KOMBI+WEGFAHRSP VDO V08 Coding: 05115 Shop #: WSC 00000 WVWZZZ3BZ3E313409 VWZ7Z0B6616471 1 Fault Found: 00779 - Outside Air Temp Sensor (G17) 30-00 - Open or Short to B+ Address 19 ------------------------------------------------------- Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 05314 No fault code found. Address 46 ------------------------------------------------------- Controller: 1C0 959 799 B Component: 7X Komfortgerát HLO 0003 Coding: 00259 Shop #: WSC 05311 1 Fault Found: 00928 - Locking Module for Central Locking: Front Driver Side (F220) 27-10 - Implausible Signal - Intermittent Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
polonez15 Zgłoś #2 Napisano 15 Lutego 2011 Niemalże wszystkie serwomechanizmy Climatronica mają błędy, czujnik temperatury zewnętrznej G17 zwarcie do plusa lub przerwa, centralny zamek drzwi kierowcy sygnał niezrozumiały. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Danek75 Zgłoś #3 Napisano 15 Lutego 2011 A wiesz co to jest SZUKAJ-ka? :fajny Wpisujesz kod błędu i czytasz. Gdyby komuś chciało się odnieść co do znajomych błędów A tobie co? Nie chce się? Wszystko masz na forum - wystarczy poszukać. A temat leci do kosza :dupablada Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
