rafal0584 Zgłoś #1 Napisano 10 Sierpnia 2008 Witam!!! Zrobilem wczoraj skan mojego passata, ponizej wstawiam log, czy ktos moglby rozszyfrowac kody bledow i wyjasnic mi o co kaman Z gory wielkie dzieki VAG-COM Version: Release 311.2-N Chassis Type: 3B - VW Passat B5 Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58 Address 01 ------------------------------------------------------- Controller: 038 906 019 GL Component: 1,9l R4 EDC G000SG 1495 Coding: 00002 Shop #: WSC 00267 WVWZZZ3BZ4E022563 VWZ7Z0B5973327 1 Fault Found: 17965 - Charge Pressure Control: Positive Deviation P1557 - 35-10 - - - Intermittent Readiness: N/A Address 03 ------------------------------------------------------- Controller: 4B0 614 517 G Component: ABS/ESP front 1728 Coding: 04255 Shop #: WSC 00111 1 Fault Found: 00526 - Brake Light Switch-F 27-10 - Implausible Signal - Intermittent Address 08 ------------------------------------------------------- Controller: 3B1 907 044 H Component: CLIMATRONIC B5GP 0008 Coding: 17000 Shop #: WSC 05311 5 Faults Found: 00603 - Footwell/defroster Flap Positioning Motor (V85) 35-10 - - - Intermittent 01271 - Positioning Motor for Temperature Flap (V68) 35-10 - - - Intermittent 01272 - Positioning Motor for Central Flap (V70) 35-10 - - - Intermittent 01274 - Air Flow Flap Positioning Motor (V71) 35-00 - - 01273 - Fresh Air Blower (V2) 35-10 - - - Intermittent Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 3B0 920 847 E Component: KOMBI+WEGFAHRSP VDO V08 Coding: 21115 Shop #: WSC 00111 WVWZZZ3BZ4E022563 VWZ7Z0B5973327 No fault code found. Address 19 ------------------------------------------------------- Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 05314 No fault code found. Address 37 ------------------------------------------------------- Controller: 1J0 919 887 A Component: Navigation BNO 0106 Coding: 00000 Shop #: WSC 05311 No fault code found. Address 46 ------------------------------------------------------- Controller: 1C0 959 799 A Component: 7W Komfortgerát HLO 0003 Coding: 00067 Shop #: WSC 05311 2 Faults Found: 01141 - Luggage Compartment Unlocking Switch (E165) 27-10 - Implausible Signal - Intermittent 00928 - Locking Module for Central Locking: Front Driver Side (F220) 27-10 - Implausible Signal - Intermittent Address 56 ------------------------------------------------------- Controller: 1J0 035 152 G Component: Radio BNO 0106 Coding: 05405 Shop #: WSC 05311 1 Fault Found: 01044 - Control Module Incorrectly Coded 35-00 - - End ------------------------------------------ Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
poldeczek1 Zgłoś #2 Napisano 10 Sierpnia 2008 to nie jest zaden log tylko odczyt bledow i jest ich w cholere szczegolnie w klimatroniku wywalilo bledy chyba wszystkich silniczkow sterujacych a co do silnika to turbo przeladowuje poszukaj na forum jest tego pelno prawdopodobnie zapieczone kierownice turbiny lub problemy z podcisnieniem lub elektrozaworkiem chyba n18 reszta to pierdolki pokasuj i zobacz ktore pojawia sie na nowo pzzdr. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
rafal0584 Zgłoś #3 Napisano 10 Sierpnia 2008 Mam jeszcze pytanko co moze byc przyczyną jak zapala mi sie na komputerze ikona o braku plynu w spryskiwaczach a jest go full??? paska mam tydzien czasu takze dopiero zaczynam z nim przygode Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
artuj Zgłoś #4 Napisano 10 Sierpnia 2008 Błędy Climatronika wykasuj - kiedyś już widziałem taka litanię, była spowodowana naprawami samochodu w trakcie których ktoś na moment włączył zapłon i się zaczęło. Ważne żeby znowu się nie pojawiły - jest napisane do reszty że błąd sporadyczny lub jednorazowy. Kolejna sprawa. Zostaw włączone światła, wyjmij kluczyk ze stacyjki i otwórz drzwi kierowcy - jeżeli nie będzie pisku informującego to masz problem z krańcówkami w drzwiach - szukaj na forum "mikrostyki", "zimne luty". Podobnie jeżeli nie zapala się oświetlenie wnętrza po otwarciu drzwi kierowcy, po zamknięciu samochodu nie mruga kontrolka przy "bolcu". Do reszty zainteresuje się stanem swojej turbiny. Szukaj na forum tematów "zapieczone kierownice", "n75", "tryb awaryjny" - nie ma sensu powtarzać tego samego. Pozdrawiam Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
rafal0584 Zgłoś #5 Napisano 10 Sierpnia 2008 nie ma pisku przy otwartych drzwiach, tak samo nie zapala sie lampka sufitowa jak otwieram drzwi kierowcy i lamki pod drzwiami nie pala sie w drzwiach kierowcy i lewych tylnych, sprawdzilem napiecie i jest bardzo slabe w tych drzwiach- nie ma nawet 1v, aha i nie dziala podswietlenie tablicy i wycieraczka tylna (kiedy powinna sie wlaczac?) gdzie szukac przyczyn tego wszystkiego ??? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
artuj Zgłoś #6 Napisano 10 Sierpnia 2008 Napisałem Ci wszystko - musisz użyć wyszukiwarki na forum posługując się słowami kluczowymi które Ci dałem. Jesteś w stanie to naprawić samemu, wystarczy trochę wolnego czasu i lutownica - opisy wraz ze zdjęciami, wszystko jest na tym forum - szukanie może Ci zająć nawet którąś godzinę ale chyba nie liczysz że zrobi to ktoś za Ciebie? Pozdrawiam Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
