JurekW Zgłoś #1 Napisano 18 Września 2008 (edytowane) Oznaczenia skrzyń biegów stosowanych w Passacie B3-B4(35i): 1988-1991 1992-1993 1994-1997 -------------------------------------------------------------------------------------------- 1.9 Diesel:AFN _______CYP; DAB**, (81KW/110PS)____________________TDI 1Z ________ CTN; CHU; ASD; CTL; CKZ**; (66KW/90PS________TDI AHU________ CTN; CKZ**; (66KW/90PS)____________________TDI 1Y__________ CHA; ARC**; AFE; AOG**; AYM; (50KW/68PS)_____Wolnossący AAZ__________CHA; CAT; AOG**, (55KW/75PS) * Syncro ** Automat 4-biegowy *** Manual 4 biegowy Ewentualnie trzeba by poszukać co było w Golfach. I pozostałe 1.6 Diesel: RA ----- AFF; AOG**; (59KW/80PS) SB ----- AYP; AYY; AFF (59KW/80PS) 2.9 Benziner (VR6)*: ABV ---- CSR*; (135KW/184PS) .................................................. .......................... HA-Differential: CSS 2.8 Benziner (VR6): AAA ---- CCM; CDM; CFF**; CLB**; DLL**; AGK; APB**; (128KW/178PS) 2.0 Benziner: 2E ------ CNL; CGY; CNK; CRU; AFE; AYK; APE**; (82-85KW/112-115PS) 9A ------ AGL; AFE; AGC; AYK; APE**; (100KW/136PS)............................................ ..........................16V ADY --- CRU; CNK; CNP**; CLK**; CGM*; CGX*; (85KW/115PS) AGG --- CRU; CLK**; DKS**; CGM*; CGX*; (85KW/115PS) ABF ---- CMZ; CTM; (110KW/150PS).......... .................................................. .....................16V 1.8 Benziner: AAM -- CGX; AYH; (55KW/75PS) RP ----- AFE; AGC; AYH; ARO**; (66KW/90PS) ABS --- CNA; CGX; CRR**; CSK**; (66KW/90PS) PF ----- AFE; ARN**; AMA; (79KW/107PS) PB ----- AMA; AFE; ARN**; (82KW/112PS) KR ----- AFE; AGC; AYH; ARN**; (100KW/136PS) PG ----- AWR*;CBC*; (118KW/160PS) .................................................. .................................................. "G60" ADZ --- CNA; CGX; CRR**; CSK**, CKX**; (66KW/90PS) 1.6 Benziner: RF -------- ALA***; ALS***; ALB***; ALY***; ASA ; ASB; ATW; ATX; AOF**; (53KW/72PS) ...............Vergaser EZ/ABN - ALA***; ALS***; ALB***; ALY***; ASA ; ASB; ATW; ATX; AOF**; AYH; (53KW/72PS) ......Vergaser 1F -------- CGX; ALY***; ASA; ATX; ATW; AOF**; (55KW/75PS) AEK ----- CJA; CKX**; (74KW/100PS) AFT ------ CJA; (74KW/100PS) skrzynia CTN i ASD różnia się przełożeniami na poszczególnych biegach , jedynie przełożenie przekładni głównej mają takie samo.CYP - 1bieg 34/9 2bieg 33/16 3bieg 31/23 4bieg 29/30 5bieg 28/39 ASD - 1bieg 33/10 2bieg 35/18 3bieg 34/26 4bieg 33/36 5bieg 33/40 CTN - 1bieg 39/9 2 bieg 36/17 3bieg 34/25 4bieg 34/35 5bieg 34/45 Jak widać różnice są spore jedynie przekładnia główna we wszystkich ma przełożeni 60/19. skrzynie biegĂłw 1988-1991.pdf skrzynie biegĂłw 1991-1993.pdf skrzynie biegĂłw 1993-1996.pdf Edytowane 28 Marca 2013 przez rainman777 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
kuban Zgłoś #2 Napisano 1 Kwietnia 2009 To nie jest nawet połowa skrzyń - mojej tutaj nie ma ( csr ) , nie ma też cgm , która też była montowana do vr6. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
b3tomek Zgłoś #3 Napisano 7 Grudnia 2009 a które oznaczenia są do skrzyń automatycznych ? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Grześko Zgłoś #4 Napisano 7 Grudnia 2009 a które oznaczenia są do skrzyń automatycznych ? Oznaczenia rodzaju skrzyni, tzn. automatyczna czy manualna są w drugiej rubryce od lewej. 4A - skrzynia automatyczna czterobiegowa 5S - skrzynia manualna pięciobiegowa Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
naprawa21 Zgłoś #5 Napisano 13 Grudnia 2009 witam mam pytanie mam b3 1.8 1990 r i jak jest zimny i go odpale to jest oki jeśli się zrobi ciepły po 3 lub 5 minutach zgrzyta 2 bieg reszta oki jeśli przełanczam z jedynki na 2 i jeśli powracam z większych biegów do 2 czy ktoś wie co jest nie tak jedni mówią że to ustawić na ciągadłach lub uszkodzony synchronizator mam skrzynie od paska 20 l dohc czy skrzynia jest taka sama Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Hansiu Zgłoś #6 Napisano 31 Marca 2010 Żeczywiscie nie zostaly tu wymienione chyba wszystkie skrzynie Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
archeolog Zgłoś #7 Napisano 8 Lipca 2010 Koledzy szukam jednej bardzo ważnej informacji czy do silnika 9a podejdzie skrzynia wraz ze sprzęgłem z silnika 1.8 abs Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
The_Saint Zgłoś #8 Napisano 9 Lipca 2010 Dzwony są takie same ale musisz sobie zdawać że te skrzynie mają różne przełożenia, tak więc to się nie bardzo zgrywa Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
archeolog Zgłoś #9 Napisano 9 Lipca 2010 Tyle to i ja wiem jak ze sprzęgłem które w układzie silnika abs jest dość dziwne tzn nie ma łożyska oporowego nie będzie problemu ? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
look1990 Zgłoś #10 Napisano 12 Lipca 2010 Czym różni się skrzynia biegów z 1,9td od tej z 1,9 tdi? czy można zostawić skrzynię od td po wstawieniu silnika 1,9 tdi? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
wytrych Zgłoś #11 Napisano 15 Lipca 2010 witam mam pytanie mam passka b4 2.0 16v 150 km benzyna, jaką skrzynie można zamieć do niego bo na 1 biegu grechot słychać i mechanik mi mowił ze lepiej wymienic skrzynie niz tą jedynke naprawic Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
papencjusz Zgłoś #12 Napisano 26 Września 2010 Chciałbym zapytać. Czy jak patrzę na skrzynię biegów od przodu, to po lewej stronie wybieraka mam taki nr 357 721 261. Czy to jest nr skrzyni? A w bagażniku na wlepie to na które oznaczenia patrzeć? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
GURAL Zgłoś #13 Napisano 26 Września 2010 to po lewej stronie wybieraka mam taki nr 357 721 261. To jest numer siłownika wysprzęglającego A w bagażniku na wlepie to na które oznaczenia patrzeć? Zernij tutaj http://forum.vw-passat.pl/showpost.php?p=372886&postcount=3 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
papencjusz Zgłoś #14 Napisano 26 Września 2010 Gural wzorując się na wlepie którą zapodałeś, silnik to ABS a skrzynia CEW, ale na zdjęciach wyżej takiej skrzyni nie ma. Co to oznacza? Czy z innego paska z silnikiem ABS skrzynia podejdzie na pewno do mojego? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
The_Saint Zgłoś #15 Napisano 26 Września 2010 Podejdzie, szukaj od ABS-a albo RP-ka, przełożenia będą się zgadzać. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
papencjusz Zgłoś #16 Napisano 26 Września 2010 ok dzięki. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
GURAL Zgłoś #17 Napisano 26 Września 2010 silnik to ABS a skrzynia CEW, ale na zdjęciach wyżej takiej skrzyni nie ma. Co to oznacza? Jak nie ma, jak jest. dowód poniżej. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
gonek_t Zgłoś #18 Napisano 4 Grudnia 2010 (edytowane) Orientuje się może któryś z kolegów czy skrzynia biegów(AAA) od Sharana VR6 podejdzie do Passata B4 VR6? Chodzi o skrzynie manualną. Edytowane 4 Grudnia 2010 przez gonek_t Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
The_Saint Zgłoś #19 Napisano 4 Grudnia 2010 Jeżeli to będzie sharan a nie galaxy, to tak. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
gonek_t Zgłoś #20 Napisano 4 Grudnia 2010 Ok, dzięki za info. Ogólnie mam zamiar zmienić skrzynię automatyczna na manuala i szukam jak najtańszej skrzyni, a od Sharana jest dużo i może się trafi coś niedrogo. Szkoda, że na początku tematu w oznaczeniach skrzyń nie ma informacji do jakich aut były montowane. Wiedziałbym jakich zoznaczeń konkretnie szukać. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
