fcbsoci
Vcds 12.12.0 brak pliku ROD
A wiec po koleii .
Przed swetami pojechalem do vw na akcje z emisja spalin .Pozniej zrobilem czipa w tune force poznan .
Nastepnie zrobilem scan vcds em i nie moge sie z engine 01 polaczyc
moze ktos cos rozkmini ?
Address 01: Engine (J623-CFGB) Labels: None
to powyzej jest na czerwono .
Widze tez ,ze jest blad navi chyba a zmienialem rns315 z mojego na taka sama z 2013 od zwyklego paska takze chyba nie powinno sie nic dodatkowo kodowac ?
Monday,30,January,2017,17:51:57:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ3CZBE743533 License Plate:
Mileage: Repair Order: 30 stycznia 2017 cc
Chassis Type: 3C (7N0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 2E 36 37 42 44 46 4F 52 53
55 56 61 62 65 72
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Part No SW: 03L 997 018 B HW: 03L 907 309 N
Component: R4 2.0l TDI H24 9979
Revision: 47H24--- Serial number: 00000000000000
Coding: 00190012042501080000
Shop #: WSC 77025 210 00000
ASAM Dataset: EV_ECM20TDI01103L997018B 003002
ROD: N/A
VCID: 3365F9479AC0B386591-8066
No ASAM data for: "EV_ECM20TDI01103L997018B" (VW46)
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 M HW: 3AA 614 109 M
Component: J104 C2 450M V481 0005
Revision: --H07--- Serial number: 00000003621526
Coding: 0003001
Shop #: WSC 05311 000 00000
VCID: 377DCD5746B85FA6659-8062
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 ED HW: 5K0 907 044 ED
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000000003
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 71E9334FA05CC1966BD-8024
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 A HW: 3AA 937 087 A
Component: BCM PQ47 H 413 0452
Revision: BB413001
Coding: 000000000000000000180010940089A4437D7788602007206480C7200041
Shop #: WSC 05311 123 12345
VCID: 387FCE6B8BA650DE6C3-806D
Subsystem 1 - Part No SW: 3C8 955 119 E HW: 3C8 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 03091 10 0603
Coding: 00B7B5
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 040111 05 54 0403
Coding: 073028
Address 10: Park/Steer Assist (J446) Labels: 3AE-919-475.clb
Part No SW: 3AE 919 475 HW: 7N0 919 475
Component: PARKHILFE 8K H04 0009
Revision: -------- Serial number: 77631101100396
Coding: 108003
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_EPHVA18VW47X0000 001003
ROD: EV_EPHVA18VW4280000.rod
VCID: FCF7927B771E3CFE48B-80A9
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 05011104270001
Coding: 010180
Shop #: WSC 05314 000 00000
VCID: 275D1D175618CF26F59-8072
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 Q HW: 5N0 959 655 Q
Component: J234__31C VW10 HI 1918
Revision: 22014000 Serial number: 003JZPS92BZ
Coding: 0012611
VCID: 4B9581A72A30CB46311-801E
Subsystem 1 - Serial number: 6332MTS694883420
Subsystem 2 - Serial number: 6342MTS659163430
Subsystem 3 - Serial number: 6351HTS6R9UTL9KJ
Subsystem 4 - Serial number: 6361HTS6N50UL9KJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101221201314
Coding: 0182270000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 72EB3C43A55AFA8E927-8027
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 970 P HW: 3C8 920 970 P
Component: KOMBI H20 0420
Coding: 140F00
Shop #: WSC 05314 115 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 3979CB6FB8AC49D693D-806C
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 G HW: 1K0 907 951
Component: J533 Gateway H41 1614
Revision: H41 Serial number: 040111F2000621
Coding: 464007
Shop #: WSC 05314 123 12345
VCID: 3467FA5B97CEB4BE40B-8061
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0399
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 42875 001 1048576
VCID: F6E38053813266AE3EF-80A3
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Component: SG EXT.PLAYER H13 0150
Revision: A1001003 Serial number: 7669174002
Coding: 020000
VCID: 285F1E2B5B06C05EFC3-807D
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 169
Mileage: 193566 km
Time Indication: 0
Date: 2004.14.28
Time: 16:23:35
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 A HW: 3C8 959 760 A
Component: Sitzmemory H05 2301
Revision: 00H05000
Coding: 000039
Shop #: WSC 00000 000 00000
VCID: 3365F94792C0B386591-8066
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 1
Reset counter: 150
Mileage: 193354 km
Time Indication: 0
Date: 2004.14.18
Time: 15:35:10
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 B HW: 3C8 035 279 B
Component: RNS315-EU H59 0319
Serial number: VWZAZ2M0004490
Coding: 040004010400110000019002
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 2A5BE4234D0AF24EEA7-807F
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V6 0062
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0502
Revision: 12110009 Serial number: 0002021254
Coding: 0213B7
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: EDD1AF3F3C64A576CF5-80B8
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 704 C HW: 3C0 959 794 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001868441
Coding: 000090
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 207 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 3467FA5B57CEB4BE40B-8061
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 043 0631
Coding: 19910A0001864E3F00029C1D7008DFCE105C01
Subsystem 1 - Part No: 1K8 951 605 A
Component: LIN BACKUP HORN H11 9004
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1614
Coding: 00000008
VCID: EFEDB5373E685766FD9-80BA
Subsystem 1 - Part No SW: 3AA 919 204 HW: 3AA 919 204
Component: Analoguhr 003 0003
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0502
Revision: 14110009 Serial number: 0002019753
Coding: 0213B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: EED3A83331625E6EF6F-80BB
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 703 C HW: 3C0 959 795 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001799808
Coding: 000090
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000113125
Coding: 0022067
VCID: 3365F94752C0B386591-8066
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0148
Revision: 00H04000 Serial number:
Coding: 3493320
Subsystem 1 - Part No: 1K0 941 329
Component: AFS-Lst.-Modul l 0008
Coding: 00000053
Subsystem 2 - Part No: 1K0 941 329
Component: AFS-Lst.-Modul r 0008
Coding: 00000053
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1614
Coding: 030B185A
VCID: F1E9B34F285C4196EBD-80A4
Subsystem 1 - Part No SW: 1K0 915 181 F HW: 1K0 915 181 A
Component: J367-BDM H07 0150
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 B HW: 3AA 907 273 B
Component: RDKBERU30 H08 0008
Serial number: 10000000015292
ASAM Dataset: EV_RDKBERU30 003010
ROD: EV_RDKBERU30_SE36.rod
5 Faults Found:
8397058 - Front Left TPMS Sensor
C1050 31 [009] - No Signal
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 186030 km
Date: 2066.14.12
Time: 16:07:29
8397314 - Front Right TPMS Sensor
C1051 31 [009] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 186030 km
Date: 2066.14.12
Time: 16:07:29
8397570 - Rear Left TPMS Sensor
C1052 31 [009] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 186030 km
Date: 2066.14.12
Time: 16:07:29
8397826 - Rear Right TPMS Sensor
C1053 31 [009] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 246
Mileage: 186030 km
Date: 2066.14.12
Time: 16:07:29
8402177 - System Switched Off
C106D 00 [009] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 246
Mileage: 186025 km
Date: 2066.14.12
Time: 15:33:58
End ---------------------------------------------------------------------
Edytowane przez fcbsoci
A takie coś mi wyskakuje po skanie
Nasuwają mi się 2 pytania.
Czy przez to że vw zaktualizował ecu mój kabel z wersją programu 12.12.0 jest za stary ?
czy może jednak panowie z tuneforce poznam gdy wyjeli ECU i wygrywali nowa mapę na stole coś zjebali ?
A jak zamkniesz program, odłączysz kabel na sek. i podłączysz jeszcze raz i wejdziesz ponownie np. Seat Mem. Wywala to samo za każdym razem? Klony tak mają że gubią Rody.
Wysłane z ekranu
Wysłane z ekranu
A więc tak ,kiedyś już ten plik mi zaginął ale reinstalacja programu zawsze pomogła ale tym razem niestety nie.
Pobrałem program na nowo z linku który dostałem od osoby która mi kabel sprzedała i to też nie pomogło.
Jutro sprawdzę i dam znać.
