stinger Zgłoś #1 Napisano 20 Grudnia 2010 (edytowane) Witam jak w temacie. Chodzi o to że po dłuższym postoju przy odpaleniu wchodzi na obroty sam i leci czarny dym. Po przeskanowaniu całym prezentuje sie to następująco. Prosze o pomoc co to może być? Pilnie! Dzięki z góry.:dobrze Thursday,09,December,2010,13:36:27:46862 Chassis Type: 9N - VW Polo Scan: 01 02 03 08 09 15 17 19 37 44 45 46 55 56 76 VIN: WVWZZZ9NZ3D120935 Mileage: 51060km/31727miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 036-906-034-APE.LBL Part No: 036 906 034 DD Component: MARELLI 4MV 4555 Coding: 00021 Shop #: WSC 31414 WVWZZZ9NZ3D120935 VWZ7Z0B6249519 1 Fault Found: 16502 - Engine Coolant Temp. Sensor (G62): Signal too High P0118 - 35-10 - - - Intermittent Readiness: 0010 0101 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: None Part No: 6Q1 937 049 C Component: 00 BN-SG. 1S33 Coding: 25742 Shop #: WSC 31414 1 Fault Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL Part No: 1C0 909 605 K Component: 0L AIRBAG VW51 0P 0006 Coding: 12364 Shop #: WSC 31414 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: None Part No: 6Q0 920 800 Component: KOMBI+WEGFAHRSP VDO V15 Coding: 01141 Shop #: WSC 00000 WVWZZZ9NZ3D120935 VWZ7Z0B6249519 1 Fault Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901.LBL Part No: 6N0 909 901 Component: 09 GATEWAY CAN 1S33 Coding: 00012 Shop #: WSC 31414 1 Fault Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: None Part No: 6Q0 423 156 R Component: LenkhilfeKYO V913 Coding: 10140 Shop #: WSC 31414 1 Fault Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 6Q0-959-433.LBL Part No: 6Q0 959 433 H Component: 1G Komfortgerát 0002 Coding: 00067 Shop #: WSC 31414 Part No: 6Q2959802A Component: 1G Tőrsteuer.FS TFK 0004 Part No: 6Q2959801A Component: 1G Tőrsteuer.BF TFK 0004 No fault code found. End -------------------------------------------------------------------------------------------------- Edytowane 20 Grudnia 2010 przez stinger Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Łysy Zgłoś #2 Napisano 20 Grudnia 2010 _tytul1 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mielke Zgłoś #3 Napisano 20 Grudnia 2010 (edytowane) 16502 czujnik temp cieczy G62 [ATTACH]42343[/ATTACH] 01314 brak połączenia ze sterownikiem sprawdź przewody doń i wtyczkę i bezpieczniki Edytowane 20 Grudnia 2010 przez mielke Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
stinger Zgłoś #4 Napisano 20 Grudnia 2010 O który chodzi i gdzie on jest? Jaki koszta takiego czujnika i czy to może być przyczyną takiego odpalania? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mielke Zgłoś #5 Napisano 20 Grudnia 2010 O który chodzi i gdzie on jest? Jaki koszta takiego czujnika i czy to może być przyczyną takiego odpalania? co do czujnika to podałem PDF co do sterownika to chodzi o [ATTACH]42347[/ATTACH] Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
AQT24 Zgłoś #6 Napisano 22 Grudnia 2010 Oczywiście to może byc przyczyną problemu z odpalaniem i jestem zdania,ze tak właśnie jest. Sprawdź go dokładnie i wymień sterownik. Powinno pomóc. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
