judam
Park Assist 2.0 Pierwszy mój planowany mod czy da rade?
Więc zaczynam a raczej chciałbym zacząć od park assist 2. Tutaj skan mojego auta. Najważniejsze czy maglownica da rade ta? Reszta to już chyba drobnostki. Co jeszcze musiałbym wymienić?
Chassis Type: 3C0
Scan: 01 02 03 08 09 13 15 16 17 18 19 25 37 42 44 46 47 52 53 55
56 62 69 6D 72 76 77
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-018-BMN.lbl
Part No SW: 03G 906 018 EM HW: 03G 906 018 EM
Component: R4 2.0l PPD1.2 A 4369
Revision: --H42--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 12345 123 232322
VCID: 74E3D8E36C7B
No fault code found.
Readiness: N/A
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 044 L HW: 02E 927 770 AE
Component: GSG DSG 081 1402
Revision: 04608010 Serial number: 00000709030961
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 1E37DA4BB277
Address 03: ABS Brakes Labels: 3C0-614-109-C4.lbl
Part No SW: 3C0 614 109 E HW: 3C0 614 109 E
Component: J104 C4 440 V3 0003
Revision: --020--- Serial number: 00000775914515
Coding: 0000285
Shop #: WSC 05311 000 00000
VCID: 204BE4B38803
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CA HW: 3C0 907 044 CA
Component: ClimatronicPQ46 122 0708
Revision: 00122021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 62CFAEBBC68F
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000007611290
Coding: E78A8F4701041A00570000000F000000000B5D435C000180000000000000
Shop #: WSC 05124 000 00000
VCID: 71EDD1F71369
Subsystem 1 - Part No: 3C1 955 419 A
Component: Wischer 030907 003 0205
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AF
Component: RLS 270907 046 0204
Coding: 00208933
Shop #: WSC 05124
Address 13: Auto Dist. Reg Labels: None
Part No SW: 3C0 907 567 H HW: 3C0 907 567 H
Component: AC201 RDW 1 031 0119
Revision: 00031000 Serial number: 00000000014560
Coding: 0010000
VCID: 306B14F3D8E3
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
Component: 0D AIRBAG VW8 032 2522
Revision: 12032000 Serial number: 003B1PJJ7JAS
Coding: 0012356
VCID: 306B14F3D8E3
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 K HW: 3C0 953 549 K
Component: J0527 0015
Revision: 00006000 Serial number: 3C9953507BH
Coding: 0001222
VCID: 346318E32CFB
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 65536 645 577705
VCID: 2647F2ABEA27
Address 18: Aux. Heat Labels: 1K0-815-007.lbl
Part No: 1K0 815 007 BH
Component: Standheizer 042 4404
Revision: 00042000 Serial number: 09011075000000
Coding: 0001012
Shop #: WSC 49841 141 95350
VCID: 6BD1C39F3145
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 D HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1300Q07802017E
Coding: FD857F4E520E022002
Shop #: WSC 49883 141 173349
VCID: 224FEEBB860F
Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 397D29D70B99
Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
Part No: 1K0 919 887 F
Component: Navigation 0030
Coding: 0000101
Shop #: WSC 05314 000 00000
VCID: 3C7330C304AB
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000530678903
Coding: 0000245
VCID: 3B7133DF01A5
Address 44: Steering Assist Labels: 1Kx-909-14x-44.lbl
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.136 H08 1901
Shop #: WSC 02069 000 90108
VCID: 356525E72781
Address 46: Central Conv. Labels: 3C0-959-433-46.lbl
Component: KSG PQ46 ELV 042 0472
Coding: 00900A00D1030E763004941570084F0E707800
Shop #: WSC 49883 141 11342
VCID: 397D29D70B99
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Component: NGS n.mounted
Component: IRUE n.mounted
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 3C0 035 456 G HW: 3C0 035 456 G
Component: 08K Audioverst. 0006
Revision: 00003000 Serial number: 00000008119348
VCID: 2443E8A39C1B
1 Fault Found:
00870 - Bass Speaker Front Left (R21)
007 - Short to Ground
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000696478923
Coding: 0000244
VCID: 3C7330C304AB
Address 53: Parking Brake Labels: 5N0-907-801.lbl
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000182010
Coding: 0000057
VCID: 295DF997FB39
Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
Part No SW: 5M0 907 357 A HW: 5M0 907 357 A
Component: AFS-Steuergeraet 0001
Revision: H02 Serial number:
Coding: 2301953
VCID: 326F1EFBD6EF
Subsystem 1 - Part No: 7L6 941 329
Component: AFS-Lst.-Modul l X018
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X018
Coding: 00000035
1 Fault Found:
02628 - Sensor for Swivel Module Position; Right
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 4
Reset counter: 138
Mileage: 258636 km
Time Indication: 0
Date: 2017.04.07
Time: 10:17:37
Freeze Frame:
Voltage: 14.20 V
Speed: 130.0 km/h
ABS 1
Address 56: Radio Labels: 1K0-035-095.lbl
Part No: 1K0 035 095 G
Component: Radio 0030
Coding: 0012042
VCID: 295DF997FB39
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1119
Revision: 11006001 Serial number: 00000002377766
Coding: 0000208
VCID: 3D753DC71FB1
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 D HW: 1K0 907 383 B
Component: Anhaenger H15 0070
Revision: 3A002001 Serial number: 00000106940677
Coding: 0100000200000000
VCID: 2E570A8BC2D7
Address 6D: Trunk Elect. Labels: None
Part No SW: 3C9 827 383 B HW: 3C9 827 383 E
Component: J605 HECKDECKEL 0600
Revision: 00H21001
Shop #: WSC 23250 384 715754
VCID: 306B14F3D8E3
Part No: 3C9 827 384 B
Component: J756 HECKDECKEL 0600
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1119
Revision: 11006001 Serial number: 00000002388283
Coding: 0000208
VCID: 3E773ACB12B7
Address 76: Park Assist Labels: 3C0-919-283.lbl
Part No SW: 3C0 919 283 C HW: 3C0 919 283 C
Component: Parkhilfe 8-Kan 004 0013
Revision: 00004000 Serial number: 90630726403628
Coding: 0011024
VCID: 295DF997FB39
Edytowane przez judam
Przeniesiony do prawidłowego działu.
pewnie że możesz pla 2.0 jak wymienisz magiel i abs i parę *******
Wysłane z mojego SM-G935F przy użyciu Tapatalka
szczetke napisałeś chyba post nie czytając mojej specyfikacji.
Moja maglownica to z literką M i gdzieś czytałem że ponoć właśnie tylko ta z tego typu będzie odpowiednia. Szukam tutaj potwierdzenia czy to prawda.
No i chyba jednak się da. Jest możliwość w adaptacji ustawić park assist nawet DSR. Po adaptacji na park assist wywala błąd 2017-04-09 21.00.36.jpg
Błąd komunikacji z sterownikiem automatycznego pilota parkowania J791.
Czy dobrze mi sie wydaje że jeśli idzie zrobić adaptacje to będzie ta maglownica działała?
Do pla 2.0 musisz połowę elektryki zmienić
proszę o konkrety
Manglownica Ci podejdzie ale będzie przy parkowaniu szarpała, nie ma w niej płyności obrotu można zastąpić manglownice z golfa lub 5N1. Do wymiany pompa absu, czujniki abs, moduł parkowania, tunel z b7 z panelami i kupe roboty z elektryką
A jak to się ma w przypadku B7, bo też mi taki mod chodzi po głowie?
w b7 dokladka 4 pdc i wymianą sterownika pdc to wszystko
Ok. Dzięki za info. A kodowanie ?
Odgapimy z mojego.
Odgapimy z mojego.
Już porównywałem. Kwestia tylko czy kodujemy ABS, wspomaganie,i czy wymagana jest jakaś kalibracja?
Proponuje zrobić PLA1.5 i będzie git
Do pla 1.5 także potrzebna pompa od pla 2.0 . Do 1.0 trzeba sprawdzić czy ta obsłuży. Magiel obsłuży.
Wysłane z mojego GT-I9506 przy użyciu Tapatalka
A jaka jest różnica pomiędzy PLA1.5 a 2.0 ?
Ja pier piernicze
Chcesz się zabrać za takiego moda i jesteś zielony ?
1 i 1.5 to równolegle
2.0 to prostopadle i wyjazd
Ja pier piernicze
Nie stresuj się kolego. Dam radę. :) Chodziło mi tylko o potwierdzenie
a cos szerzej na temat opcji 'wyjazd'? jak mam to rozumiec? auto potrafi samo wyjechac z miejsca parkingowego? jesli tak to jak to uruchomic?
Jak zaparkowałeś za pomocą pla to żeby Ci wyjechał wciskasz przycisk od pla i wtedy dostaniesz komunikaty na fisie do wyjazdu (takie jak przy pakowaniu)
...a czy do tego wystarczy sterownik z końcówką "L" czy może "S"?
