marky
Błąd 928 i 930
Wywala mi dwa błędy. Mam problem z ryglowaniem drzwi od wewnątrz (z pilota jest ok) i sporadycznie włączającym się autoalarmem.
Czy dobrze to interpretuję, że mam do sprawdzenia "tylko": moduł komfortu, kabelki, wszelakie wtyczki od tych kabli, zamek w drzwiach?
00928 - Locking Module for Central Locking; Front Driver Side (F220)
00928 - Locking Module for Central Locking; Front Driver Side (F220): Implausible Signal
Possible Symptoms
* Door Locks not working properly
Possible Causes
* Wiring/Connectors from/to Locking Module for Central Locking; Front Driver Side (F220) faulty
* Voltage Supply for Locking Module for Central Locking; Front Driver Side (F220) faulty
* Door Lock Mechanics are stiff/partially seized
* Locking Module for Central Locking; Front Driver Side (F220) faulty
Possible Solutions
* Check Wiring/Connectors from/to Locking Module for Central Locking; Front Driver Side (F220)
* Check Voltage Supply for Locking Module for Central Locking; Front Driver Side (F220)
* Check Door Lock Mechanics/Operation
* Check Locking Module for Central Locking; Front Driver Side (F220)
00928 - Locking Module for Central Locking; Front Driver Side (F220): Incorrectly Equipped
Possible Symptoms
Possible Causes
* Incorrect Door Lock installed
Possible Solutions
00930 - Locking Module for Central Locking; Rear Left (F222)
Possible Solutions
* Check Door Contact Switch (F10)
* Check Central Locking Module Rear Left (F222)
* Check Central Locking Motor (V115) with Actuator (Lock) Rear Left (F133)
* Check Central Locking Motor (V163) with Actuator (Safe) Rear Left (F245)
* Check Child Safety Motor Rear Left (V142)
00930 - Locking Module for Central Locking; Rear Left (F222): Implausible Signal
Possible Symptoms
Possible Causes
* Wiring/Connectors from/to Locking Module for Central Locking; Rear Left (F222) faulty
* Voltage Supply for Locking Module for Central Locking; Rear Left (F222) faulty
* Locking Module for Central Locking; Rear Left (F222) faulty
Possible Solutions
* Check Wiring/Connectors from/to Locking Module for Central Locking; Rear Left (F222)
* Check Voltage Supply for Locking Module for Central Locking; Rear Left (F222)
* Check Locking Module for Central Locking; Rear Left (F222)
00930 - Locking Module for Central Locking; Rear Left (F222): Incorrectly Equipped
Possible Symptoms
Possible Causes
Possible Solutions
o Check Door Lock Part Number
Jednostka zamykająca F220 centralnego zamka drzwi LP
Jednostka zamykająca F222 centralnego zamka drzwi LT
Jak dobrze rozumiem, błędy te wskazują najprawdopodobniej na problem z zamkiem?
00928 - Blokujący Moduł dla Centralnego Zamykania; Przedni Kierowca Strona ( F220)
00928 - Blokujący Moduł dla Centralnego Zamykania; Przedni Kierowca Strona ( F220): Nieprawdopodobny Sygnał
Możliwe Symptomy
* Zamki Drzwi pracujące właściwie
Możliwe Przyczyny
* Drutując / Wtyczki od / do Zamykania na klucz Modułu dla Centralnego Zamykania; Przedni Kierowca Strona ( F220) wadliwy
* Zapas Napięcia dla Zamykania na klucz Modułu dla Centralnego Zamykania; Przedni Kierowca Strona ( F220) wadliwy
* Mechanicy Zamka Drzwi są sztywni / częściowo zacięty
* Blokujący Moduł dla Centralnego Zamykania; Przedni Kierowca Strona ( F220) wadliwy
Możliwe Rozwiązania
* Instalacja Kontroli / Wtyczki od / do Zamykania na klucz Modułu dla Centralnego Zamykania; Przedni Kierowca Strona ( F220)
* Zapas Napięcia Kontroli dla Zamykania na klucz Modułu dla Centralnego Zamykania; Przedni Kierowca Strona ( F220)
* Mechanicy Zamka Drzwi Kontroli / Operacja
* Sprawdź Zamykanie na klucz Modułu dla Centralnego Zamykania; Przedni Kierowca Strona ( F220)
00928 - Blokujący Moduł dla Centralnego Zamykania; Przedni Kierowca Strona ( F220): Niepoprawnie Zaopatrzył
Możliwe Symptomy
Możliwe Przyczyny
* Niepoprawny Zamek Drzwi zainstalował
Możliwe Rozwiązania
00930 - Blokujący Moduł dla Centralnego Zamykania; Tył Zostawił ( F222)
Możliwe Rozwiązania
* Skontaktować się Drzwi Kontroli z Witką ( F10)
* Sprawdź Centralnego Zamykającego na klucz Tył Modułu Zostawiony ( F222)
* Sprawdź Centralnego Zamykającego na klucz Motor ( V115) z Organ wykonawczy ( Zamkiem) Wznieść Lewa strona ( F133)
* Sprawdź Centralnego Zamykającego na klucz Motor ( V163) z Organ wykonawczy ( Bezpieczna) Lewa strona Tyłu ( F245)
* Dziecko Kontroli Bezpieczeństwo Motor Tył Zostawiło ( V142)
00930 - Blokujący Moduł dla Centralnego Zamykania; Tył Zostawił ( F222): Nieprawdopodobny Sygnał
Możliwe Symptomy
Możliwe Przyczyny
* Drutując / Wtyczki od / do Zamykania na klucz Modułu dla Centralnego Zamykania; Tył Zostawił, że ( F222) jest wadliwy
* Zapas Napięcia dla Zamykania na klucz Modułu dla Centralnego Zamykania; Tył Zostawił, że ( F222) jest wadliwy
* Blokujący Moduł dla Centralnego Zamykania; Tył Zostawił, że ( F222) jest wadliwy
Możliwe Rozwiązania
* Instalacja Kontroli / Wtyczki od / do Zamykania na klucz Modułu dla Centralnego Zamykania; Tył Zostawił ( F222)
* Zapas Napięcia Kontroli dla Zamykania na klucz Modułu dla Centralnego Zamykania; Tył Zostawił ( F222)
* Sprawdź Zamykanie na klucz Modułu dla Centralnego Zamykania; Tył Zostawił ( F222)
00930 - Blokujący Moduł dla Centralnego Zamykania; Tył Zostawił ( F222): Niepoprawnie Zaopatrzył
Możliwe Symptomy
Możliwe Przyczyny
Możliwe Rozwiązania
Część Zamka Drzwi Kontroli zera Zdrętwiały
Nie patrz na stylistykę i pisownie, użyłem translatora :) i nie chciało mi się go poprawiać :D
_________________
Na ciebie kuczlaw można liczyć. Dzięki.
To teraz będę miał zabawę :kwasny:
:hurra: autor :hurra: autor :hurra: tłumaczenia :rotfl:
mam ten sam błąd 0930, zamykanie z kluczyka działa tak jak z pilota czyli nie działa poprawnie, próbuje sobie domknąć drzwi.
Czy do wymiany mam zamek??
dzisiaj po skanie skasowałem błędy i pojawił się na nowo:
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-00 - Implausible Signal
Wcześniej było kilka błędów też z tymi drzwiami związanych.
ma ktoś rozwiązanei za co się brać po kolei?
Trza rozbierać drzwi też mi to wyskoczyło ale rozwiazania w tych drzwiach to są tragiczne z tym zaczepem do klamki to bez sens straszny
a koledzy co może być związane z tym że oprócz tego błędu wyskakuje jeszcze błąd od regulatora okna lewego. czasami nei działa podnoszenie/opuszczanie okna. czy nie będzie to jakaś wiązka/wtyczka gdzieś do poprawy?
wymien przycisk przy panelu do otwierania i zamykania szyb:) ja tez tak mialem ale wymienilem panel okazyjnie kupiony za 15 zl i teraz smiga :)
heh ale to i tak nie zlikwiduje mojego błędu od zamka który raz działa a raz nie działa. tak myslałem że może jest to gdzie połączone w kupie i na jakiejś wiązce nie styka:)
Powiem Ci ze mam te same bledy co ty tylko ze mi sie zamki po lewej stronie zamkna po chwili odryglowywuja sie:/ a pozakladalem cakowicie nowe zamki:/ i tez nie potrafie sobie z tym poradzic:/
no ja jak zamykam z pilota albo z kluczyka to spoko zamek sie zamyka i nie odskakuje. a jak zamykam do środa (z panelu w drzwiach) to czasami się zamknie a czasami właśnie się zamknie i odskoczy;/ może ktoś poradzi coś jeśli to nie zamki..
Widzę, że kolega z Nowego Sącza i jak w pysk strzelił ma identyczny problem, co ja :(
Otóż sytuacja wygląda u mnie tak: jak rygluję z pilota, to jest ok, jak zamykam kluczykiem, to jest ok, ale jak chcę się zamknąć od środka, to rygluje wszystkie drzwi, a lewe tylne drzwi (za kierowcą) odskakują (ten dzyndzel). Zamyka się i zaraz odskakuje z powrotem. Od jakiegoś pół roku czasu miałem taki efekt, że raz sie to ryglowało, raz nie, ale od dziś zupełnie sie nie rygluje od środka...
Jak to ugryźć?
I oczywiście błąd 0930 - IMPLAUSIBLE SIGNAL REAR LEFT.
Gnojstwo straszne, a muszę to mieć, bo zawsze jeżdżę zamknięty od środka :(
Sprawdziłem kable, które są pod tym mieszkiem gumowym między drzwiami i kable wyglądają na ok, nie są złamane/przerwane.
Co teraz pozostaje?
Mam jeszcze problem z tym, ze miga mi taka niebieska dioda, która jest na konsoli środkowej (chyba od alarmu). Dawniej (właściwie) było tak, że ona migała co sekundę po zamknięciu auta, a teraz jak go otworzę z kluczyka, to miga pulsacyjnie tak jakby był alarm, ale w ogóle nie ma odgłosu syreny...
Coś mi się całkiem poyebało z tym alarmem :/
no ja jeszcze zauważyłem że jak zamykam auto z pilota to zawsze zamknie ale nie zawsze migną kierunki. to chyba właśnie przez to że nie trybi że drzwi zamknięte. chyba się będziemy musieli umówić i pogmyrać w tych naszych maszynach :D
Tylko, ze ja totalnie nie znam się na takich rzeczach :/
to może znajdziemy kogoś kto nam to ogarnie w miarę tanio bo mi z kolei się nie chce za to zabierać :P
Dziś pytałem kolegów z aso skody i mi powiedział mechanik, że tak też się działo w golfach i superbach... Sprawcą tego jest uszkodzony zamek w drzwiach. Zasadniczo zamek jest do wymiany, a koszt takiego w skodzie, to 530 zł, a w vw, to 510 zł :/
Numer referencyjny lewego tyłu (za kierowcą), to: 3B4839015A
no oni mówią że zamek 90% forum mówi że zimne luty :D jak dla mnie warto zaoszczędzić te parę stówek samemu to wszystko rozebrać posprawdzać i polutować od nowa:)
