Gość kicol Zgłoś #1 Napisano 14 Maja 2007 Witam wszystkich! oto mój wyciąg z autoscanu: Chassis Type: 3B - VW Passat B5 Address 01 ------------------------------------------------------- Controller: 038 906 019 EJ Component: 1,9l R4 EDC 0000SG 1369 Coding: 00002 Shop #: WSC 05314 WVWZZZ3BZ2E20XXXX VWZ7Z0A420XXXX 2 Faults Found: 18057 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 35-10 - - - Intermittent 17965 - Charge Pressure Control: Positive Deviation P1557 - 35-00 - - Address 03 ------------------------------------------------------- Controller: 4B0 614 517 G Component: ABS/ESP front 1728 Coding: 04255 Shop #: WSC 05311 No fault code found. Skipping Address 15-Airbags Address 17 ------------------------------------------------------- Controller: 3B0 920 807 A Component: KOMBI+WEGFAHRSP VDO V01 Coding: 05115 Shop #: WSC 00000 WVWZZZ3BZ2E20XXXX VWZ7Z0A420XXXX 2 Faults Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent 00462 - Control Module for Seat Memory: Rear (J522) 49-00 - No Communications Address 19 ------------------------------------------------------- Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 05314 3 Faults Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent 00462 - Control Module for Seat Memory: Rear (J522) 49-00 - No Communications 00463 - Control Module for Digital Sound Package (J525) 49-00 - No Communications Address 46 ------------------------------------------------------- Controller: 1C0 959 799 B Component: 10 Komfortgerát HLO 0003 Coding: 00259 Shop #: WSC 05311 No fault code found. Address 56 ------------------------------------------------------- Controller: 1J0 035 152 E Component: Radio GRO 0001 Coding: 00001 Shop #: WSC 05311 No fault code found. End ------------------------------------------------------- Wszelka pomoc w rozszyfrowaniu mile widziana Nie włączałem w autoscanie poduszek, ponieważ VAG wyświetlił info, że w rocznikach 00/01 jest jakiś numer sterownika (czy czegoś tam), który może spowodować zniszczenie poduszek więc sobie odpuściłem. Mam też log z jazdy jeśli są chętni czarodzieje do odszyfrowania z miłą chęcią podrzucę... Z góry dzięki za wszelką pomoc Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Marek Zgłoś #2 Napisano 14 Maja 2007 Address 01 ------------------------------------------------------- 18057 - P1649 - 4689 - Powertrain Data Bus: Missing Message from ABS Controller P1649 - 35-10 - - - Intermittent Magistrala danych napędu, brak danych z komputera sterującego systemem ABS. Tu trzeba dowiedzieć się co powoduje brak komunikacji bo powodów może być całkiem sporo, ale jest to zadanie raczej dla kogoś doświadczonego i bezpośrednio przy aucie. Problem może leżeć najprawdopodobniej w instalacji na linii z modułem ABS. 17965 - P1557 - 462D - Charge Pressure Control: Positive Deviation P1557 - 35-00 - - Przekroczona w górę granica regulacji układu regulacji ciśnienia doładowania. Prawdopodobnie szwankuje zaworek N75 ale trzeba to sprawdzić bo może być problem gdzie indziej na rurach powietrznych lub podciśnieniu - generalnie trzeba sprawdzić działanie całego układu od turbo (kierownice) po kolektory. Usterka wiele razy opisywana na forum lecz przyczyn może być również sporo. Address 17 ------------------------------------------------------- 01314 - 0522 - Engine Control Module 49-10 - No Communications - Intermittent Komunikacja magistrali danych BUS (niewłaściwy odbiór danych z magistrali CAN) 00462 - Control Module for Seat Memory: Rear (J522) 49-00 - No Communications moduł sterujący pamięcią ustawienia siedzenia/fotela Address 19 ------------------------------------------------------- 01314 - Engine Control Module 49-10 - No Communications - Intermittent 00462 - Control Module for Seat Memory: Rear (J522) 49-00 - No Communications 00463 - Control Module for Digital Sound Package (J525) 49-00 - No Communications Tak na dobrą sprawę to coś za dużo tu błędów związanych z głównymi modułami/ sterownikami, możliwe że są to stare błędy na wskutek licznego odłączania lub ingerencji w te moduły lub początek pewnych niesprawności instalacji lub nawet błędnego kodowania tych sterowników. Skasuj teraz błedy i autko idzie pod obserwację diagnostyczną - interesują nas błędy które nie dadzą się wykasować lub powrócą ponownie. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Gość kicol Zgłoś #3 Napisano 14 Maja 2007 Wielkie dzięki Marku wiedziałem, że mogę na Ciebie liczyć Jeśli chodzi o przekroczoną górną granicę ładowania to jakieś 25tyś km wstecz miałem czyszczoną turbinę, ponieważ miała zapieczone kierownice (auto stało 2 miesiące) i nie można było ujechać Po wyczyszczeniu dość długo było dobrze jednak ostatnio pojawiały się przypadki odłączania turbiny być może turbina znowu nadaje się do czyszczenia lub wymiany. Nie bardzo wiem o co może chodzić z pamięcią foteli - ja nie mam żadnej elektrycznej regulacji... Pokasuje wszystkie błędy i za jakiś czas znowu puszcze autoscana Jeszcze raz dzięki za pomoc! Pozdrawiam Błażej Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
MrTi2310 Zgłoś #4 Napisano 13 Lipca 2014 Witam wszystkich Też mam prośbę o sprawdzenie co mi tu VAG odnalazł. Zgóry dzięki. Chassis Type: 3B - VW Passat B5 Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,57,58,76 ------------------------------------------------------------------------------- Address 01: Engine Controller: 038 906 019 EN Component: 1,9l R4 EDC G000SG 1441 Coding: 00002 Shop #: WSC 05314 WVWZZZ3BZ2E161959 VWZ7Z0A4075361 No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Controller: 4B0 614 517 G Component: ABS/ESP front 1728 Coding: 04255 Shop #: WSC 05311 No fault code found. ------------------------------------------------------------------------------- Skipping Address 15-Airbags ------------------------------------------------------------------------------- Address 17: Instruments Controller: 3B0 920 846 A Component: KOMBI+WEGFAHRSP VDO V01 Coding: 21115 Shop #: WSC 00186 WVWZZZ3BZ2E161959 VWZ7Z0A4075361 1 Fault Found: 00462 - Control Module for Seat Memory: Rear (J522) 49-00 - No Communications ------------------------------------------------------------------------------- Address 19: CAN Gateway Controller: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 05314 4 Faults Found: 00462 - Control Module for Seat Memory: Rear (J522) 49-00 - No Communications 00778 - Steering Angle Sensor (G85) 49-10 - No Communications - Intermittent 01331 - Door Control Module: Driver Side (J386) 49-10 - No Communications - Intermittent 00463 - Control Module for Digital Sound Package (J525) 49-00 - No Communications ------------------------------------------------------------------------------- Address 37: Navigation Controller: 1J0 919 887 A Component: Navigation BNO 0206 Coding: 00000 Shop #: WSC 50628 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Controller: 1C0 959 799 B Component: 0J Komfortgerát HLO 0003 Coding: 00259 Shop #: WSC 05311 1 Fault Found: 00930 - Locking Module for Central Locking: Rear Left (F222) 27-00 - Implausible Signal ------------------------------------------------------------------------------- Address 55: Xenon Range Controller: 4Z7 907 357 Component: dynamische LWR D06 Coding: 00007 Shop #: WSC 05311 1 Fault Found: 01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48) 30-00 - Open or Short to B+ ------------------------------------------------------------------------------- Address 56: Radio Controller: 1J0 035 152 G Component: Radio BNO 0206 Coding: 05205 Shop #: WSC 50628 1 Fault Found: 00856 - Radio Antenna 36-00 - Open Circuit End -------------------------------------------------------------------------------------------------- Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mRs Zgłoś #5 Napisano 13 Czerwca 2016 ------------------------------------------------------------------------------- Address 55: Xenon Range Controller: 4Z7 907 357 Component: dynamische LWR D06 Coding: 00007 Shop #: WSC 05311 1 Fault Found: 01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48) 30-00 - Open or Short to B+ Mam ten sam problem z poziomowaniem Xenonu po wymianie silniczka w reflektorze lewym więc podłączam się do zapytania. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
