JurekW
Oznaczenia skrzyń biegów B3-B4(35i)
Oznaczenia skrzyń biegów stosowanych w Passacie B3-B4(35i):
1988-1991
1992-1993
1994-1997
1.9 Diesel:
AFN _______CYP; DAB**, (81KW/110PS)____________________TDI
1Z ________ CTN; CHU; ASD; CTL; CKZ**; (66KW/90PS________TDI
AHU________ CTN; CKZ**; (66KW/90PS)____________________TDI
1Y__________ CHA; ARC**; AFE; AOG**; AYM; (50KW/68PS)_____Wolnossący
AAZ__________CHA; CAT; AOG**, (55KW/75PS)
* Syncro
** Automat 4-biegowy
*** Manual 4 biegowy
Ewentualnie trzeba by poszukać co było w Golfach.
I pozostałe
1.6 Diesel:
RA ------> AFF; AOG**; (59KW/80PS)
SB ------> AYP; AYY; AFF (59KW/80PS)
2.9 Benziner (VR6)*:
ABV -----> CSR*; (135KW/184PS) .................................................. .......................... => HA-Differential: CSS
2.8 Benziner (VR6):
AAA -----> CCM; CDM; CFF**; CLB**; DLL**; AGK; APB**; (128KW/178PS)
2.0 Benziner:
2E -------> CNL; CGY; CNK; CRU; AFE; AYK; APE**; (82-85KW/112-115PS)
9A -------> AGL; AFE; AGC; AYK; APE**; (100KW/136PS)............................................ ..........................16V
ADY ----> CRU; CNK; CNP**; CLK**; CGM*; CGX*; (85KW/115PS)
AGG ----> CRU; CLK**; DKS**; CGM*; CGX*; (85KW/115PS)
ABF -----> CMZ; CTM; (110KW/150PS).......... .................................................. .....................16V
1.8 Benziner:
AAM ---> CGX; AYH; (55KW/75PS)
RP ------> AFE; AGC; AYH; ARO**; (66KW/90PS)
ABS ----> CNA; CGX; CRR**; CSK**; (66KW/90PS)
PF ------> AFE; ARN**; AMA; (79KW/107PS)
PB ------> AMA; AFE; ARN**; (82KW/112PS)
KR ------> AFE; AGC; AYH; ARN**; (100KW/136PS)
PG ------> AWR*;CBC*; (118KW/160PS) .................................................. .................................................. "G60"
ADZ ----> CNA; CGX; CRR**; CSK**, CKX**; (66KW/90PS)
1.6 Benziner:
RF ---------> ALA***; ALS***; ALB***; ALY***; ASA ; ASB; ATW; ATX; AOF**; (53KW/72PS) ...............Vergaser
EZ/ABN --> ALA***; ALS***; ALB***; ALY***; ASA ; ASB; ATW; ATX; AOF**; AYH; (53KW/72PS) ......Vergaser
1F ---------> CGX; ALY***; ASA; ATX; ATW; AOF**; (55KW/75PS)
AEK ------> CJA; CKX**; (74KW/100PS)
AFT -------> CJA; (74KW/100PS)
skrzynia CTN i ASD różnia się przełożeniami na poszczególnych biegach , jedynie przełożenie przekładni głównej mają takie samo.
CYP - 1bieg 34/9 2bieg 33/16 3bieg 31/23 4bieg 29/30 5bieg 28/39
ASD - 1bieg 33/10 2bieg 35/18 3bieg 34/26 4bieg 33/36 5bieg 33/40
CTN - 1bieg 39/9 2 bieg 36/17 3bieg 34/25 4bieg 34/35 5bieg 34/45
Jak widać różnice są spore jedynie przekładnia główna we wszystkich ma przełożeni 60/19.
skrzynie biegĂłw 1988-1991.pdf
skrzynie biegĂłw 1991-1993.pdf
skrzynie biegĂłw 1993-1996.pdf
Edytowane przez rainman777
To nie jest nawet połowa skrzyń - mojej tutaj nie ma ( csr ) , nie ma też cgm , która też była montowana do vr6.
a które oznaczenia są do skrzyń automatycznych ?
Oznaczenia rodzaju skrzyni, tzn. automatyczna czy manualna są w drugiej rubryce od lewej.
4A - skrzynia automatyczna czterobiegowa
5S - skrzynia manualna pięciobiegowa
witam mam pytanie mam b3 1.8 1990 r
i jak jest zimny i go odpale to jest oki
jeśli się zrobi ciepły po 3 lub 5 minutach zgrzyta 2 bieg reszta oki
jeśli przełanczam z jedynki na 2 i jeśli powracam z większych biegów do 2
czy ktoś wie co jest nie tak jedni mówią że to ustawić na ciągadłach lub uszkodzony synchronizator
mam skrzynie od paska 20 l dohc czy skrzynia jest taka sama
Żeczywiscie nie zostaly tu wymienione chyba wszystkie skrzynie ;)
Koledzy szukam jednej bardzo ważnej informacji czy do silnika 9a podejdzie skrzynia wraz ze sprzęgłem z silnika 1.8 abs
Dzwony są takie same ale musisz sobie zdawać że te skrzynie mają różne przełożenia, tak więc to się nie bardzo zgrywa ;)
Tyle to i ja wiem jak ze sprzęgłem które w układzie silnika abs jest dość dziwne tzn nie ma łożyska oporowego nie będzie problemu ?
Czym różni się skrzynia biegów z 1,9td od tej z 1,9 tdi? czy można zostawić skrzynię od td po wstawieniu silnika 1,9 tdi?
witam mam pytanie mam passka b4 2.0 16v 150 km benzyna, jaką skrzynie można zamieć do niego bo na 1 biegu grechot słychać i mechanik mi mowił ze lepiej wymienic skrzynie niz tą jedynke naprawic
Chciałbym zapytać. Czy jak patrzę na skrzynię biegów od przodu, to po lewej stronie wybieraka mam taki nr 357 721 261. Czy to jest nr skrzyni? A w bagażniku na wlepie to na które oznaczenia patrzeć?
To jest numer siłownika wysprzęglającego ;)
Zernij tutaj =>http://forum.vw-passat.pl/showpost.php?p=372886&postcount=3
Gural wzorując się na wlepie którą zapodałeś, silnik to ABS a skrzynia CEW, ale na zdjęciach wyżej takiej skrzyni nie ma. Co to oznacza? Czy z innego paska z silnikiem ABS skrzynia podejdzie na pewno do mojego?
Jak nie ma, jak jest. dowód poniżej. ;)
Orientuje się może któryś z kolegów czy skrzynia biegów(AAA) od Sharana VR6 podejdzie do Passata B4 VR6? Chodzi o skrzynie manualną.
Edytowane przez gonek_t
Ok, dzięki za info.
Ogólnie mam zamiar zmienić skrzynię automatyczna na manuala i szukam jak najtańszej skrzyni, a od Sharana jest dużo i może się trafi coś niedrogo.
Szkoda, że na początku tematu w oznaczeniach skrzyń nie ma informacji do jakich aut były montowane. Wiedziałbym jakich zoznaczeń konkretnie szukać.
