gutek_24 Zgłoś #1 Napisano 24 Lutego 2017 Friday,24,February,2017,01:31:30:10074 VCDS Version: Release 11.11.2 (x64) Data version: 20120126 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3C0 Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 37 42 44 46 52 53 55 56 62 65 72 VIN: WVWZZZ3CZ9P024073 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: Malfunction 0010 14-Susp. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 1010 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Not registered 0001 72-Door, Rear Right -- Status: Malfunction 1010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03H-906-032-BLV.lbl Part No SW: 03H 906 032 AB HW: 03H 906 032 AB Component: P3.2-FSI-EU4 G00 2501 Revision: 5GH04--- Serial number: VWZCZ000000000 Coding: 0000175 Shop #: WSC 00028 028 00001 VCID: 62CFAEBBBD54903 No fault code found. Readiness: 0110 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-300-0xx.lbl Part No SW: 02E 300 011 CN HW: 02E 927 770 AJ Component: GSG DSG AG6 431 1802 Revision: 04843012 Serial number: 00000807240888 Coding: 0000020 Shop #: WSC 00028 028 00001 VCID: 5DB59D47842AAFB No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb Part No SW: 3C0 614 109 P HW: 3C0 614 109 P Component: J104 C4 440 V2 0011 Revision: --025--- Serial number: 00000785938499 Coding: 0000394 Shop #: WSC 00028 028 00001 VCID: 2B51039F8A1E11B 1 Fault Found 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3C0-907-044.lbl Part No SW: 3C0 907 044 DA HW: 3C0 907 044 DA Component: ClimatronicPQ46 132 0811 Revision: 00132023 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 63C1ABBFA24E99B 1 Fault Found 01809 - Actuating Motor for Temperature Flap; Left (V158) 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 254 Reset counter: 31 Mileage: 176156 km Time Indication: 0 Date: 2099.14.06 Time: 09:53:03 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl Part No SW: 3C8 937 049 E HW: 3C8 937 049 E Component: Bordnetz-SG H54 2602 Revision: 00H54000 Serial number: 00000005899137 Coding: F7868F0700041A00470000000F000000000B5D435C000120000000000000 Shop #: WSC 00567 048 00001 VCID: 33611BFF522E49B Subsystem 1 - Part No: 3C1 955 419 A Component: Wischer 110608 003 0205 Coding: 00046997 Shop #: WSC 00567 Subsystem 2 - Part No: 1K0 955 559 AF Component: RLS 110808 046 0204 Coding: 00471077 Shop #: WSC 00567 5 Faults Found 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 27 Reset counter: 19 Mileage: 186732 km Time Indication: 0 Freeze Frame: OFF Voltage: 11.80 V OFF ON OFF OFF OFF 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 27 Reset counter: 19 Mileage: 186732 km Time Indication: 0 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 3 Reset counter: 38 Mileage: 187453 km Time Indication: 0 Freeze Frame: OFF Voltage: 9.60 V OFF ON OFF OFF OFF 02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 38 Mileage: 187453 km Time Indication: 0 Freeze Frame: OFF Voltage: 9.80 V OFF ON OFF OFF OFF 00153 - Windshield Wiper Motor; Driver Side (V216) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 2 Reset counter: 38 Mileage: 187453 km Time Indication: 0 Freeze Frame: ON Voltage: 10.45 V ON ON OFF OFF ON ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: None Part No SW: 3C8 919 475 HW: 3C8 919 475 Component: PARKHILFE 8K H07 0007 Revision: -------- Serial number: 97530821905030 Coding: 100102 Shop #: WSC 00028 028 00001 VCID: F1ED51F728B2BBB 2 Faults Found 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 6 Fault Frequency: 1 Reset counter: 38 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:30:03 Freeze Frame: Temperature: 5.0°C 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 6 Fault Frequency: 3 Reset counter: 38 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:29:13 Freeze Frame: Temperature: 5.0°C ------------------------------------------------------------------------------- Address 14: Susp. Elect. (J250) Labels: None Part No SW: 3C0 907 376 HW: 3C0 907 376 Component: DAEMPFUNGS-SG H07 0069 Revision: 00000000 Serial number: 16070800130002 Coding: 010180 Shop #: WSC 00028 028 00001 VCID: E6C732AB117C6C3 4 Faults Found 03262 - Comfort Restriction 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 15 Reset counter: 253 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:28:59 Freeze Frame: Error Code: 2 Bin. Bits: 00000000 00000 - End of output 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 15 Reset counter: 253 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:28:59 00000 - End of output 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 15 Reset counter: 253 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:28:59 00143 - Right Front Dampening Adjustment Valve (N337) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 38 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:33:35 Freeze Frame: Bin. Bits: 00000000 10000000 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 5N0 959 655 HW: 5N0 959 655 Component: J234__017 VW10 HI 1815 Revision: 19013000 Serial number: 0039BPDCXP79 Coding: 0012599 Shop #: WSC 00028 028 00001 VCID: FAFF76DBB5C4F83 2 Faults Found 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 37 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:28:45 01222 - Crash Sensor Side Airbag; Passenger Side (G180) 010 - Open or Short to Plus - Intermittent - MIL ON Freeze Frame: Fault Status: 10101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 18 Mileage: 186732 km Time Indication: 0 Date: 2107.14.11 Time: 11:58:32 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl Part No SW: 3C0 953 549 AB HW: 3C0 953 549 AB Component: J0527 0020 Revision: 00026000 Serial number: 3C5953507AP Coding: 0001013 Shop #: WSC 00028 028 00001 VCID: 6CD3C0834F90D63 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb Part No SW: 3AA 920 870 H HW: 3AA 920 870 H Component: KOMBI H05 Serial number: 00000000000000 Coding: 160F00 Shop #: WSC 00028 028 00020 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716 ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod VCID: 37792FEF8E56A5B No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 3C0-907-530.lbl Part No SW: 3C0 907 530 H HW: 3C0 907 951 Component: J533__Gateway H13 0142 Revision: H13 Serial number: 2600P0871200EE Coding: FDAB7F064002021002 Shop #: WSC 00028 028 00001 VCID: 2647F2AB91FC2C3 3 Faults Found 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 22 Reset counter: 236 Mileage: 183934 km Time Indication: 0 Date: 2104.14.21 Time: 14:35:18 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 0 km Time Indication: 0 Date: 2107.14.11 Time: 11:58:28 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 18 Mileage: 186732 km Time Indication: 0 Date: 2107.14.11 Time: 11:58:28 ------------------------------------------------------------------------------- Address 22: AWD Labels: Redir Fail! Part No SW: 0BS 907 554 A HW: 0BS 907 554 A Component: Haldex 4Motion 4013 Coding: 0000005 Shop #: WSC 00000 000 00000 VCID: 448348230780FE3 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 3C0-959-433-25.clb Part No SW: 3C0 959 433 AJ HW: 3C0 959 433 AJ Revision: 00051000 Serial number: VWZCZ000000000 Shop #: WSC 65536 1023 2097151 VCID: 72EFDEFB6DB4003 Part No: 3C0 905 861 G Component: ELV 027 0380 3C0905861G ELV 027 0380 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 1T0 035 680 L HW: 1T0 035 680 B Component: RNS-MID H03 5238 Revision: AB001001 Serial number: VWZ6Z7H9225048 Coding: 04000400040000820000 Shop #: WSC 00567 048 00001 ASAM Dataset: ---------------- ------ VCID: 37792FEF8656A5B Subsystem 1 - Part No: 1T0 919 859 B Component: EU West V13 8348 4 Faults Found 00871 - Bass Speaker Front Right (R23) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 21 Reset counter: 18 Mileage: 186728 km Time Indication: 0 00873 - Bass Speaker Rear Right (R17) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 3 Reset counter: 12 Mileage: 186728 km Time Indication: 0 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 5 Fault Frequency: 5 Reset counter: 37 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:28:16 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 5 Fault Frequency: 2 Reset counter: 37 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:25:51 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: None Part No SW: 1K0 959 701 A HW: 1K0 959 793 N Component: J386 TUER-SG FT Revision: 72009005 Serial number: 00000567888715 Shop #: WSC 00028 000 00000 VCID: 2C5300838F10163 2 Faults Found 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 38 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:49:16 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 19 Mileage: 186732 km Time Indication: 0 Date: 2107.14.11 Time: 11:58:30 ------------------------------------------------------------------------------- Address 44: Steering Assist Cannot be reached ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: Redir Fail! Part No SW: 3C0 959 433 AJ HW: 3C0 959 433 AJ Component: KSG PQ46 RDK 051 0221 Revision: 00051000 Serial number: VWZCZ000000000 Coding: 01910A0001860E763004941570084FCE705801 Shop #: WSC 00028 028 00001 VCID: 72EFDEFB6DB4003 Part No: 1K0 951 605 D Component: LIN BACKUP HORN H08 9001 Part No: 3C0 951 171 C Component: Neigungssensor 004 0611 Part No: 3C0 951 171 C Component: Innenraumueb 2 Faults Found 01332 - Door Control Module; Passenger Side (J387) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 19 Mileage: 186732 km Time Indication: 0 Date: 2107.14.11 Time: 11:58:29 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 19 Mileage: 186732 km Time Indication: 0 Date: 2107.14.11 Time: 11:58:29 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: None Part No SW: 1K0 HW: 1K0 959 792 N Component: J387 TUER-SG BT 1517 Revision: 72009005 Serial number: 00000030588724 Shop #: WSC 00028 028 00001 VCID: AC5380830F10963 4 Faults Found 01334 - Door Control Module; Rear Right (J389) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 19 Mileage: 186955 km Time Indication: 0 Date: 2107.14.19 Time: 11:54:16 00933 - Electric Window Motor; Passenger Side (V148) 005 - No or Incorrect Basic Setting / Adaptation - Intermittent Freeze Frame: Fault Status: 00100101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 19 Mileage: 0 km Time Indication: 0 00121 - Outside Warning Light/Door exit Light Passenger Side 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 5 Fault Frequency: 7 Reset counter: 19 Mileage: 186295 km Time Indication: 0 Date: 2106.14.31 Time: 18:13:44 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 38 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:49:16 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: Redir Fail! Part No SW: 3C8 907 801 A HW: 3C8 907 801 A Component: J540 EPB3 VW-10498 0003 Revision: 009 Serial number: 00000000094763 Shop #: WSC 00028 028 00001 VCID: 285BFC939BE83A3 1 Fault Found 00446 - Function Limitation due to Under-Voltage 002 -- Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 37 Mileage: 187453 km Time Indication: 0 Date: 2108.14.02 Time: 00:36:18 Freeze Frame: Voltage: 8.60 V Count: 52 Speed: 0.0 km/h Hex Value: 0x12E1 Hex Value: 0x0021 Hex Value: 0x1010 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
