AdamUK
Oleje ktore pasuja do VW LongLife
Wszystkie oleje jakie znalazlem, ktore mozna stosowac do silnikow z systemem VW LongLive
Addinol Addinol Mega light MV0539 LE SAE 5W-30 50400/50700
Agip Agip 7008 SAE 5W-30 50400/50700
Agip Autol Carrera Longlife III SAE 5W-30 50400/50700
Aral Aral SuperTronic LongLife III SAE 5W-30 50400/50700
Aral Aral SuperTronic Longlife III SAE 5W-30 50400/50700
Astris Astris Matro L-3 SAE 5W-30 50400/50700
Avia Aviasynth 5W-30 longlife III SAE 5W-30 50400/50700
BP BP Visco 7000 Longlife III SAE 5W-30 50400/50700
Bucher AG Motorex Profile V-XL SAE 5W-30 50400/50700
Castrol Castrol Edge SAE 5W-30 50400/50700
Castrol Castrol SLX Longlife III SAE 5W-30 50400/50700
Castrol Castrol TXT 507 00 SAE 5W-30 50400/50700
Castrol Longlife III Hochleistungsmotorenöl SAE 5W-30 50400/50700
Castrol Castrol SLX Professional Powerflow
Castrol VW Longlife III SAE 5W-30 50400/50700
Castrol Castrol SLX Professional Powerflow LonSgAliEfe 5IIWI -30 50400/50700
Castrol Castrol SLX Professional LL03 SAE 5W-30 50400/50700
Castrol Castrol SLX Professional Longlife III SAE 5W-30 50400/50700
Castrol Castrol SLX LongLife III Topup SAE 5W-30 50400/50700
Cepsa CEPSA STAR TDI SYNT SAE 5W-30 50400/50700
Chevron Havoline Ultra V SAE 5W-30 50400/50700
De Oliebron Tor Extendo SAE 5W-30 50400/50700
Elf Elf Solaris LLX SAE 5W-30 50400/50700
Elf Elf Excellium TDI SAE 5W-30 50400/50700
ENI R&M Division Agip Formula FUTURE SAE 5W-30 50400/50700
Eurol Eurol Syntence Longlife SAE 5W-30 50400/50700
Eurolub Eurolub WIV ECO SAE 5W-30 50400/50700
FL Selenia Selenia Multipower Specs SAE 5W-30 50400/50700
Fuchs Fuchs TITAN GT1 Longlife III SAE 5W-30 50400/50700
Fuchs TITAN GT1 Pro C-3 SAE 5W-30 50400/50700
Galp energia Galp Formula Longlife III SAE 5W-30 50400/50700
Gamaparts GAMAPARTS Super LongLife III SAE 5W-30 50400/50700
Gulf Oil Gulf Formula GVX SAE 5W-30 50400/50700
Hunold Eurolub WIV ECO SAE 5W-30 50400/50700
Kuwait Petroleum Q8 Formula V Long Life SAE 5W-30 50400/50700
Liqui Moly Top Tec 4200 SAE 5W-30 50400/50700
Liqui Moly Liqui Moly Pro-Engine M 600 SAE 5W-30 50400/50700
Meguin megol Motorenoel Compatible SAE 5W-30 50400/50700
Millers Oils Millers XF Longlife SAE 5W-30 50400/50700
Mitan Alpine Longlife III SAE 5W-30 50400/50700
Mobil Mobil 1 ESP Formula SAE 5W-30 50400/50700
Mobil Mobil SHC Formula V SAE 5W-30 50400/50700
MOL MOL Dynamic Gold Longlife SAE 5W-30 50400/50700
Motul MOTUL Specific 50400 507 00 SAE 5W-30 50400/50700
MRD Motor GOLD Longlife III SAE 5W-30 50400/50700
Neste Oil Neste City Pro W LongLife III SAE 5W-30 50400/50700
New-Process AG New Process eco syn Plus SAE 5W-30 50400/50700
Oel-Brack Midland Crypto3 SAE 5W-30 50400/50700
OMV OMV eco extra SAE 5W-30 50400/50700
OMV OMV BIXXOL special V7 SAE 5W-30 50400/50700
Opet Opet Oxt Formula V 507 SAE 5W-30 50400/50700
Panolin Panolin Avanis SV-X SAE 5W-30 50400/50700
Pentosin Pento Super Performance III SAE 5W-30 50400/50700
Petronas Petronas Syntium 5000 AV SAE 5W-30 50400/50700
Ravensberger Schmierstoffvertriebe Rabvenol WIV III SAE 5W-30 50400/50700
Repsol Repsol Elite Longlife 50700/50400 SAE 5W-30 50400/50700
Rowe HIGHTEC ECOSYNT Longlife III SAE 5W-30 50400/50700
Shell Shell Helix Ultra VX SAE 5W-30 50400/50700
Shell Pennzoil Platinum VX SAE 5W-30 50400/50700
Shell Q European Engine VX SAE 5W-30 50400/50700
Shell Shell Helix Ultra LX SAE 5W-30 50400/50700
Shell Q Diesel Plus SAE 5W-30 50400/50700
Shell Shell Helix Ultra AP SAE 5W-30 50400/50700
Shell Shell Helix Ultra Extra SAE 5W-30 50400/50700
Shell Shell Helix Diesel Ultra Extra SAE 5W-30 50400/50700
Shell Vapsoil 507 SAE 5W-30 50400/50700
Slovnaft Madit Gold Longlife SAE 5W-30 50400/50700
SRS Schmierstoff Vertrieb Wintershall ViVA1 SLV plus SAE 5W-30 50400/50700
Startol Transit Diplomat Longlife III SAE 5W-30 50400/50700
Statoil Statoil LazerWay LL SAE 5-W30 50400/50700
SWD swd PRIMUS DPF SAE 5W-30 50400/50700
SWD Concep-Tech VX SAE 5W-30 50400/50700
SWD swd PRIMUS LLX SAE 5W-30 50400/50700
TACTI Corporation Castle Euaro 504 SAE 5W-30 50400/50700
Techno Tecar Motorenöl 504 00 / 507 00 SAE 5W-30 50400/50700
Texaco Havoline Ultra V SAE 5W-30 50400/50700
Total Total Quartz INEO 504-507 SAE 5W-30 50400/50700
Total Total Activa INEO SAE 5W-30 50400/50700
Total Gulf Progress Intensia SAE 5W-30 50400/50700
Unil Opal Opaljet Energy 3 SAE 5W-30 50400/50700
Valvoline Valvoline SynPower XL-III SAE 5W-30 50400/50700
VAPS Vapsoil 507 00 SAE 5W-30 50400/50700
Volkswagen Original Teile ® Volkswagen LongLife III SAE 5W-30 50400/50700
Würth Triathlon Endurance III SAE 5W-30 50400/50700
Yacco Yacco VX 2103 FAP SAE 5W-30 50400/50700
Zeller+Gmelin Divinol Syntholight 03 SAE 5W-30 50400/50700
Edytowane przez Łysy
trochę tego znalazłeś,na pewno komuś się przyda.
Staralem sie
ok a ja zadam jedno pytanie :)
nie wiem czy w dobrym wątku i jesli nie to proszę przenieść.
Jak kupilem mojego passata byl lany SHELL 5w30 longlife, zrobilem jedna wymianę wlalem MOTUL 5w40 z normą 505.01
Mam dość dobry układ w ASO i zaproponowali ze za dobrą cenę mogą mi lać longlife jakis olej 5w30, Powiedział gość ze jesli na wlepce jest QG1 to wtedy się nadaje. Tylko ze jak wtedy ma się norma 505.01 bo z tego co widzę wszystkie jakie podałes jest to 50400/50700
Moze pytanie dla jednych głupie ale ja juz przeczytałem tyle wiadomości o olejach ze mi się pomieszało :) Czy olej taki na 30 000 km nadaje się do silnika po chipie? Będę bardzo wdzięczny o wyrozumiałość i pomoc ;))
Edytowane przez kamilb
witam kolego a jak znalez czy ten silnik ma longlive mam vw passat 2003r 1.9 -130km i 6 biegowy combi
We wnęce koła zapasowego masz wklejoną kartkę i na niej jeśli jest kod QG1 to znaczy że jest serwisowany w systemie Long Life:)
:) tak to wyglada pozdrawiam
Chyba LONG LIFE! :)
_tytul1 :D
Bardzo przydatne zestawienie olejów silnikowych.
Chciałbym tylko jeszcze dodać, że norma VW 507.00 jest nowszą (wyższą)normą i zastąpiła poprzednią, czyli 506.01. Jeżeli ktoś ma starą instrukcję, gdzie podane jest, że nalezy stosować olej spełnaijący tylko VW506.01 (longlife), należy obecnie (chyba od połowy 2006 roku) używać VW 507.00
Witam troche odgrzeje jeszcze
Kupilem paske z niemiec i jak sadze byl serwiswany ystemie long life ma tez kod QG1 ma najechane 160kkm (osatni serwis przy 147kmm), w ksiazce wbite jest ze nastepny jest przy 180kkm ale ponizej jest adnotacja "Bremsflussigkeits-Service i tam date 02.2010
Dodam ze komputer podaje ze nastepny serwis za 16 kkm lub 530 dni i teraz pytanie czy w lutym mam cos zmieniac w sensie olej jak sadze czy cos wiecej? Lany jest o ile pamietam Castrol SLX 5w30 (chyba ten long life)
pozdro
Chyba chodzi o płyn hamulcowy.
Informacje dokładne na temat systemu long life są też na wklejce w ksiązce serwisowej, ale tutaj uwaga, bo inny olej jest przy zastosowaniu QG1 z DPF i bez DPf
tak samo np. w silnikach R5 i 5.0tdi teoretycznie tez jest QG1 a olej ma inną normę niż 507.00.
w wiekszosci juz przypadkow 507.00 zastapil pozostale normy, ale warto dokladnie to sprawdzic chociazby pod wzgledem, DPF - filtra czastek stalych oraz czy auto jest PD czy CR
jeśli kogoś zainteresuje to poniżej wkleiłem odpowiedź pracownika z firmy Castrol (Junior Technical&Training Specialist) na pytanie czy do Castrola 5w30 B4 (którego nie mogłem trafić) można dolać inny olej
Z Pańskiego opisu wnioskuję iż zastosowano Panu olej Castrol SLX Professional B4 5W-30. Olej ten jest produktem dedykowanym wyłącznie do autoryzowanych stacji obsługi i dlatego może mieć Pan problem z dostaniem tego oleju. Aby nie popełnić błędu powinien Pan stosować na dolewki olej zgodny z normą VW 507.00 lub 505.01. Poprawnym olejem może być olej w/w który posiada normę VW505.01 lub produkty wyższe z normami VW507.00 Castrol SLX Professional PowerFlow VW Longlife III 5W-30 który też jest sprzedawany w autoryzowanych serwisach. Ten olej będzie najlepszym produktem dla Pańskiego silnika. Ewentualnie można też zastosować Castrol EDGE 5W-30 który też posiada normę VW 507.00 oraz inne, jest produktem dedykowanym do sprzedaży detalicznej i jest produktem bardziej uniwersalnym.
Witam. Ja tak informacyjnie... Mam wlepkę z normą j/w a wymiana według kompa wyskakuje mi co 15 tyś.
Prawdopodobnie zostało to przestawione przez servis w Niemczech.
Mam 2.0 TDI 136KM (BGW) z DPF
W serwisie powiedzieli że mam lać CASTROLA EDGE 5W-30 SLX Professional LondLife III i leję :)
Mirek niekoniecznie jeśli serwis kasowany był za pomocą przycisków w licznikach to automatycznie przechodzi z LL na co 15tys. km.
W moim aucie, które odebrałem z salonu, nówkę, w lutym, przegląd był ustawiony na 15 tys., gdy we wrześniu pojechałem na przegląd (bo już "nakulałem" 15tys), to w oczekiwaniu na przyjęcie samochdu na przegląd, przeczytałem w książce gwarancyjnej właśnie wzmiankę o oznaczeniu QG1 na wklejce na początku książki. Zapytałem gościa w serwisie dlaczego wpisali mi przy wydawaniu samochodu, że przeglądy mam co 15 skoro fabrycznie został "przygotowany na LL" (czytaj: zalany olejem LL) i kiedy mogę przejść na LL. Gość powiedział, że na LL mogę przejść natychmiast nawet bez przeglądu - kwestia przeprogramowania komputera - zrobili to od razu, bezpłatnie. Zaznaczyli tylko, że samochód ma "czujnik jakości oleju" i jeżeli przed przebiegiem 30 tys. komputer pokaże, że mam wymienić olej to trzeba to zrobić. I tyle...
Zaznaczę, że mam Paska już z białymi zegarami, aczkolwiek wyprodukowanego pod koniec 2008.
W książce serwisowej są wypisane normy jakie spełniać musi olej na normelne przeglądy i LL. Na LL bezwględnie musi spełniać 507.00, na "krótkie" może mieć 505.00 i 507.00.
Co ciekawe np. Castrol Edge 5W30, który spełnia 507.00, może być stosowany zarówno do benzynowców i do diesli...
Ja tez mam wlepke z QP1, lany byl Castrol Long Life III chyba 5W30 a od ostatniego przegladu zarejstrowanego w serwisie ASO przy 166 tys przejechane ma 11tys i wyskoczyl serwis za 2tys km. Ale przestawione przy pomocy VAGa serwis za 17tys i zaprogramowanie na LongLife.
ja mam pytanie jeśli castrol ma napisane LongLife 2&3 to jest jakaś różnica w tym 2&3 a LL III czy to jest jakaś zasadnicza róźnica?
Edytowane przez porki
Gość reloop85
ja mam silnik na pompie VP i wczesniej byl zalany Castrol Longlife z norma 506.00, czy to teraz zostalo zastapione norma 507.00?
